rparigor(at)SUFFOLK.LIB.N Guest
Posted: Mon Feb 13, 2006 10:48 am Post subject: Main and E-Bus |
Anyone have pictures of what a Main Bus and E-Bus can look like?
I know what they look like on a schematic, and what B+C sells as Bus Bar
Stock which is .025" x .5" x 12" brass.
I can see if you have breakers in a row you can screw to the brass.
What if you have switches, fuses and breakers? Can you solder Faston tabs
like B+Cs Tab ground kit?
Thx.
Ron Parigoris
frank.hinde(at)hp.com Guest
Posted: Mon Feb 13, 2006 11:07 am Post subject: Main and E-Bus |
The busses really are the fuse boxes...At least mine are.
Frank
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon Feb 13, 2006 12:15 pm Post subject: Main and E-Bus |
In a message dated 2/13/06 12:51:29 PM Central Standard Time,
rparigor(at)SUFFOLK.LIB.NY.US writes:
| Quote: | Anyone have pictures of what a Main Bus and E-Bus can look like?
Hi Ron-
Here's a look at mine-
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5003
click on the foto for larger view &let me know if ya have any questions...
Mark Phillips - Columbia, TN
All-electric RV-6A, 280 hours
_________________ From The PossumWorks... |
rondefly(at)rtriano.com Guest
nuckollsr(at)cox.net Guest
Posted: Mon Feb 13, 2006 2:41 pm Post subject: Main and E-Bus |
At 06:45 PM 2/13/2006 +0000, you wrote:
If you use breakers, then they look something like
http://www.aeroelectric.com/Pictures/Breakers/Bus_Bar_Not_1.jpg
. . . except the breakers are more modern.
If you use fuse blocks, the bus bars are built into the
fuse block assembly . . .
http://www.aeroelectric.com/Pictures/Fuses/fuseblks.jpg
Nothing to build, just bolt it in and start wiring up.
| Quote: | I know what they look like on a schematic, and what B+C sells as Bus Bar
That works well for breakers . . .
| Quote: | I can see if you have breakers in a row you can screw to the brass.
yup . . .
| Quote: | What if you have switches, fuses and breakers? Can you solder Faston tabs
Perhaps you were unaware that the bus is built into the fuse
holders. Use the fuseblocks as supplied and your bus bars
are already done. They run right down the middle of the fuseblock
and you wire them with a wire to the fat screw at the end of the
fuseblock.
