DAVELEIKAM(at)wi.rr.com Guest
Posted: Mon Jun 04, 2007 2:50 pm Post subject: wig wag HID lights |
I was told I cannot wig wag the HID lights I purchased from CreativeAir. True or False???
Dave Leikam
RV-10 40496
QB Wings
wslaughter(at)houston.rr. Guest
Posted: Mon Jun 04, 2007 3:07 pm Post subject: wig wag HID lights |
True. HID lights cannot turn on and off quickly.
William Slaughter
RV-8 Fuselage
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Monday, June 04, 2007 6:50 PM
Subject: wig wag HID lights
Dave Leikam
RV-10 40496
QB Wings
Quote: | http://www.matronics.com/Navigator?AeroElectric-List | 01234
aadamson(at)highrf.com Guest
Posted: Mon Jun 04, 2007 3:24 pm Post subject: wig wag HID lights |
CreativAir sells an HID wigwagger, whey don't you ask them?
Alan
Sent: Monday, June 04, 2007 7:50 PM
Dave Leikam
RV-10 40496
QB Wings
Posted: Mon Jun 04, 2007 3:29 pm Post subject: wig wag HID lights |
Um, hate to argue, but don't think that is true...
See - http://www.creativair.com/wigwag-flasher-halogen-lamps-p-89.html
plus I know others who routinely wigwag HID's.
Alan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Slaughter
Sent: Monday, June 04, 2007 7:07 PM
Subject: RE: wig wag HID lights
William Slaughter
RV-8 Fuselage
Dave Leikam
RV-10 40496
QB Wings
5 [quote][b]
Posted: Mon Jun 04, 2007 6:47 pm Post subject: wig wag HID lights |
I did. Thanks!
Dave Leikam
Posted: Mon Jun 04, 2007 7:13 pm Post subject: wig wag HID lights |
Bizarre Dave... Not trying to poke at you.. Seriously, they have a device on their website that is used to wig-wag HID's. I talked them them numerous times while they were in search for the 2" versions that they have and they said they were flashable. I know people who have used a simple timer circuit to flash them too....
Ah, well as an old boss of mine use to say.... "I guess the truth changed".
Sorry, done correctly (with a warm up time), they should be able to be flashed. Even XeVsion sells a flasher for theirs.
Alan
Sent: Monday, June 04, 2007 11:46 PM
Subject: Re: wig wag HID lights
I did. Thanks!
Dave Leikam
Posted: Mon Jun 04, 2007 8:34 pm Post subject: wig wag HID lights |
No problem, I just got bad info from a friend. I emailed CreativeAir the same time I posted to this list and got my answer. Thanks for all the replies.
Dave
Eric M. Jones
Posted: Tue Jun 05, 2007 6:41 pm Post subject: Re: wig wag HID lights |
Yes, no, yes, no.
I say NO you can't wig-wag HID lamps...but here are the particulars--
The Creativair device wig-wags each lamp 20 times per minute. (This is almost as slow as the message indicator in my Radio Shack telephone. It flashes once every 10 seconds. Drives me mad...) The important thing is that this is very slow and may not get the intention it deserves in the sky...
There are technically insoluble problems with wig-wagging arc lamps. The best solution seems to be to never let them go out, so restarting is not required. This is called "flash from simmer". If you flash from cold (completely off), the lifetime of the lamp AND usually the power supply is drastically shortened.
Still...the flash rate with the Creativair device is so slow maybe this is okay. Measured against the cost of a mid-air, the HID wig-wag would be preferable.
A device which works fine for many applications is a mechanical rotator (Cessnas and cops) or a wig-wagger (locomotives use them). If I had a single HID lamp in the nose, I would seriously consider it. For a halogen solution, use a high-low automotive sealed beam. Some xenon and HID auto lamps use mechanical movements to "dip" the headlights.
There are now some serious MR-16 LEDs (HUNDREDS of lumens) available on Ebay. I have a sample for playing around and will report on this later. By the end of next year the LED will look like the only choice.
They wig-wag all you like.
You can always trust the information given to you by people who are crazy; they have an access to truth not available through regular channels. -- Sheila Ballantyne
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
mprather(at)spro.net Guest
Posted: Tue Jun 05, 2007 8:15 pm Post subject: wig wag HID lights |
Hey Eric,
I have wondered about "flash from simmer" on HID's. Encouraging to hear
that it might be practical.
I also think I might consider one light system for recognition and a
separate system for nighttime ground illumination. LED/Halogen for
recognition - maybe wide angle for conspicuity and a spot HID for me to
see out. Run the wide angle lamps in steady mode while taxiing to be able
to see around corners better.
Matt-
Quote: |
<emjones(at)charter.net>
Yes, no, yes, no.
sky...
preferable.
Sheila Ballantyne
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=116793#116793
rtitsworth
Posted: Wed Jun 06, 2007 5:09 am Post subject: wig wag HID lights |
[quote] --
Description: |
Filesize: |
77.96 KB |
Viewed: |
641 Time(s) |
