Posted: Fri Jun 22, 2007 12:35 pm Post subject: Ms Dixie Fine Tuning |
Paul,
A few years ago I restored/rebuilt a Wizard ultralight. Many pieces were
missing, so I was left to come up with my own unproven designs on a couple
of parts. One of the things that turned out to be in need of improvement
that I built was the throttle. Mine, like yours, was touchy as a son of a
gun! I had a friend test-fly my Wizard (Quicksilver clone) and he really
suggested fixing it, too.
By moving the push/pull point closer to the pivoting point on the
throttle lever, I significantly changed the rpm range when applying power.
Now, when you push the lever to increase power a 1/2" you get 50 rpm
increase, instead of 300 rpm. So, instead of an overall throw of 2 1/2" I
ended up with a 7" throw. (These numbers are from memory, but you get the
idea.)
So it is my experience, and opinion that you might really consider
improving the throttle response to not being so touchy.
If your set-up is like mine was, a lever you push and pulled, then all you
need to do is relocate the attach point closer to the fulcrum. (Cut the
distance in half and see how that acts)
Of course, the overall distance of throw will limit the attach point,
also. You will want to make sure you still have the full rpm capability.
The geometry has to make sense!!!
One more thing to consider would be the safety aspect. I believe it would
be very possible to experience PIO (pilot induced oscillation) if you can't
control your RPM range precisely. (That's kind of what my friend
experienced. He said there was "no control", just rapid changes to much
different RPM settings!)
Best of "training" regarding your first flight, ( I don't
believe in "luck")
Mike Welch in SW Utah
BTW. My shop and pool I have been building are virtually finished. All
that's left on my shop is the doors I am going to make. Here's a photo with
my MkIII and the GlaStar.
Don’t miss your chance to WIN $10,000 and other great prizes from Microsoft
37.34 KB |
488 Time(s) |
Steve Boetto
Posted: Sat Jun 23, 2007 5:36 am Post subject: Ms Dixie Fine Tuning |
Very nice Mike
steve
See what's free at AOL.com.
Paul Petty
Posted: Sat Jun 23, 2007 3:21 pm Post subject: Re: Ms Dixie Fine Tuning |
Thanks Mike! as of today we looked at the pivot point on the throttle lever at the main connection and there is plenty of room to get the connection closer to the center of the rear quadrant.....Kolbras work the throttle from the rear seat lever via a push pull tube to the front seat. what the upper cable slot is and it's attach point is still a mystry to me!
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
blackbird
Posted: Sun Jun 24, 2007 11:11 am Post subject: Re: Ms Dixie Fine Tuning |
Hey Paul,
I think the throttle part you described is from the OLD days.......LOL
On a two stroke it was used for the choke (enricher) circuit..........
I know......only on two strokes..............LOL
Mystery solved................
WT
_________________ Wish I lived in the American REPUBLIC!!! |
