hansriet
Posted: Fri Jun 22, 2007 6:31 am Post subject: Wings options |
I'm about ready to order the wings for my Zodiac XL kit and I would like some insights on the options.
Having flown with the Canadian flex-aileron equipped demonstrator, I'm pretty much set on the piano-hinge option.
But what about the wing lockers? Will I need the extra space, especially when I'm thinking of installing a BRS parachute in the luggage area?
Long range tanks or not? Even in our Cessna Cardinal I never fly longer than 2.5 hours. Do I need the extra range or safe some weight with full tanks?
I was thinking of installing wig-wag lights. Shall I order an extra lens, riblet and channel and install this mirrored in the opposite wing?
Your thought are greatly appreciated.
Hans van Riet
Gig Giacona
Posted: Fri Jun 22, 2007 8:58 am Post subject: Re: Wings options |
Weight in the wing lockers have a LOT less moment than anything put in the back luggage area and that is a good thing. Especially if you are going to hard mount 25 lbs. in the back.
If you never fly more than 2.5 hours why would even consider the long range tanks? The 12 gallon tanks give you 4+ hours at 5 gph.
| hansriet wrote: | I'm about ready to order the wings for my Zodiac XL kit and I would like some insights on the options.
Hans van Riet |
601XL Under Construction
stutzman(at)stutzman.com Guest
Posted: Fri Jun 22, 2007 9:35 am Post subject: Wings options |
On Fri, 22 Jun 2007, Gig Giacona wrote:
| Quote: | If you never fly more than 2.5 hours why would even consider the long
Probably for the same reason you see a lot of tip tanks on high
performance singles.
It really reduces operational costs when you have the ability to
load up on cheap fuel when the opportunity arises.
Frank Stutzman
601zv(at)ritternet.com Guest
Posted: Fri Jun 22, 2007 9:41 am Post subject: Wings options |
I've been places where the price of fuel has made me wish I could have
brought more along.
Do not archive.
crvsecretary
Joined: 18 Mar 2007 Posts: 38 Location: Naugatuck, CT
Posted: Fri Jun 22, 2007 9:45 am Post subject: Wings options |
Hello Hans:
IMHO, wing lockers are a must for all the reasons mentioned previously.
RE: Long-range tanks - just remember, you don't HAVE to fill them up all the way all the time - just when you want extra fuel on board. It's not an option you can easily add later, do if it's in the budget, do it NOW,
You have the same thoughts as I RE: wig-wag lights. Here's a thought: I assume you successfully built your rudder and stab by now and you're getting pretty good at all this, right ??? By the time you finish the first wing your skill set will be even further along...so why not wait until you're ready to order up those extra parts for the extra light....you might feel confident enough to SCRATCH-BUILD your first parts.
Just my $0.02
Tracy Smith
N458XL (reserved)
601XL
working on wings - forever
In a message dated 6/22/2007 9:32:43 AM Eastern Standard Time, hansinla(at)mac.com writes:
| Quote: | --> Zenith-List message posted by: Hans van Riet <hansinla(at)mac.com>
Hans van Riet
See what's free at AOL.com.
_________________ Zenith 601XL N458XL (reserved)
Naugatuck, CT
Tail Complete; working on wings |
gscampoli(at)HOTMAIL.COM Guest
Posted: Fri Jun 22, 2007 10:28 am Post subject: Wings options |
Hans,
My first instructor taught me that there is nothing less valuable to a pilot
than runway behind you, altitude above you or fuel left on the ground.
If you are certain that you are NEVER going to fly more than 2 1/2 hour
legs, standard tanks are the way to go. But, on an extended cross-country,
eliminating a fuel stop or two can save a lot of time and, believe it or
not, fuel. You can always fill the tanks only half full for the short
jaunts and eliminate the weight penalty, but it's really convenient to have
the ability to extend your cross-country legs to 3 1/2 to 4 hours.
In my case though, my kidney will usually force a stop long before the fuel
runs low.
Blue skies,
Gerry Scampoli
Hingham, MA
601XL - Corvair
| Quote: | From: Hans van Riet <hansinla(at)mac.com>
| Quote: | Long range tanks or not? Even in our Cessna Cardinal I never fly longer
tanks?
Hotmail to go? Get your Hotmail, news, sports and much more!
http://mobile.msn.com
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Fri Jun 22, 2007 10:32 am Post subject: Wings options |
Hans
I chose to go with the wing lockers even without a BRS parachute, because
the Zenith folks tell me that the main baggage area is limited to 40 lbs.
That is about what I used to carry in my pack when backpacking--not much
for two people. I chose to go with the standard 12 gal tanks, mostly
because I didn't want the extra weight, and, as Gig points out, 4 hrs is
about as long as I'm likely to fly. Finally, regarding the wig-wag lights,
I just bought a lens from Zenith which I plan to cut in half, one piece for
each wing. Then I plan to scratch build a mounting plate for HID landing
and taxi lights, probably 35W units from Creativair. I'm assuming that the
small HID lights will do fine with half a lens. I haven't worked out the
final design. I hope it will all fit together.
Of course, I'm still working on my rudder, so my wig-wag plans are long way
from fruition.
Terry
At 09:58 AM 6/22/2007 -0700, you wrote:
| Quote: | Weight in the wing lockers have a LOT less moment than anything put in the
> Hans van Riet
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Just starting a 601 kit
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Gig Giacona
Posted: Fri Jun 22, 2007 10:36 am Post subject: Re: Wings options |
The long range tanks are 15 gallon, right? So we are talking 6 extra gallons. If your normal fuel price is say $3.50 and where you are going is double that you are only saving $22.00.
Plus fully fueled it is an additional ~36lbs and I like to be fully fueled.
| stutzman(at)stutzman.com wrote: |
Frank Stutzman |
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Fri Jun 22, 2007 12:02 pm Post subject: Wings options |
"wing options"
Hans--
I agree the hinge aileron is the way to go ,I did.
The "long range " tanks are also a good option to have. They were not
available when I got my kit. The only option then was two 12 gallon tanks in
each wing which complicated the fuel valve too much for me. The extra 6
gallons capacity is good to have.
I installed a wigwag, but instead of using a light in each wing, I wigwaged
the taxi and landing lights that are adjacent to each other.
Good luck
George May
601XL 912s---92 hours
Picture this – share your photos and you could win big!
http://www.GETREALPhotoContest.com?ocid=TXT_TAGHM&loc=us
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Fri Jun 22, 2007 12:32 pm Post subject: Re: Wings options |
I went with the hingless ailerons.
I bought the wing locker option, but am having second thoughts about installing it. Haven't closed my top skins yet, so I can still change my mind...
Went with the 15 gallon tanks - thinking cross country weekends to airports with no fuel. Mostly peace of mind.
Am considering a BRS. Might mount my battery ahead of the firewall for CG, but that's a ways in the future for me.
Probably as many different configuration ideas as there are builders
Patrick
XL/Corvair
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Jun 22, 2007 2:13 pm Post subject: Re: Wings options |
Hi
Chris from Down Under with an XL kit.
I went with the wing lockers, yes they are thinner than the thick wing HD,s, but for the small cost they make a great option available to the pilot when it comes to W&B.
I went with Long range tanks only because down here sometimes you have to buy AVGAS in 44 Gal drums at a time and what you dont take in your plane is left for the locals ( see them que up for free fuel for their cars) With the wing lockers I have seen mods to make it a spare fuel can area. Its up to you and your spacific needs, it is more money and you dont get a credit for not having the normal tanks. 2.5 hours in a Cessna cardinal ver's XL is very different so take a long look at range req Vs speed/time.
I put strobes on only because I will be flying at night ,what are you going to be using your Aircraft for? it is always an option to wire it up and decide later. I put my strobe power suppys out at the wing tip.
I also stayed with the hingless design for 2 reasons, and I am a flight engineer on big aircraft. I dont want to do aerobatics I am happy with the feel. It is also a very good talking point amongst the rest of the aero engineers at work they are amazed and roll their eyes till they look at the data from Chris H. then all agree its save simple and easy.
Horses for courses.
Chris.
hansriet
Posted: Fri Jun 22, 2007 7:45 pm Post subject: Re: Wings options |
Thank your all for your insights. This is a fantastic group.
Hans
dave.thompson(at)verizon. Guest
Posted: Sat Jun 23, 2007 10:49 am Post subject: Wings options |
I don’t know from first hand experience but… I discussed the pros and cons of the flex skin hinge and actual hinges on the ailerons with both Gus of Flycorvair and Mark Townsend of Can-Zac. The Flycorvair “Zenvair” was initially built with flex skin. They later changed out to hinges. Gus said that the hinges provided more responsiveness with less stick pressure than the flex skin. The flex skin has a tendency to want to center the stick, causing a little bit more stick pressure to move it. That’s pretty much what Mark said too. However, Mark stated that the flex skin will fly more “hands off” where the hinges requires a little more attention to the stick. He said that if you intend to fly cross country most of the time, use flex skin. If you just want to just “play around” the hinges will give you more responsiveness. Take this as second hand information. However, if you think of it, those statements make sense. I’d like to hear other opinions.
As for the long range tanks, my personal opinion is that you don’t have to fill them up every flight. If you need to save weight, make more stops. If you want to fly cross country, carry less baggage. What’s the empty weight difference of the short range tanks verses the long range tanks? The same train of thought can be used with the baggage lockers.
Guys, please correct me if I am thinking wrong.
Dave Thompson
Westminster, CA
alex_01
Posted: Sat Jun 23, 2007 1:21 pm Post subject: Re: Wings options |
hello hans
i fly a 601 xl but is was RTF from CZAW (my allready second xl) for the wing lockers you should denfintly build then they are so hand for the extra space.
If you consider a BRS the standard installation on the CZAW build planes is on the RH Front on the co pilots side. so no restrictions for baggage room
we in Germany have to use a rescue system it is compulsory for us here.
for more info please contact me.
if you install a rotax 912s you can fly approx 6hrs with the 90ltr tanks but it is nice to have more incase you can buy fuel cheap
