papadaddyo(at)tampabay.rr Guest
Posted: Tue Jun 19, 2007 5:47 pm Post subject: Batteries |
Not to start the battery wars again but has anyone installed 2 PC680 batteries and put one up front somewhere, ie. Firewall. If so, where does it fit and how is it on W&B. I know Tim has smaller batteries under his seat I believe.
Rick Leach
40397
GenGrumpy(at)aol.com Guest
Posted: Tue Jun 19, 2007 6:11 pm Post subject: Batteries |
I put 2 PC680 batteries just behind the baggage compartment bulkhead. Used 2 of Van't battery mounting boxes. Not much of a flicker on the W&B for me.
Grumpy
In a message dated 6/19/2007 8:54:33 PM Central Standard Time, papadaddyo(at)tampabay.rr.com writes:
Rick Leach
40397 |
See what's free at AOL.com.
Rick S.
Posted: Tue Jun 19, 2007 6:45 pm Post subject: Batteries |
I have two 680's but they are both in the back. Due to the weight factor I suggest you keep as much controlable weight aft of the CG. Although I have not finished mine yet, all information to date indicates a the -10 flies better with more weight aft of the CG. With the CG at the forward limit the aircraft requires more aft stick to develop a nice flare. Little flight experience but lots of reading about it. YMMV.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
bcondrey
Posted: Wed Jun 20, 2007 4:48 am Post subject: Batteries |
I have a pair of PC-680s but they are in the standard battery location (minor mod to the battery tray).
Bob #40105
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Leach
Sent: Tuesday, June 19, 2007 8:47 PM
Subject: Batteries
Rick Leach
40397
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
jwt(at)roadmapscoaching.c Guest
Posted: Thu Jun 21, 2007 8:05 pm Post subject: Batteries |
I've done exactly the same thing.
John Testement
jwt(at)roadmapscoaching.com (jwt(at)roadmapscoaching.com)
40321
Richmond, VA
Paint prep and LOTS of misc stuff
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Sent: Wednesday, June 20, 2007 8:48 AM
Subject: RE: RV10-List: Batteries
Bob #40105
Subject: RV10-List: Batteries
Rick Leach
40397
5No virus found in this incoming message. size=2>Version: 7.5.472 /
2:18 PM
john_rv10(at)yahoo.com Guest
Posted: Thu Jun 21, 2007 10:14 pm Post subject: Batteries |
Rick,
We haven’t done it yet but we are planning 2 PC680s, one up the front to crank the engine, and the second down the back for the endurance bus. We plan to follow Bob Knuckolls’ approach of changing out the cranking battery and rotating the new battery down the back to maximize life on the endurance bus battery. We have purchased the RV7 firewall mount kit and we will locate it when we have the engine hung. I would prefer to hang it on the engine side of the firewall, but if I can’t, then we will put it inside somewhere ’convenient’.
I have done several W & B calcs using the numbers other people have published for their RV 10s and I feel comfortable with the results. Being a first time builder we have gone a bit overboard with the primer on the empennage parts, which is all weight way down the back and we are looking at the light weight starter and alternators which reduces weight at the front.
John Cleary
40260
Fitting cabin top
Sent: Wednesday, 20 June 2007 11:47 AM
Subject: Batteries
Rick Leach
40397
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Fri Jun 22, 2007 9:05 am Post subject: Re: Batteries |
| bcondrey wrote: | I have a pair of PC-680s but they are in the standard battery location (minor mod to the battery tray).
Bob #40105 |
Any chance of getting a pic of your battery tray mod?
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Deems Davis
Posted: Fri Jun 22, 2007 9:24 am Post subject: Batteries |
Don;'t know about how Bob did it, but I've got 2 PC 680's, and here's a
link to 11 pics that should give you and idea how I went about it.
http://deemsrv10.com/album/Sec%2039%20Control%20System/slides/DSC02860.html
Page forward to see the rest of the pics
Deems Davis # 406
Engine & Panel Stuff
orchidman wrote:
> Bob #40105
Gary Blankenbiller
RV10 - # 40674
(N410GB reserved)
bcondrey
Posted: Fri Jun 22, 2007 9:44 am Post subject: Batteries |
Attached is my approach and I sent a series of pictures offline so as
not to clutter up the list (I think they've been posted before).
Essentially I took the easy way out and just widened the stock tray on
the non-contactor side and moved the aft angle forward a bit. I have
both contactors mounted on a piece of angle that's bolted into the stock
contactor location.
Bob #40105
86.55 KB |
470 Time(s) |
