rdmac(at)swbell.net Guest
Posted: Wed Jun 06, 2007 5:29 pm Post subject: Flying Question |
I need input from anyone flying the model 5, 6 or 7. I’m having a CFII at our local airport giving my flight review and he tells me that I need to fly my approach around 55mph. He says that these Kitfox’s are made to land slowly. I have found that my plane seems to do best between 60 and 65mph on base and final with full flaps and keeping the end of the runway just above the glare shield and once over the runway leveling out and holding it off, (here I’m between 45 and 50mph) till the plane decelerates and settles on to the runway. The problem here is I have all the speed options you can get on my plane and it is difficult to slow it down to a 55mph approach. I can do a 55mph approach but the only problem with that is I have to flatten out the glide and fly such a low approach. I guess what I’d like to know is what approach speed is best for the Model 7 and at what speed do you land?
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
kitfoxmike
Posted: Wed Jun 06, 2007 5:40 pm Post subject: Re: Flying Question |
I fly the 4 and what I am reading here is that you have figured out a good landing for YOUR airplane, if the CFI doesn't agree with the way YOU land your airplane, well, I would find another CFI. Sounds like he is going by what he is reading or hearing, not what is for YOUR airplane. Hope this helps. I don't think the CFI should be dictating approach speeds, he needs to be looking for safe operation, including landings. If they are controlled and not all over the place, he shouldn't be trying to change your flying skills.
kitfoxmike
Posted: Wed Jun 06, 2007 5:43 pm Post subject: Re: Flying Question |
Oh, one more thing. MY 4 flies a much better approach at 60 as well, and will flaten out as you say, if I go slower.
kirkhull(at)kc.rr.com Guest
Posted: Wed Jun 06, 2007 5:57 pm Post subject: Flying Question |
If you built your for then you wrote the pilot hand book and should tell the instructor that for your aircraft the correct is 60 to 65. unless this instructor has more experience in your type of fox he might not know what he is talking about
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Roger McConnell
Sent: Wednesday, June 06, 2007 8:25 PM
Subject: Flying Question
Float Flyr
Posted: Wed Jun 06, 2007 7:16 pm Post subject: Flying Question |
When I did my flight instruction my instructor had me do several circuits landing at different speeds. then he let me figure out what worked best.... Funny thing is it was the same speed as the other instructors teach their students to do.
[img]cid:399280903(at)07062007-184D[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
Description: |
Filesize: |
19.77 KB |
Viewed: |
620 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
tstaley(at)centurytel.net Guest
Posted: Thu Jun 07, 2007 4:19 am Post subject: Flying Question |
Roger,
The best way to figure your approach speed is to find the stall speed then apply the rule of stall times 1.2 . This is the lowest approach speed you can safely fly.
My five likes 60 to 65. I would never go lower than 60 on final.
I dont think your cfi has flown any foxes.
LeRoy
Home grass strip, room in the hanger for visitors.
flyins are welcome.
mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Thu Jun 07, 2007 4:51 am Post subject: Flying Question |
Uhh, I think that rule of thumb is stall times 1.3
Mark Scott
Elkton, MD
[quote]-------------- Original message --------------
Roger,
LeRoy
flyins are welcome.
_________________ Mark Scott
Winston-Salem, NC |
frank.phyllis(at)mindspri Guest
Posted: Thu Jun 07, 2007 5:25 am Post subject: Flying Question |
[quote]Roger,I’ve not flown my S7 yet (maybe this summer). So my comments are from the general context. For sure, when I’m in phase I of testing I will consider the following when determining my approach speed: As a CFII (SE, ME, Glider) I have experienced many pilots want to a higher than recommended approach speed. The Private Pilot PTS criteria for normal, short & soft field approaches: “Maintain a stabilized approach and recommended approach speed, or in its absence not more than 1.3 Vso” That’s near the speed most GA recommend for their aircraft. The issue is the momentum of the AC, requiring more runway (maybe not much of an issue with the Kitfox) and the added degree of exposure to injury at the higher speed if there’s an accident (always a consideration). That’s why the fatalities are so much higher for twins than single—higher approach speed. For what it’s worth. FrankN5929S7 [b]
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Thu Jun 07, 2007 5:32 am Post subject: Re: Flying Question |
You're both right.
Once upon a time, 1.2 was used as the ref number, but for a good while, 1.3 has been the accepted value. Too many people let their airspeed get slow. I use 1.3X whenever I get into a strange airplane, as it's easy to multiply against whatever is showing as stall on the airspeed indicator.
That said, the Fox is a very light airplane with a light wing loading, and there have been many low speed wind-related accidents on takeoff and landing. The cure for wind is higher airspeed. Think of it as more wind that you are in control of.
With the speed and how you describe his guidance, it sounds like the instructor believes in Cessna stabilized approaches, where things are never varied from turning final, or from the FAF. I'd suggest printing out the Kitfox accidents from the NTSB site (www.ntsb.gov) to discuss with him or go find somebody that gives instruction in a Kitfox, Champ, or similar lightly loaded taildragger.
_________________ Remember that internet advice may only be worth what you pay. |
Guy Buchanan
Posted: Thu Jun 07, 2007 6:50 am Post subject: Flying Question |
At 06:24 PM 6/6/2007, you wrote:
Quote: | I'm having a CFII at our local airport giving my flight review and
that these Kitfox's are made to land slowly.
Roger,
I know you asked for 5 - 7 owners, but I'll throw in what I
learned with my IV. When I started flying it I was rather shocked at
the high glide rate and low approach angle. I was also shocked that
the glide never seemed to steepen as you got slower. I was coming
from Cessnas and Bonanzas, both of whom have a very obvious "best
rate of glide" speed and can generate very steep descents in the
landing configuration. If I land my IV fast, (60 mph,) my landings
are long. Now, where I fly that's not a problem, because the first
turn-out is about a 1000' down and if you land short you get to taxi
nearly that whole distance. But I wanted to learn how to get down
short. (100') One way is to land slow and fairly flat, with full
flaps. I found I could land at five mph over stall, (35-40 mph,) and
get very short landings. Note, though, that this is a power-on
landing. You control your touchdown point with power. Otherwise the
only way to control it is with a slip, and I won't slip at 5 mph over
stall. (In the Bonanza and Cessna I control my touchdown point with
speed. Nose up to go slower and descend faster; nose down to go
faster and descend slower. If you pull the nose up on my IV it goes
slower, but doesn't descend any faster so you don't move the
touchdown point any closer.)
Another way to land short is slow and steep with a severe
slip. My problem with this is that I haven't determined how slow I
can go in a slip without spinning. So I slip fast (50-60) and have to
bleed speed near the ground. This results in longer landings again.
I recommend doing it your way AND doing it his way. I'd try
both, as well as fast wheel landings, minimum speed full flap
landings, full slip landings, one wheel landings, (not the nose
wheel, though,) and anything else you can think of! I've found my
Kitfox to be incredibly forgiving, with no "right" way to land.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
kitfoxmike
Posted: Thu Jun 07, 2007 7:48 am Post subject: Re: Flying Question |
Guy,
I do slips all the time, the best advice, the more you push on the stick the more you can put in the rudder, I go on feel and noise of the wind. As I get closer to the ground and start to pull back on the stick I reduce the slip aka the rudder as I get to rounding out, once in the flair I'm straight and no slip. hope this helps. I guess you can go on your negative vertical speed on the amount of slip to apply, more negative more slip.
propellerdesign(at)tele2. Guest
Posted: Thu Jun 07, 2007 7:51 am Post subject: Flying Question |
stall * 1,3 is correct now, and + half the gust factor.
Jan
rexinator(at)gmail.com Guest
Posted: Thu Jun 07, 2007 8:33 am Post subject: Flying Question |
CFI's are not infallible. To my knowledge there is no requirement for a
CFI to know the details of experimental aircraft design and their
operating parameters as part of the exams. If he is an inexperienced CFI
you may be able to inform him of the reasoning and authority you have as
a manufacturer to define operating numbers. So don't be afaird to do so.
Start out with a casual question of his experience with experimental
aircraft and be prepared to quote FARs if he hasn't educated himself on
the subject yet.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
wingnut
Posted: Thu Jun 07, 2007 9:58 am Post subject: Re: Flying Question |
My IV seems to behave differently from the rest of you. If I slow her down, she comes in steaper. At 55, the rate of descent is a little faster than at 60 but, since I'm going slower, my angle of descent is noticeably greater. In fact, I prefer to come in with a little power to open up the pattern a bit. At idle, I have to cut my down wind leg shorter than I'm comfortable with to make the runway.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
mikeperkins
Posted: Fri Jun 08, 2007 6:28 am Post subject: Re: Flying Question |
Hi Roger,
I’ve flown a Kitfox Model 1 for thirteen years, am an EAA Flight Advisor. The usual recommendation is to fly your approach at Vso times 1.3, where Vso is your stall speed (with flaps set to landing position). My Kitfox has a Vso of about 33 mph. That would make my approach speed 1.3 x 33, or 43 mph. Not coincidentally, that’s also about my best glide speed. But I don’t fly the pattern or approach that slowly – please read on.
First, why is Vso x 1.3 recommended? One reason is because it is very close to the best glide speed in case of engine failure. Another reason is because it’s the slowest you’d want to go around the pattern, giving a somewhat safe margin from stall during a 30-degree bank. Also, maintaining Vso x 1.3 is important for aircraft that fly fairly fast so that a lot of deceleration is not required over the runway – limiting the approach speed to Vso x 1.3 plus a gust-margin is important for aircraft that tend to use a good portion of the runway on landing. Keep in mind that Vso changes with landing weight and density altitude.
That having been said, there’s NO way I’d fly my Kitfox around the pattern as slow as 43 mph….or even 53 mph. First, I don’t want to grow old in the pattern. Second, I don’t want to be an impediment to other aircraft behind me. However, it’s more than just a kind consideration to fellow aviators – being really slow in the pattern is an actual safety issue. For that reason, my target pattern speed is 70 mph. I keep that speed all the way down until I begin the flare. Yes, I float a little.
If I’m going into a very short field, I modify my usual approach to fly as low as 43 mph on final plus an optional gust-margin. Even in that case, however, I would still tend to use 43 only after base leg because there’s no real advantage to fly slower until then. Even airliners fly faster speeds on approach than on final, decelerating in the pattern. I have qualms about flying the pattern and early approach at 70.
Another nice thing about a Kitfox is that it slips so nicely to burn off altitude and airspeed. I tend to fly a little high and a little fast. That way, if I have an engine failure in the pattern, I can glide to the field.
I do my final aiming adjustments by slipping or by throttle. If you don’t slip often, you might give it a try. It’s not only a good thing to learn but it can be fun. And using slips can control your landing spot very accurately. If you’re not interested in using slips, then you can still fly at say 70 around the pattern and just learn the best way to decelerate on short final by using throttle.
My thought is to find a comfortable speed you like for flying the pattern and then decelerate on short final. It just makes sense for slow-flying aircraft.
Mike Perkins
kitfoxmike
Posted: Fri Jun 08, 2007 8:00 am Post subject: Re: Flying Question |
Since we are making conversation on flying patterns, mine are what I think is necessary at the time I'm flying, meaning, if there is traffic, I'll either speed up or slow down depending. If I have to delay my down wind, I'll go to 55 and as soon as I am ready for my base, I pull up just a little and slow to 50, then, now this is really fun, I put in full rudder to the direction I'm turning and aileron and down elevator. I leterally rotate in place, very cool. If I need to speed it up I'll hit full bull and do around 120 in the downwind and base and final is around 80 with bleeding off and a major slip in the process, generally a base to final will be over the numbers about 10 ft. off very cool fun and takes the, crap this is boring, out of flying.
As far as the engine out logic, this is mine, if the engine isn't up to par don't take off. Must be why I have a Rotax 912. Have a nice day and above all, make the flying fun.
andynfultz(at)bellsouth.n Guest
Posted: Fri Jun 08, 2007 12:44 pm Post subject: Flying Question |
Kitfoxmike,
You have obviously never had a perfectly good running engine quit on you.
I don't care what you are running, you had better be prepared for it to
happen at the least opportune time. It can and will if you fly long enough.
It's a scary feeling yet very comforting to know that you can "make the
field" when it does happen.
Andy Fultz
n85ae
Posted: Tue Jun 12, 2007 6:12 am Post subject: Re: Flying Question |
Mine is a series 5 with an IO-240
I chop power on downwind, slow down to 60 set my trim, turn base,
then start slipping (60 mph) on base/final. I fly tight patterns, and
mostly don't use any flaps. I'm probably starting to get the nose up
into the serious part of the flare once I know I have runway under
me, at that point speed is dropping from the 60 I flew on final to final
plopdown around 35-40.
Any faster than 60 on final and I need to bring lunch while I wait for
touchdown.
I compensate for Cessna's, etc. By simply flying tight patterns, and slip
a lot. They're always 2 miles out on final anyway, so not really a problem.
Most CFI's will be in major pucker mode in my plane, because they
simply are not used to the nose high attitude of the plane, or the slow
speed. If the CFI does not have time in a Kitfox, or something very
similar they are really not qualified to comment on how best to fly
it in my opinion.
Somebody mentioned something about engine failure. Well mine did,
when the engine driven pump failed on my sixth test flight. I was 3000
AGL and glided about 4 miles back to the airport. I always fly with an
awareness of fields, etc, and adjust my flight path accordingly. I fly
under the O-Hare Class B a lot, and emergency landing here can mean
a subdivision (no thanks). SO my advice to the guy who mentioned
he doesn't worry about it ... Please do NOT fly over my neighborhood.
I think assuming your engine is not going to fail, is in effect assuring that
it will.
Jeff Hays
Series 5, IO-240B
kitfoxmike
Posted: Tue Jun 12, 2007 7:33 am Post subject: Re: Flying Question |
Oh, I think about the engine all the time, I just don't obsess about it. I make checks on my engine and do a preflight on the aircraft before each flight. I too make short approaches for the reason that if the engine did fail I'm close to the runway, at least that's a good excuse for doing them. Those pilots that do the 2 mile approaches are the ones that WILL have a big problem if the fan quits.
For those that try to preplan what to do if the fan quits. Try this one, pick a landing spot for a simulation, now go low and slow and check that landing spot out, might scare you. Better yet, take your land vehicle and go check out some of the spots you picked out. Big difference from picking one at 1000ft versus on the ground looking at them. Might change your perception of good landing spots. I still think landing on a road and hitting a sign or two is much better.
