rstone4(at)hot.rr.com Guest
Posted: Sun Jun 10, 2007 8:01 am Post subject: Air venting |
Does anyone know of air vents that are available to be fitted to the side of the cockpit skin to direct outside air on the pilot and passenger, I am looking for the type that have a flange on the outside to cover a rough cut opening. Metal or plastic of good quality is desired. If so, I would like to see some pictures or be directed where I can see pictures.
In trying to solve a problem of high cockpit heat, I installed heat shield materiel on the firewall and wrapped some tape around the exhaust pipes made by Thermo Tec. This reduced the amount of heat signifently, however it's still too warm for summer flying here in Central Texas
Tracy Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
Posted: Sun Jun 10, 2007 8:53 am Post subject: Air venting |
Do you mean in addition to the factory NACA vents?
How about a vent in the canopy? Spruce p/n CC3251 or 05-01179. Cut the hole by hand with a fly-cutter in under an hour. Pictures attached of a vent installed on Doug Dugger's plane.
http://www.aircraftspruce.com/pdf/2007Individual/Cat07190.pdf
-- Craig
40.45 KB |
539 Time(s) |
31.38 KB |
574 Time(s) |
32.24 KB |
537 Time(s) |
37.48 KB |
531 Time(s) |
sonar1(at)cox.net Guest
Posted: Sun Jun 10, 2007 9:14 am Post subject: air venting |
Hi Robert/Tracy Stone:
Check out Vans. They have a vent that fits in the wall, and puts a scoop
out into the slipstream. I got two, installed one, but haven't flown
with it yet.
They also have adapters for the plastic eyeballs, and cheap air hose.
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1181495301-506-117&browse=heatvent&product=10vent_kit
Fred Sanford 601XL Jab 60%
Posted: Sun Jun 10, 2007 1:21 pm Post subject: Air venting |
robert stone wrote:
*Tracy,
You can make your own channel for the inside behind a NACA opening and
add a louvered adjustable air vent out
of a GM auto for very little. They work very well so long as you
position the NACA intake at or forward of the leading
edge of the aircraft. Air vents over the wing can actually suck air
from the cabin or minimize the flow due to wing lift.
I built my own and it only takes a little time. There are commercial
equivalents, but most get into your panel with a
spherical vent. The GM vents are cylindrical and have adjustable
louvers. About $3.00 for both. See links,
http://www.macsmachine.com/images/largeassembly2/full/NACAvent.gif
http://www.macsmachine.com/images/largeassembly2/full/freshairassy.gif
http://www.macsmachine.com/images/largeassembly2/full/freshairassy2.gif
http://www.macsmachine.com/images/largeassembly2/full/outletventright.gif
http://www.macsmachine.com/images/largeassembly2/full/outletvent.gif
http://www.macsmachine.com/images/completion/full/601ezclosefrtrt.gif
Larry McFarland at www.macsmachine.com
| Quote: | Does anyone know of air vents that are available to be fitted to
Central Texas
Tracy Stone
Harker Heights, Tx
NYTerminat(at)aol.com Guest
Posted: Mon Jun 11, 2007 4:04 pm Post subject: Air venting |
Craig,
Yes, I have the factory NACA vents installed but cant get the airflow adjusted any higher than my chest. I just called Aircraft Spruce and ordered a pair of the plexiglass vents which I will install on the canopy sides so I can get cool outside air blowing right in my face. Thanks much for the information.
Tracy
Posted: Mon Jun 11, 2007 5:11 pm Post subject: Air venting |
Thank you for the compliment Bob.
It was a wonderful process, building from Zenith plans
and I really enjoyed it.
Larry
amyvega2005(at)earthlink. Guest
Posted: Tue Jun 12, 2007 10:40 am Post subject: Air venting |
eye ball vents are just not enough in the noon FLorida sun.
fderfler(at)gmail.com Guest
Posted: Tue Jun 12, 2007 3:21 pm Post subject: Air venting |
But, the NACA vent blowing up your shorts is the best angle of attack indicator money can buy. I use it to judge climb speed/angle, to set cruise configuration, and to judge final approach. Why do you want it blowing on your chest? You are losing a valuable flight instrument!
Frank Derfler AMD-Built 601XL N183AM
See my information for pilots at www.flyinflorida.com [quote][b]
