bobair8(at)msn.com Guest
Posted: Thu May 24, 2007 3:50 pm Post subject: Two Circuits on One Fuse? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I'm following the AeroElectric Connection philosophy and using fuses. I have 29 circuits but only 24 tabs on my fuse block. What is the "best we know how to do" in this situation? I'd like to think that crimping two circuits into one Faston is OK but what size fuse should I use and should I match the relative current draw or pick a higher current draw circuit to pair with a lower current draw circuit? I intend not to pair similar items such as radio and transponder so that one blown fuse doesn't take down all my avionics.
Bob
GlaStar
N248BF
khorton01(at)rogers.com Guest
Posted: Thu May 24, 2007 4:30 pm Post subject: Two Circuits on One Fuse? |
On 24 May 2007, at 19:46, r falstad wrote:
| Quote: | I'm following the AeroElectric Connection philosophy and using
The fuse needs to be big enough to comfortably handle the worst case
total load that could be produced by both devices. Then, all wires
fed by that fuse need to be big enough to handle the fuse rating
without overheating. This is because a wiring fault in a single wire
could put as much current as the fuse will deliver without blowing
through that single wire.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
klehman(at)albedo.net Guest
Posted: Thu May 24, 2007 5:10 pm Post subject: Two Circuits on One Fuse? |
The fuse should be sized to protect the smallest awg wire that it
supplies. I have several circuits where a 10 amp fuse feeds two 18 awg
wires. The total current draw is less than 10 amps. If you pick a larger
fuse it can allow the wire to overheat and will not provide the intended
protection.
Ken
r falstad wrote:
| Quote: | I'm following the AeroElectric Connection philosophy and using fuses.
Bob
GlaStar
N248BF
gmcjetpilot
Posted: Fri May 25, 2007 6:50 am Post subject: Two Circuits on One Fuse? |
Dear Bobair8:
Yes you can do it and your house does it all over the place. In
fact you could gang more than two if careful.
Before Bob's concept of using modern automotive fuses, most
planes ganged circuits on one protection device, be it fuse or
circuit breaker all the time. How many small Cessna's have 30
fuses or CB's. Its a nice luxury to have an individual "fuse" for
every circuit and has obvious advantages, like when one blows
you lose one item.
However from a safety stand point you can "gang" circuits on
a fuse and it will be as safe and more practical with some
precautions. (Practical means less fuses than the space
shuttle.)
SIMPLICITY (examples)
You could put in ONLY 10 amp fuses in for all circuits and run
as many 18 awg wires and circuits you like, 1, 2 or 3 or more, if
the total is under 10 amps. This is what many planes do. So
you are just putting in bigger but fewer fuses or CB's.
However it is more than the current draw of the items you must
look at. You have to look at wire protection, which is the real
reason for the fuse or CB.
You want (must) make sure the fuse does not exceed the
wires capability.
EXAMPLE:
Say you have 3 items on one fuse and they are each 3.3 amp
with a short wire run. So 22 gage wire is enough for each
individual 3.3 amp run.
(Note: For electrical, 20 awg is a nominal min gauge just for
simplicity and durability. If wiring a large aircraft you would
use 22, 24 and even 26 awg to save weight. For data wiring,
like a transponder 22 awg is fine, making those busy plugs
easier to manage. All my humble opinion, pls no hate mail.)
So a +10 amp fuse would be fine for all three, but you might
go with say the next size up, a 15 amp fuse. Lets say one wire
shorted and the other items where off or drawing min current.
A 22 gage wire would get too hot before fuse blowing a 15 amp
fuse for my comfort (190F?). Now a 22 gauge wire will actually
fuse at 41 amps, but lets say its a "soft short" and the wire
is getting hot but the short is not great enough for the fuse
to blow? You will smell it and 190F might ignite something.
Rule of thumb: 22 awg would use 7 amp, 20 awg = 11 amps
and 18 awg = 16 amp fuses for max chassis wiring. If circuit is
for continuous voltage transmission over long distance, the
wire's current ratings are much lower than above "max.
Again this is all about wire protection than second total current.
The solution is very simple go to 18 awg wire to handle the 16A
load, so each wire at fuse rating is safe, not just the individual
load. Clearly 18 awg is over kill for 3.3 amps over a short length
but perfect for 15 amp fuse. Personally I would pick smaller loads
than 3.3 amps to gang and of course pick non "critical" items.
It's better to match similar ratings together of course,
eg, don't match 8 amps with a bunch of 1/2 amp circuits.
There is nothing keeping you from putting 3 or 4 (one) amp items
on a 5 amp fuse with 20 awg wire. However I would knock it off
at a gang of 3 my self, but there is no rule, just common sense.
CAUTION: Be sure you can lose all items in one shot from a
mission critical standpoint. Now simplify!
George ATP/CFI-II-ME/MSME
>From: Kevin Horton <khorton01(at)rogers.com (khorton01(at)rogers.com)>
| Quote: | Subject: Re: Two Circuits on One Fuse?
case total load that could be produced by both devices.
Looking for a deal? [url=http://us.rd.yahoo.com/evt=47094/*http://farechase.yahoo.com/;_ylc=X3oDMTFicDJoNDllBF9TAzk3NDA3NTg5BHBvcwMxMwRzZWMDZ3JvdXBzBHNsawNlbWFpbC1uY20-]Find great prices on flights and hotels[/url] with Yahoo! FareChase. [quote][b]
Jekyll
Posted: Fri May 25, 2007 9:17 am Post subject: Re: Two Circuits on One Fuse? |
I ganged several of my fuses. I agree with what's been said above so I'll just stay with a systems approach to add something to the topic.
You didn't say if you are using an E-bus or just a main bus. Your architecture bears on the process. First, I wouldn't gang anything I would consider appropriate for an E-bus. Those items are by definition the minimum requirements for safe continued operation. I wouldn't introduce any chance of sympathetic failure to my essential systems. Those circuits should be carefully planned to maximize reliability.
Gang only unrelated items, non essential or those with other backups:
- Gang all your internal lights and panel lights. Carry a flashlight for a backup. I carry several when night flying including a LED on a neck lanyard.
- Gang your flaps with something such as position lights. You can safely fly without either in a pinch.
- Gang intermittent items such as trim, taxi lights.
Just some ideas to ponder.
In the end, you can add to your fuse block without really adding to your fuse block. Run a single fused wire to a terminal block and run individual power runs from there using in-line fuses. Another method is to run a single wire to all CB's you may still use. In my plane, I have fuses but decided to install pullable CBs for pitch and roll trim so I could rapidly locate and turn off the trims in case of a run away condition. I ran 1 fused wire to the daisy-chained CBs. Each CB protects its down stream wires and the power run is fused and sized to feed both CBs.
George, good info.
Jekyll
N1DeltaWhiskey(at)comcast Guest
Posted: Fri May 25, 2007 2:37 pm Post subject: Two Circuits on One Fuse? |
May as well throw in a few more veggies into the soup here.
I am not a fan of "ganging," but would consider it in some cases. If one is
short several fused terminals, I would add another fuse block with a short
supply lead from the supply of the first block or direct from the firewall .
Since I would tolerate only 2-3 of these cases, I would then look for the
low current need equipment, 1-2 amps. Here's the reason. Minimum
recommended wire size is 22 ga which would be protected with a 3 amp or less
fuse. Combining a couple 1 amp devices on this 3 amp fuse would not
increase the need to upsize the wire to either device.
If the combined power need of ganged leads approached or exceeded 3 amps, I
would jump to a 5 amp fuse and change the feed wires to each device ganged
to this fuse from 22 ga to 20 ga.
Anything more than that, give me another buss. They're not expensive.
Ganging larger demand devices may be OK if there is no likelihood they will
be active at the same time, but the fuse needs to be sized to protect the
smallest wire and you must be prepared to not miss those devices in case the
are both powered at the same time and blow a fuse in the process.
Regards, Doug Windhorn
