dgardea(at)gmail.com
Joined: 26 Mar 2007 Posts: 50 Location: Indianapolis, IN
Posted: Sun Jun 03, 2007 6:47 pm Post subject: Zenith wing skins |
Hello 601XL kit builders .. anyone receive bottom wing skins with the tiedown slot precut to the outboard side (flange side) of rear rib #9? Of course the plans have you mounting the tiedown on the inboard side of rr #9 which makes sense. I am now faced with developing some way of mounting the tiedown by bringing it out even with the flange to match the very generous precut slot in the skin. Anyone run into this and develop a solution? Also a little odd that Zenith has chosen to predrill the spar edge of the top and bottom skins since the nose skin overlaps those skins thus rendering the pre-drilled holes kinda useless. I suppose I will try to tuck the nose skin under the top and bottom skins to try to transfer those predrilled holes to the nose skin before drilling and then move back on top to cleco. Your experience with this and solutions are appreciated.
Dave Gardea
_________________ Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html |
rsteele(at)rjsit.com Guest
Posted: Sun Jun 03, 2007 7:24 pm Post subject: Zenith wing skins |
Can't speak to the tiedown, but with regards to the skins, this is
exactly the way the current rudder kit works. Slip the nose skin
under the tail skin, drill, remove and then cleco the nose skin over
the tail skin.
Ron
On Jun 3, 2007, at 10:47 PM, dgardea(at)gmail.com wrote:
<dgardea(at)gmail.com>
appreciated.
Dave Gardea
Dave Gardea
601XL - Corvair
working on wings
http://home.comcast.net/~davegardea/
http://forums.matronics.com/viewtopic.php?p=116275#116275
Posted: Sun Jun 03, 2007 8:44 pm Post subject: Zenith wing skins |
Hi Dave,
I had to scrap my first wing because I followed the directions with
perhaps less than perfect skill. I damaged the spar cap angles by
drilling the holes in the wrong places. The original directions I
had called for magically drilling the nose skin, rear skin, and spar
cap angle all at once after building most of the wing. I solved this
problem in the next two wings by drilling the holes in the spar cap
angles first - long before installing the nose skin.
If you mark the center line of the spar cap angles and drill the rear
skin to the spar before doing anything else (except perhaps aligning
the skin with the rear ribs) then you will be sure of making these
critical holes in the right places. You can then drill the nose skin
as mentioned by inserting it between the rear skin (once it is
completely drilled and clecoed in place) and the spar. You can press
the nose skin into place using the web clamps as shown for the
elevator. When it comes time to rivet the three parts together just
position the nose skin on top of the rear skin.
Paul
XL fuselage
At 07:47 PM 6/3/2007, you wrote:
Dave Gardea
ashleyw(at)gvtc.com Guest
Posted: Mon Jun 04, 2007 2:54 am Post subject: Zenith wing skins |
Had the same problem with my skins.
I called Zenith and they approved the swapping of the ribs #9 from the right
and left wings. The tie down fits correctly if the rib flanges are inboard
instead of outboard as shown on the drawings.
Floyd Wilkes
Posted: Mon Jun 04, 2007 3:32 am Post subject: Re: Zenith wing skins |
Thanks to everyone for their quick and helpful replies!
Best regards,
Dave Gardea
dredmoody(at)cox.net Guest
Posted: Mon Jun 04, 2007 5:58 am Post subject: Zenith wing skins |
I'd convert the precut slot into an access hatch and make a new slot where it is supposed to go. First, however, make sure that you are lining the skin up properly and that the rib in question is located at the correct location. If all of that checks out, call the factory before proceeding. They may be able to spot the problem and suggest a better solution.
Dred
---- "dgardea(at)gmail.com" <dgardea(at)gmail.com> wrote:
Dave Gardea
Dave Gardea
601XL - Corvair
working on wings
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Jun 04, 2007 7:45 am Post subject: Re: Zenith wing skins |
My skins (received the kit a year ago) did not have the holes predrilled for the LE flange nor did they have the slot for the tiedown ring cut. They were, however, 18 mm short of what was called for in the drawings which resulted in having to recalculate the "Y" distances slightly when it came to trimming the wing tips (top skins). It also had a few holes located at positions other than those called for in the plans. There was nothing I couldn't deal with but it did result in a little head scratching before I felt confident to proceed.
I give ZAC credit for trying to make the process easier for us but I think sometimes they err themselves. It is important to point these problems out to them so that if need be they can make adjustments to their CNC machine. A gross error on their part would be justification to ask for a replacement.
For your problem, swapping ribs sounds like a simple solution.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Mon Jun 04, 2007 9:43 am Post subject: Re: Zenith wing skins |
Hi Tim,
Thanks for the note. I should definitely call ZAC to let them know about the tiedown mis-cut on the bottom skin as you suggest. I plan to swap the #9 ribs as you guys recommended. Floyd, glad you had called ZAC and confirmed OK to do this. Paul, thanks for the advice on the spar cap angles .. I will likely take your approach with the next wing to be sure I have adequate web clearance. What a great forum and resource! .. I posted a note late last night and had three helpful replies already by the time I left for work today!
Dave
macstar(at)raider.co.nz Guest
Posted: Mon Jun 04, 2007 11:45 am Post subject: Zenith wing skins |
I drilled the holes in the spar caps first to ensure correct spacing and
edge distance. I then used the back drill method to first pick up the rear
skin and the nose skin. The back drill method uses a tool similar to the
flange finder tool shown on www.601ch.org/tools
Just remove the flange and put a solid csk 1/8 rivet in one of the pilot
holes. This rivet is placed in the spar cap hole and you drill using the
other pilot hole as a guide hole.
Ian McClelland
601XL scratch builder
Flight controls finished. Wings 70% complete
New Zealand
