flight to MV-Larry C.
rp3420(at)freescale.com
PostPosted: Mon May 28, 2007 7:48 am    Post subject: flight to MV-Larry C. Reply with quote
Larry,
That is interesting that you lost airspeed by completely enclosing the fuselage? Did I read that right??
You'd think that the enclosure would clean up the aerodynamics and increase your top speed. Does anyone else have any experience or data with this? I am currently building a rear enclosure for my Firestar to help gain a faster airspeed, or will I lose airspeed from it?
Tim Gherkins
FSII
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell
Sent: Saturday, May 26, 2007 4:17 PM
Subject: flight to MV
..... . I did find after I got home and went flying with John H and W that after taking off the rear wrap around part of the enclosure that I lost about 8 MPH by having it on. I couldn't have done without it on the trip though, I needed something to hold my stuff in the plane.
Larry, Oregon
lcottrell
PostPosted: Mon May 28, 2007 11:33 am    Post subject: flight to MV-Larry C. Reply with quote
Hi,
After flying better than 2000 miles with the enclosure on the rear on the trip, I am positive it wasn't a fluke. You see when John H and W as well as Roger got here, we put in better than 6 hours flying all over the area here. Head and tail winds of course mixed. My ground speeds were 6 to 8 mph faster, and the temps were still reasonable inside with the heater on, since the air seems to be pulled back into the cone of the enclosure. I know that I can smell gas when I refuel while I fly. If it were me and I decided that I wanted a rear enclosure, I would make a serious effort to keep it as clean and aerodynamic as possible, every thing tapered to the rear, including the area at the rear of the cage. I would still do a before and after test to see if it was worth it. The picture shows how the front enclosure looks.
Larry, Oregon
[img]cid:002b01c7a15e(at)usermj5tjr71vq[/img]
 Filesize:  135.62 KB
 Viewed:  192 Time(s)
WillUribe(at)aol.com
PostPosted: Mon May 28, 2007 6:02 pm    Post subject: flight to MV-Larry C. Reply with quote
Hi Tim,
Sorry but the answer is yes, I fly slower with the full enclosure then when I fly with the half windscreen. I can't figure it out but it's true. One of my flying buddies has a Challenger with a 582. When I fly with the full enclosure I have a hard time keeping up with him but when I have the half windscreen I have no problem staying with him. He even commented he had a hard time catching up to me one time when I only had the half windscreen.
Will Uribe
FireStar II N4GU
El Paso, TX
Back home from watching, for two weeks, farm tractors being built.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Gherkins Tim-rp3420
Sent: Monday, May 28, 2007 9:48 AM
Subject: RE: flight to MV-Larry C.
Larry,
Tim Gherkins
FSII
Larry, Oregon
See what's free at AOL.com.
