Rudder Pedal Boots
moe(at)rosspistons.com
PostPosted: Mon Jun 25, 2007 8:07 am    Post subject: Rudder Pedal Boots Reply with quote
[img]cid:image001.gif(at)01C7B708.88CBD6B0[/img] 625 S. Douglas, El Segundo, CA 90245 ● Phone: (310) 536-0100 Fax: (310) 536-0333
moe(at)rosspistons.com (moe(at)rosspistons.com) �
Fellow Commander Drivers:
The last couple of flights, the pressurization in N680RR my 680F(p) has really been weak. The problem is the boots around the rudder pedals are cracked and leaking air big time. I had always assumed that they were made of a nice, thin, and flexible leather, however, when removed they appear to be cloth that has been coated (almost like an old oil cloth table cloth). Has anyone made or had made replacement rudder pedal boots, and if so, what did you use?
Comments will be greatly appreciated.
Moe
 Filesize:  7.29 KB
 Viewed:  2164 Time(s)
deneals(at)deneals.com
PostPosted: Mon Jun 25, 2007 8:43 am    Post subject: Rudder Pedal Boots Reply with quote
On 6/25/07 11:09 AM, "Moe - Ross Racing Pistons" <moe(at)rosspistons.com> wrote:
Moe
I have not had any experience with this, but your description reminds me of the shift boot I had in my 1986 Audi with manual transmission.
I had always thought it was leather until I replaced it to find it was a plasticized or rubberized material over a cloth-like base.
Just an idea for an “adaptation.”
Deneal Schilmeister ATP Learjet
St. Louis, Missouri USA
http://deneals.com
[img]cid:3265616597_212744[/img]
 Filesize:  1.08 KB
 Viewed:  2163 Time(s)
floydgm(at)hotmail.com
PostPosted: Mon Jun 25, 2007 9:11 am    Post subject: Rudder Pedal Boots Reply with quote
Those boots are readily available from TCAC part number is 860227-7 and
860227-9
Mike
Get a preview of Live Earth, the hottest event this summer - only on MSN
http://liveearth.msn.com?source=msntaglineliveearthhm
swperk(at)earthlink.net
PostPosted: Mon Jun 25, 2007 5:46 pm    Post subject: Rudder Pedal Boots Reply with quote
At the Twin Commander University last March, TCAC passed around a few different prototypes for replacement boots they’ve designed, built, and tested (the example they showed was for the control column, but the construction methods would be essentially the same for all six boots). The idea is to redesign the boots to make them significantly more durable and easier to replace. From what I saw, they looked very promising, especially compared to the original equipment. No time frame or cost estimates, though.
I think that I’ll be needing to replace mine soon enough, so I have a particular interest in this topic, too!
Stan
N681SP
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe - Ross Racing Pistons
Sent: Monday, June 25, 2007 9:09 AM
Subject: Rudder Pedal Boots
[img]cid:image001.gif(at)01C7B759.0143A050[/img] 625 S. Douglas, El Segundo, CA 90245 ● Phone: (310) 536-0100 Fax: (310) 536-0333
Moe
 Filesize:  7.29 KB
 Viewed:  2190 Time(s)
