m.j.gregory(at)talk21.com Guest
Posted: Wed Jun 20, 2007 7:59 am Post subject: EUROPA PIP-PIN RECESS |
To all Listers
Please see the updated safety bulletin on the PFA web site – see link below.
Europa Club Safety Officer
EUROPA SAFETY ALERT UPDATE!
EUROPA SAFETY BULLETIN RAISED TO ISSUE 2 TO INCLUDE FURTHER GUIDANCE ON ACCEPTANCE DESIGNS OF PIP-PIN RECESSES IN TAILPLANES.
Europa Flight Safety Bulletin 006
carl(at)flyers.freeserve. Guest
Posted: Wed Jun 20, 2007 1:25 pm Post subject: EUROPA PIP-PIN RECESS |
Well, this really puts the cat amongst the pigeons.
I have just spent a day upgrading the pins in the tailplane torque so I could continue flying. Not the nicest job in the world (unless you are a midget)
The revised bulletin effectively grounds me.
My pip pin hole is circular as are many (its easier to make a cover for them). Since a circular hole is more "efficient" circumference wise (as opposed to a rectangle) the circumference of mine aint big enough.
PFA have advised not to modify them to meet the criteria but to wait for the revised design - oh and most importantly "Do not fly the aircraft".
For those that may have a similar problem the formula is Circumference is 3.142 x diameter. Area is 3.142 x radius squared.
Limits are
Base of recess must be more than 170 sq mm
Circumference of recess must be more than 125mm
Also recess must have at least 2 layers of bid and must have flox corners at the join with the tailplane skin.
A one inch (25mm) diameter pip pin recess fails the above criteria - Area 490sq mm - Circumference only 78mm.
What a bummer.
steven.pitt2(at)ntlworld. Guest
Posted: Wed Jun 20, 2007 1:40 pm Post subject: Europa pip-pin recess |
I have just seen the updated safety bulletin and I suspect many of us will
now find ourselves grounded as having non standard pip-pin recesses.
I have looked at the new Issue 2 and using the calculations therein have
calculated that
1) the base of the pip-pin recess needs to be at least 13mm by 13mm or a
radius of 7.35mm and
2) the top recess to the skin needs to be either a square 31.25mm each side
or a circle of 20mm radius. I suspect it is this latter dimension that is
going to ground many of us as the nicely turned circular pip-pin recesses
with built in covers are not likely to be that big.
I have just checked mine and found it to be 14.5mm radius (29mm diameter)
so I am grounded for the duration.
Also if you have used plastic fittings without covering them with two plies
of bid then this will also fail you.
Any one else picked up on this dilemma?
Steve Pitt
G-SMDH Tri gear XS with 46 hours on the clock
Posted: Wed Jun 20, 2007 1:40 pm Post subject: EUROPA PIP-PIN RECESS |
Carl
I moght be wrong but I would not have grounded you. The smaller the
circumference the stronger the hole surround?
Graham
Carl Pattinson wrote:
| Quote: | Well, this really puts the cat amongst the pigeons.
[quote] My pip pin hole is circular as are many (its easier to make a cover for
Limits are
What a bummer.
Brian Davies
Posted: Wed Jun 20, 2007 2:00 pm Post subject: EUROPA PIP-PIN RECESS |
The simplest fix would appear to be to construct a "standard recess" on the
underside of the stab in place of the drain hole. This would be stronger
than the existing construction and would not run the risk of dislodging TP6
whilst trying to undo an existing (non standard)arrangement on the top.
Brian Davies
wdaniell(at)etb.net.co Guest
Posted: Wed Jun 20, 2007 2:41 pm Post subject: EUROPA PIP-PIN RECESS |
So the "drain hole" on the underside needs to be turned into something
similar to the 'ole on the top which my fast build (ha ha) kit came with?
Posted: Wed Jun 20, 2007 4:07 pm Post subject: EUROPA PIP-PIN RECESS |
Jeremy
thanks for that,
the thing that bothers me, epoxy will not bond reliably to stainless
steel. That's why the bushes are prone to coming loose.
The only way we can get any secure bonding is by mechanical means. IOW
saw cuts, drilled dimples etc.
Graham
Jeremy Davey wrote:
Graham,
Reading between the lines (and therefore subject to the proviso that my
reading may be wrong), I interpret the directive as being about the ability
of the layup in the hole to bond to the bush, not about the effect on the
strength of the stabilator skin.
I will refrain from inferring from the directives the direction of the AAIB
investigation, although I suspect it is clear to many of us.
Jeremy
ward.t(at)xtra.co.nz Guest
Posted: Wed Jun 20, 2007 7:48 pm Post subject: EUROPA PIP-PIN RECESS |
Graham,
Tony K. conveyed some good advice when I did the sleeves. I drilled dimples or 'golfballed' the outer perimeter to increase the strength in the bond with the epoxy and rib.
Tim Ward
12 Waiwetu Street
Fendalton
Christchurch.
Ph. 64 33515166
MOB 0210640221
---- Graham Singleton <grahamsingleton(at)btinternet.com> wrote:
Jeremy
thanks for that,
Graham
Jeremy Davey wrote:
> Graham,
> Regards,
> Jeremy
rparigor(at)suffolk.lib.n Guest
Posted: Wed Jun 20, 2007 8:23 pm Post subject: EUROPA PIP-PIN RECESS |
Hello Graham
"> the thing that bothers me, epoxy will not bond reliably to stainless
| Quote: | steel. That's why the bushes are prone to coming loose.
saw cuts, drilled dimples etc."
Our accelerated stabilators had one of the inner bushings debond the first
time fitting the TT.
We took the "Europa Mutilation" route, went at the bushings from the
bottom, cut grooves and rough sanded, first ply was Redux/BID and
Redux/Flox covered in peel ply, and subsequent layers Aeropoxy.
I garbage picked a thin wall Carbon Fiber oar from a rowing skull and
connected the 2 bushings. Same procedure, Redux first ply, then Aeropoxy.
My outer bushing got drilled right through the bottom by the accelerator
with the oversize drill used for drain, thus the pip pin would not grab.
Lakeland sent me next size pip pins, but I canned the whole idea of pip
pins. I am using solid stainless cap head Allen shoulder screws
(www.mcmaster.com type in stainless shoulder screws, then socket). I
turned a threaded base which I knurled and got it stuck when reinforcing
the outer bushing joint.
For the top, I turned a smooth ID wall cup knurled on the OD, just large
enough to accept 2 seals and got it stuck. The top receptacle and bottom
threaded base is stuck well, in event the outer bushing debonded, this
would hold the stabilators in place.
I have no drain on bottom, just can see the head of cap screw that is
flush with stabilator. The 2 seals I am certain would prevent the screws
from ever backing out (also from water ingress), but I installed mini ball
nose plunger to catch a grove on the screw (incorporated in the top
receptacle)
Ron Parigoris
114.86 KB |
376 Time(s) |
90.9 KB |
378 Time(s) |
fklein(at)orcasonline.com Guest
Posted: Wed Jun 20, 2007 9:02 pm Post subject: EUROPA PIP-PIN RECESS |
Ron,
Looks like you've come up with a resourceful solution to a nasty
problem. Do you have any additional pixs to illustrate your fix?
Fred
On Wednesday, June 20, 2007, at 09:21 PM, <rparigor(at)suffolk.lib.ny.us>
wrote:
| Quote: | Hello Graham
first
Aeropoxy.
accelerator
grab.
reinforcing
large
bottom
screws
ball
receptacle)
Ron Parigoris
believed to be clean.
<IM001703.JPG><IM001711.JPG>
Posted: Wed Jun 20, 2007 9:26 pm Post subject: EUROPA PIP-PIN RECESS |
Hello Fred
"Do you have any additional pixs to illustrate your fix?"
A few more 1 of 2.
Ron Parigoris
97.27 KB |
408 Time(s) |
92.68 KB |
345 Time(s) |
Hello Fred
A few more 2 of 2.
Ron Parigoris
96.7 KB |
390 Time(s) |
90.29 KB |
366 Time(s) |
nwcmc(at)tiscali.co.uk Guest
Posted: Wed Jun 20, 2007 9:53 pm Post subject: EUROPA PIP-PIN RECESS |
According to my inspector the other reason for the shape of the recess
is to ensure the tailplane can not migrate sideways at all in the event
of the outer tube becoming disbanded. It is important that the head of
the pip pin is obstructed by the sidewall of the recess before the
locating pins could become free in the root of the tailplane. He
inspected my aircraft before this change to the bulletin and as mine
also has circular recesses he suggested that the inboard side be filled
up to ensure this would be achieved. Obviously this is now out of date
and my aircraft is grounded like many others.
Nigel Charles
Posted: Wed Jun 20, 2007 10:04 pm Post subject: EUROPA PIP-PIN RECESS |
One thing that has been suggested in the past but I haven't seen
mentioned this time is that, because the pip pins are there just to stop
the tailplanes moving outwards, it is worth making the holes in the
tubes slightly oval in a fore and aft plane. This ensures that the outer
tubes do not take any of the pitching load which might cause them to
disband.
Nigel Charles
Posted: Wed Jun 20, 2007 10:38 pm Post subject: EUROPA PIP-PIN RECESS |
Ron...a picture's worth 1000 words...thanks, and I need a few more
words:
I take it the shoulder of the screws is what penetrates the TT and
bushes, and both the CF tube and the embedded and threaded "base" you
turned help to keep the outer bush bonded in place.
Hey...it's gotta be late in NYC...go to bed!
Fred
On Wednesday, June 20, 2007, at 10:23 PM, <rparigor(at)suffolk.lib.ny.us>
wrote:
| Quote: | Hello Fred
A few more 2 of 2.
Ron Parigoris
<IM001710.JPG><IM002168.JPG>
Posted: Wed Jun 20, 2007 10:41 pm Post subject: EUROPA PIP-PIN RECESS |
Hi! Nigel
If you will forgive me I'd say it slightly different:- "slotted radially
in the top and underside of the torque tube" (less room for
misunderstanding?)
Bob Harrison
Posted: Wed Jun 20, 2007 11:20 pm Post subject: Europa pip-pin recess |
Hi guys,
I spoke to Andy Draper yesterday before the new directive was issued. He
told me it would be coming out though he didnt divulge the contents (nor did
we discuss the PFA's ongoing investigations). However I know that the PFA
are giving this matter their fullest attention and have been in in regular
contact with the AIIB.
Andy, Neville and Europa are currently working together to devise an
acceptable mod for the non standard pip pin recesses and I would guess this
will be published shortly.
Much as I am dissapointed that my upgraded Europa (Mod62) is still not
considered fit to fly, this process is in everybodys best interests and we
must accept it for ur own safety.
I would also mention the bulletin states that in the case of non compliant
pip pin recesses we should consult them (the PFA) on how to proceed. It may
be that they will clear certain designs once they have had the time to
assess them. After all, any change to the build manual design constitutes an
unapproved modification which could have unforseen consequences.
Carl P
G-LABS
pjeffers(at)talktalk.net Guest
Posted: Thu Jun 21, 2007 12:10 am Post subject: Europa pip-pin recess |
Yep!!! 4 out of five a/c I have inspected in the last few days (including
my own) are now grounded.
Pete Jeffers
karelvranken(at)hotmail.c Guest
Posted: Thu Jun 21, 2007 12:41 am Post subject: EUROPA PIP-PIN RECESS |
Nigel,
This is like treating the symptom and not the illness. The play comes from
the TP10 fixing on the torque tube. If the pip pin fixes well, the play is
tranferred on the glue of the TP6 in the foam! If there is any flutter then
you can imagine how long it will take before the TP6 comes untie.
Even with Ron's solution there is a need to eliminate the play on the
tailplanes.
I am sure Bob Harrisson is grining.
Karel Vranken
josok-e(at)ukolo.fi Guest
Posted: Thu Jun 21, 2007 12:51 am Post subject: Europa pip-pin recess |
Missed so far any talk aout the club modification: "Improved TP5 and TP6
Sleeve Retention
PFA mod 10672
Did that and trust it to very rigid.
Comments please?
Jos Okhuijsen
http://www.europaowners.org/kit600
