ScooterF15
Posted: Sun Jun 10, 2007 3:13 am Post subject: Fuel Leak |
I know we just had this discussion about a leaky rivet on a fuel tank. I didn't comment because I thought I was the lucky recipient of leak-free quickbuild tanks. You'll notice from the attached photo that I was not. Seeing that did not make me happy.
Last August I pressure tested my tanks using a pressure gauge from a blood pressure cuff before installing them. I pumped them up to 35 mmHG (~ 0.67 psi) and left them for 2-3 days. The pressure did not change so I figured they were good. After filling them I checked for leaks and didn't see any. I've had fuel in the tanks for 10 months and flown 85 hours. As I was washing the bugs off my wing yesterday I found this leak. I'm glad I found it before painting.
I plan on emptying the fuel from the wing and trying the Locktite 290 approach, unless someone has a better suggestion.
-Jim
40134
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
See what's free at AOL.com.
91.07 KB |
712 Time(s) |
flysrv10(at)gmail.com Guest
Posted: Sun Jun 10, 2007 3:31 am Post subject: Fuel Leak |
You are lucky that it is only leaking from the rivet. Mine QB leaked in several places resulting in much debates, head scratching and a big hole on the rear of the tank to do repairs.
The 290 WILL work. My rivet leak has held up for a year now. I would put the same amount of neg. pressure on the tank while applying the 290 and let them sit overnight.
Do not archive.
On Jun 10, 2007, at 7:12 AM, JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) wrote:
[quote] I know we just had this discussion about a leaky rivet on a fuel tank. I didn't comment because I thought I was the lucky recipient of leak-free quickbuild tanks. You'll notice from the attached photo that I was not. Seeing that did not make me happy.
-Jim
40134
See what's free at AOL.com. <IMG_4540_1.JPG>
VHMUM(at)bigpond.com Guest
Posted: Sun Jun 10, 2007 2:24 pm Post subject: Fuel Leak |
I dont know why you guys in the states just dont send your tanks back at vans expence? Several leaks on a QB tank is BS ...I mean Vans sent me a new gear leg free of charge as it was faulty.
Chris
rvbuilder(at)sausen.net Guest
Posted: Sun Jun 10, 2007 7:37 pm Post subject: Fuel Leak |
What if one of you smart MIT types *cough* figure out about how much PSI a full tank of avgas exerts while compensating for the difference in viscosity between air and avgas. Should give you a better number to use to approx the PSI of air for testing the tanks. Hopefully it will lead to more accurate leak tests.
Just a thought.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Sunday, June 10, 2007 6:12 AM
Subject: Fuel Leak
-Jim
40134
DAVELEIKAM(at)wi.rr.com Guest
Posted: Sun Jun 10, 2007 8:34 pm Post subject: Fuel Leak |
OK, I am a short way from testing my QB tanks. If I do an air pressure test, and the test fails, how will I find any leaks? Soap?
Dave Leikam
40496
QB Wings
Tim Olson
Posted: Sun Jun 10, 2007 9:46 pm Post subject: Fuel Leak |
Dave,
I'm no expert, but I actually did sleep in a Holiday Inn Express last
night, so I'll throw in my .02.
I don't consider the soapy water check a secondary check to be done
if the air pressure leakdown fails...it's more of a primary test.
I did both, at the same time. First, pressurize the tank with the
balloon attached, and then spray it with a diluted concentration
of dish soap and water with a spray bottle. Any bubbles coming
out will grow and should be easy to spot. Check EVERYWHERE.
Then, leave the balloon full and see how it is the next day. If
it is still full, you're done. If it isn't, then you probably
need to do the bubble test again, and you'll most likely find any
problem if there is one. Other than a loose rivet, the air should
leak way easier than the fuel would. If you really want to get
a the bubble test down to a fine level, use helium and that will
easily find its way out any tiny spot, but that's way overkill.
It's interesting to see how the tanks are becoming the downfall
of the QB wings. Personally, I was much much happier to build
the tanks and KNOW how they were built than I would have been
to just buy them pre-built. It would be different if you were
buying from an aftermarket tank builder who would guarantee
them, because they'd take extra pride in their work. IMHO, people
make a little too big a deal out of how awful the tank building
job is...it just isn't that bad.
Dave Leikam wrote:
| Quote: | OK, I am a short way from testing my QB tanks. If I do an air pressure
Dave Leikam
40496
QB Wings
dmaib@me.com
Posted: Sun Jun 10, 2007 10:44 pm Post subject: Fuel Leak |
You know Chris, that is a very good point. I am getting close to pressure tests and will keep this in mind.
David Maib
40559
QB Wings
On Jun 10, 2007, at 5:23 PM, The McGough Family wrote:
[quote]I dont know why you guys in the states just dont send your tanks back at vans expence? Several leaks on a QB tank is BS ....I mean Vans sent me a new gear leg free of charge as it was faulty.
Chris
[quote]---
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
ScooterF15
Posted: Mon Jun 11, 2007 2:52 am Post subject: Fuel Leak |
Wouldn't it be nice if we had someone smart enough to do that?
It doesn't take a rocket scientist to look up the vapor pressure of AVGAS (the ASTM D 910 spec lists a maximum of about 7 psi). That is a lot of pressure and that is why we have a vent line! I don't believe our tanks ever have to or could endure that amount of pressure. So, I don't think the amount of pressure makes too much difference; if there is a hole, air is going to go through it. That's why I used about 0.5 psi. In my opinion, Tim has got it right when he suggests using soapy water along with pressure from a ballon as a primary test.
Jim
40134
In a message dated 6/10/2007 11:39:47 P.M. Eastern Daylight Time, rvbuilder(at)sausen.net writes:
Just a thought.
Michael
Do not archive |
Posted: Mon Jun 11, 2007 3:36 am Post subject: Fuel Leak |
Chris, Van offered to repair my tank at no charge and will supply you with whatever you need to repair them. They do however think that a replacement tank may not fit your wing.
At the end, I think that it is quicker and less costly to repair minor leaks at home.
Chris
[quote]---
Posted: Mon Jun 11, 2007 3:37 am Post subject: Fuel Leak |
Soap.
do not archive.
On Jun 11, 2007, at 1:34 AM, Dave Leikam wrote:
[quote]OK, I am a short way from testing my QB tanks. If I do an air pressure test, and the test fails, how will I find any leaks? Soap?
Dave Leikam
40496
QB Wings
[quote]---
Posted: Mon Jun 11, 2007 4:12 am Post subject: Fuel Leak |
Tim Olson wrote:
SNIP
| Quote: | Then, leave the balloon full and see how it is the next day. If
SNIP
Keep in mind that normal changes in pressure altitude will change the
size of the balloon. Keep an eye on the local altimeter. You really
wouldn't want to spend a lot of time checking for leaks caused by a high
moving in!!!
Linn
ScooterF15
Posted: Mon Jun 11, 2007 4:54 am Post subject: Fuel Leak |
Not to mention the temperature of the tank itself. The temp inside my hangar fluctuated from 55F at night to 120F during the afternoon, that naturally changed the pressure drastically and makes it very hard determine if there is a leak. Another reason I should have used the soapy water method over the entire tank.
-Jim
In a message dated 6/11/2007 8:13:24 A.M. Eastern Daylight Time, pitts_pilot(at)bellsouth.net writes:
| Quote: | --> RV10-List message posted by: linn Walters <pitts_pilot(at)bellsouth.net>
Tim Olson wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Dave,
SNIP
SNIP
moving in!!!
Linn
Tim Olson
Posted: Mon Jun 11, 2007 5:12 am Post subject: Fuel Leak |
Yeah, I should have mentioned the atmospheric changes, sorry I
missed that. I did my leak test in our basement with a stable
temp. As for weather, you can only hope to see everything
stable. In truth, testing the tanks is kind of a big deal
that you get it right, so I would either let it stay inflated
for at least a couple days, or test them 2 or 3 days in a row.
And if you get a balloon drop, don't panic the first day unless
it drops in an hour or two....you can do the soap bubble
and balloon test many times to verify it isn't lying to you.
JSMcGrew(at)aol.com wrote:
| Quote: | Not to mention the temperature of the tank itself. The temp inside my
-Jim
Tim Olson wrote:
> Dave,
SNIP
SNIP
high
moving in!!!
Linn
See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503>.
rene(at)felker.com Guest
Posted: Mon Jun 11, 2007 5:37 am Post subject: Fuel Leak |
Ok, I will chime in. I have not filled my tanks with gas yet, so....
I used a manometer to do the testing. I did it in my garage with wide
temperature variations and changes in atmospheric conditions. On the first
tank, I set it up, marked the water level, soap tested, and then marked the
water level each morning and night for three days. Did not see any real
drop.
On the second tank, I set up the same way, but was never really able to get
a perfect seal around the filler cap Tried several methods, none worked, so
I just used the Soap. I had no problem telling where I had not sealed
around the filler.
Rene' Felker
N423CF
40322
801-721-6080
Posted: Mon Jun 11, 2007 7:00 am Post subject: Fuel Leak |
See, you smart guys jump straight to the technical aspects. I was actually thinking the physical weight of the avgas and the PSI that that amount of head pressure that would exert. It’s probably safe to assume that all bets are off with a plugged vent line.
Probably a wacky idea anyway as I slept at a Hampton Inn. J
Michael
Sent: Monday, June 11, 2007 5:49 AM
Subject: Re: Fuel Leak
Jim
40134
Just a thought.
Michael
Do not archive |
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
rnewman(at)lutron.com Guest
Posted: Mon Jun 11, 2007 1:04 pm Post subject: Fuel Leak |
So here's my take on this test. We are building a slow build version
of the RV-10 so we took this as an opportunity to test the fuel tanks as
a two part process. This gave us a chance to resolve issues in a more
forgiving maner.
Step 1: As per instructions build a tank up to the point where you
install the back baffle that closes out the tank, but don't put the
back baffle in yet.
Set the tank aside and let the pro-seal dry for a week.
(build the other tank during the down time).
After the pro-seal is curred, place the tank in a set of
jigs with the leading edge pointing down and the rear baffle area facing
up. Support tank at the rib locations (we used three plywood forms
cut to the shape of the tank profile)
Fill the tank with water just below the rivet line for
the rear baffle.
Let it set and check all the rivets in the ribs. If you
have a leak a little bead of water will form around a rivet head. Now
you can easily fix any leaks as you have full access to all the rivets
in the rib sections. (NOTE, DO NOT TRY TO DUMP OUT THE WATER, you can
bend the tank. siphon it out)
Step 2: Once satisfied that the front portion of the tank is leak
free install the rear baffle as per instructions.
Let set a week and then perform the following test:
add a few gallons of water to the tank and then set it on a set of saw
horses with the baffle side down (leading edge up). The water will
cover the entire joint assembled during the close out.
Once satisfied your done.
We did this process to both of our tanks. Then as a belts and
suspenders test. we jiged up the tanks on three saw horse and filled
them full of water up to the filler neck and let them sit for over a
week. Periodic checks of all rivets showed two leak free tanks as the
above two step process predicted.
-Bob Newman
speckter(at)comcast.net Guest
Posted: Mon Jun 11, 2007 3:28 pm Post subject: Fuel Leak |
Two things to add.
Water is a bigger molecule than avgas and while it may not leak avgas can.
Don't ask me how I know.
2nd. Drying out the tank can be difficult. Hooking a Vacuum cleaner to
the filler and taping it off, then let it run for a few days should get most
of it.
Gary
40274
dc71(at)netspace.net.au Guest
Posted: Tue Jun 12, 2007 5:50 am Post subject: Fuel Leak |
Sorry to correct this misunderstanding,
Water molecule = H2O (small)
Avgas= mixture of multiple different hydrocarbon molecules, all
larger than C4H10 (medium to large)
I'm no physicist, but my guess at the reason that Avgas leaks is
something to do with different surface tension of the two liquids. Or
possible the differing adherence to fuel tank surfaces.
Indran
avgas can.
Posted: Tue Jun 12, 2007 6:33 am Post subject: Fuel Leak |
CHEMISTRY AND ORGANIC CHEMISTRY TO BE MORE EXACT.
Do NoT ARCHIVE
| Quote: | From: Indran Chelvanayagam <dc71(at)netspace.net.au>
Date: Tue, 12 Jun 2007 21:47:30 +0800
Avgas= mixture of multiple different hydrocarbon molecules, all larger
I'm no physicist, but my guess at the reason that Avgas leaks is something
to do with different surface tension of the two liquids. Or possible the
Indran
>can.
n1345p(at)suddenlink.net Guest
Posted: Tue Jun 12, 2007 7:17 am Post subject: Fuel Leak |
While water is a smaller molecule, hydrogen bonding between molecules forms clumps of water, making water "wet", instead of dry like fuel.
http://en.wikipedia.org/wiki/Hydrogen_bond#Hydrogen_bonds_in_water
mitch
Indran
avgas can.
Learn2fly www.chickashawings.com
