joe(at)kfiz.com Guest
Posted: Sat May 19, 2007 8:22 am Post subject: Questions |
Hi Everyone,
I have a few questions and a comment:
I'm not sure how you guys do the FAA data base searches, but is there a way
to look for something that is common to all 4 accident airplanes, such as
type of engine, 2 or 3 blade prop, wing baggage compartment, etc?
Conventional stick or mid stick? If all 4 had the same engine, is it
possible that at a certain RPM it sets up a vibration of some sort? Is it
possible to to overcontrol the airplane using a center stick? Is the
wreckage still available for inspection and can we hire someone with
credentials to go out and look at it?
Many years ago, I built a Prostar PT-2 homebuilt. The wing was simmilar to
my 601 XL with aluminum ribs and skin, roughly the same size and thickness.
The novel thing about the PT was the fact that the skin was bonded first to
the ribs with a 3M automotive type 2 face tape, then riveted with the same
kind of rivets we use! the adhesive took a mild set at first, and with age
was almost indestructable! I had to remove an inboard rib and it took me an
entire afternoon with a razor blade and laquer thinner!
So I called 3M to find out what kind of tape adhesives they have on the
market now. They have over 100 types to choose from in any thickness and
strength. They have some types that are used for aluminum construction, and
all are on a roll of 2 face tape in any width you want!
So why not use this 3M adhesive two face tape between the ribs and the wing
skin? It wouldn't change any stiffness or flexability issues with the
design, it would only hold the parts together better.
Joe in Oshkosh
601 XL
Gig Giacona
Posted: Sun May 20, 2007 9:28 am Post subject: Re: Questions |
The quick answer is it is doubtful that they all had the same engine. One was an AMD built SLSA and the other two EXP-AB.
| joe(at)kfiz.com wrote: | Hi Everyone,
credentials to go out and look at it? |
601XL Under Construction
n787xl(at)aol.com Guest
Posted: Sun May 20, 2007 4:24 pm Post subject: Questions |
Everyone
Because the 601xl has no provision to counterbalance the ailerons as 90% of the production aircraft do that use cables to actuate the ailerons, they have a fairly large danger of aileron flutter, Especially if the cables are not tight. Ref: EAA Article "Control Surface Fllutter Problems" by Tony Bingelis, Sport Aviation 7/78.
Check it out.
JES
601xl builder.
klr12(at)psu.edu Guest
Posted: Sun May 20, 2007 5:22 pm Post subject: Questions |
Then every high wing Cessna in the world, not to mention high wing
Pipers, have the same problem.
Get over it people! Stop looking for a problem that doesn't exist.
You're not building the friggin' Shuttle here!
K.L. Rupert
A&P/IA
601XL Builder
Posted: Sun May 20, 2007 6:22 pm Post subject: Questions |
KLR
High wing Cessnas are counter balanced, see back of aileron, all low wing pipers are, I can't speak to High wing Pipers. All RV's are and haven't tried to look at others. All I hope to do is to get people to look at the literature which clearly calls for balancing. If you don't want to get educated so be it.
Congrads on your A&P and IA. I will not bore you on my collection, its not necessary or cool.
JES
RV6A builder and flying
601XL builder
skyguynca
Posted: Sun May 20, 2007 8:25 pm Post subject: Questions |
I really and truely hope that is A&P/IA really isn't saying that Cessna and Piper control surfaces are not balanced! Please tell me I am misreading this post!!!!!!!!
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-224-4485
skyguynca(at)skyguynca.com (skyguynca(at)skyguynca.com)
www.skyguynca.com
Posted: Sun May 20, 2007 8:50 pm Post subject: Questions |
Scary huh!!
I think he was serious. Makes you want to build an experimental doesn't it so you can inspect your own. Thank God they are not all that way.
Unbalanced control surfaces are not good, especially when cable driven.
James Schultz
Placerville, CA
530 621-1301
TxDave
Posted: Sun May 20, 2007 10:32 pm Post subject: Re: Questions |
Gee!! I wonder how that factory demo plane has survived all these years without balanced ailerons. I guess the Heintz family has just been lucky, huh? I know...maybe we should call and warn them they're flying a death trap!
(SERIOUS SARCASM INTENDED)
"A Brief Note from Zenith Aircraft Company:
We are pleased to report that our red and white factory demonstrator Zodiac XL (N9601Z) is now six years old and has logged over 1,000 hours. The aircraft has crisscrossed the United States dozens of times through all kinds of conditions. We fly well over 300 demo flights per year in this aircraft; that's over 1,800 passengers over the last 6 years. Additionally, over 15,000 people have taken a seat in this aircraft over the years at different shows and fly-ins, as well as at the factory. The plane flies as well today as it did when it was new; we feel very fortunate being the kit manufacturer for such a fine aircraft. The fact that our demo plane still looks and performs as well as it does is a testament to the design's integrity and robustness."
Dave Clay
Posted: Mon May 21, 2007 2:25 am Post subject: Questions |
Maybe that statement was painted with too wide a brush. I was referring
to to the older ragwing Cessna's and pipers and although they are
statically balanced, they are not dynamically balanced as the newer
models are. My apologies.
KLR
skyguynca
Posted: Mon May 21, 2007 5:43 am Post subject: Questions |
I did not say the 601 had to have them, my comment was how a A&P with a IA
thinks Cessna 150, 152,172,182,205,206,210, etc doesn't have a balanced
control surface?
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-224-4485
www.skyguynca.com
rsteele(at)rjsit.com Guest
Posted: Mon May 21, 2007 6:12 pm Post subject: Questions |
(first post to this forum - working on xl rudder kit)
I'm assuming you mean the surfaces are statically balanced. Could
you describe mechanically how that works. I just flew in a 182 today
and I'll be darned if I can see how it's done. All I can think of
is a some sort of counter weight attached to the control linkage
inside the wing. This seems like an iffy way to do static balancing
as you have the slop in the control linkage that could contribute to
flutter. Other than the control linkage there is nothing that
extends forward of the aileron hinge that could account for a counter
weight.
If the you are talking about dynamic balance, I'm not real sure how
you could know how it's balanced without access to Cessna's design
and testing documents? I guess the same goes for the 601XL.
Ron
On May 21, 2007, at 9:39 AM, David Mikesell wrote:
<skyguynca(at)skyguynca.com>
with a IA thinks Cessna 150, 152,172,182,205,206,210, etc doesn't
have a balanced control surface?
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-224-4485
www.skyguynca.com
skyguynca
Posted: Mon May 21, 2007 6:48 pm Post subject: Questions |
Hi Ron,
If you take the 182 aileron and move it with the trailing edge full up and
then look inside the gap between the wing and the aileron at the lower edge
at the front of the aileron you should see a lead bar about 5/8 of a in tall
and about 1/2 wide riveted there, that is the counter balance.
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-224-4485
www.skyguynca.com
Posted: Mon May 21, 2007 7:16 pm Post subject: Questions |
Cool, I'll take a look during my next pre-flight (I'm a student).
Thanks for the reply.
Ron
Hi Ron,
up and then look inside the gap between the wing and the aileron at
the lower edge at the front of the aileron you should see a lead
bar about 5/8 of a in tall and about 1/2 wide riveted there, that
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-224-4485
www.skyguynca.com
Posted: Tue May 29, 2007 7:51 am Post subject: Questions |
Hi Everyone.
I have a few questions.
I'm up to the fuel and electrical system for my 601 XL. Why does the fuel
system tee off to the two different fuel pumps? Wouldn't it be better to go
from the gasolator to the electric fuel pump to the mechanical pump to the
engine? The parts count would be less. Is it safer to run them in paralell
like the plans call for? I've never trusted T fittings and you could
eliminate 2 of them by running them together.
What size wire are you using for different items like the fuel pump, nav
lights, battery cable, etc? I'm ordering everything I need today. I
appreciate any help. Thanks.
Anyone featuring electrical wiring on their personal WebPages with pictures?
Joe in Oshkosh
601 XL
bryanmmartin
Posted: Tue May 29, 2007 11:41 am Post subject: Questions |
A non operating fuel pump will restrict the flow of fuel to some degree.
Sucking fuel through this restriction, under some circumstances, can
lead to vapor lock. With the pumps in parallel, each pump has an
unrestricted supply of fuel and there's less chance of vapor lock.
The facet fuel pumps will run on a 5 Amp circuit so 18 AWG wire will
work. For most circuits, find out what the steady state current draw is,
add at least 50% and choose a wire and fuse appropriately. The length of
the wire run may be a factor in choosing the right size wire. (Rule of
thumb: no more than 3% voltage drop over the length of the wire.) There
are aircraft wire size calculators on the web that may help. For your
battery cable, you will probably need at least #4 wire. If the battery
is in the tail for balance purposes, you will probably need #2 wire.
Although there is no requirement to, I would recommend you use aircraft
grade Tefzel wire, at least in the cabin area. If something does short
out and burn, tefzel won't give off toxic smoke.
Joe wrote:
Hi Everyone.
fuel system tee off to the two different fuel pumps? Wouldn't it be
better to go from the gasolator to the electric fuel pump to the
mechanical pump to the engine? The parts count would be less. Is it
safer to run them in paralell like the plans call for? I've never
trusted T fittings and you could eliminate 2 of them by running them
together.
pictures?
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
Posted: Tue May 29, 2007 12:51 pm Post subject: Questions |
the rule I was told is run the tanks to the tank selector, then gascolator, then the pump.
GC cleans any debrise before going to pump.
