Gilles.Thesee(at)ac-greno Guest
Posted: Fri Jun 22, 2007 3:08 am Post subject: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
JetPilot a écrit :
Quote: |
CHT's running 100 degrees F ???? That does not make any sense at all. That is very close to the reading you would get with a completely cold engine. Something wrong in your readings, or in your reporting of temperatures. A CHT 100 degrees for a running engine is impossible.
Isn't there a confusion with Celsius ? The Rotax is a Eurapean engine.
100 degrees Celsius is quite normal for CHT in a cruise, whereas 150°C
is the absolute redline.
By the way, the Rotax 91X are easy to cool once you do your air inlet
and diffuser homework.
Gilles Thesee
http://contrails.free.fr
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Roger Lee
Posted: Fri Jun 22, 2007 6:53 am Post subject: Re: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
Hi Giles,
Your right about the temps if he said they were Celcius, but he said they were F. Most of us here in the US run our gages in F, but you have the option of using C on a lot of gage sets.
Here is an easy, do it in your head, formula for converting C to F.
Take C and double it,
then minus 10% from that doubled number,
then add 32 to that number and you have F.
Example:
20 degrees C x 2 = 40
now minus 10% which is 4 which equals 36,
now add 36 + 32 = 68F
Example:
30c x 2 = 60,
minus 10% (60-6=56),
56 + 32 = 86F
Do it in your head easy. Now when they tell you on the radio it is 35c for an OAT, you will know it's??????
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Mon Jun 25, 2007 2:30 am Post subject: Rotax 912 Cooling issue / Zodiac CH 601 HDS |
Roger,
Thank you for your message.
Yes the temps in question were said to be F, but as they did not seem to
make sense, the possibility of a unit confusion came to my mind.
Re the tip on conversion, as European flyers, we are used to convert
when dealing with engines from across the pond (though we usuallly do
convert from F to C).
Funnily, in P51 field manuals, the engine temps were in Celsius during WWII.
Best regards,
Gilles
