zackrv8
Posted: Sun Jun 03, 2007 12:17 pm Post subject: Door Guides/Pins |
Dave has solved the magnetic pick-up problem for Van's door closed warning switch using the door guides he makes. He inserted a magnet in the "bullet" of the stainless steel door pin. This allows for the actuation of the magnetic pick-up switch when mounted on the vertical intercostal.
Notice how the door pins do not extend pass the door edge. You will never scrape your fuselage with this system! I've tried many times to close the door with just the forward latch pin and have the aft pin not latch (as many RV10's do, including Vans demonstrator). Can't happen. The door guides have a "funnel" female shape so the door pins can guide in smoothly.
If the door only partially closes, the door handle cannot be closed because the door pins hit the door guides! The door guides "rack" the door where it should go when in the closed position. Very good safety feature along with the door light switch.
Zack
18.13 KB |
472 Time(s) |
21.48 KB |
458 Time(s) |
42.5 KB |
475 Time(s) |
_________________ RV8 #80125
RV10 # 40512 |
jfrjr(at)adelphia.net Guest
Posted: Mon Jun 04, 2007 8:52 pm Post subject: Door Guides/Pins |
Zack: Remind me who "Dave" is, and where one can order his door
handle/latch system. Thanks, Jay Rowe
LarryRosen
Posted: Tue Jun 05, 2007 3:18 am Post subject: Door Guides/Pins |
Zack is related to Rivethead aka Full Throttle Concepts which you can
find on the web at <http://www.rivethead-aero.com>
In addition to what is on the web site they are working on the door
guides and door handles for the 10.
Larry
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
rvbuilder(at)sausen.net Guest
Posted: Tue Jun 05, 2007 7:56 am Post subject: Door Guides/Pins |
Dave makes some very nice products but unfortunately his website is usually way out of date (probably not the best thing with this group of Internet savvy types). Best to contact him directly for current product offerings.
Michael
