Guy Buchanan
Posted: Sat May 19, 2007 8:37 pm Post subject: Maximum Takeoff Weight is not Gross weight..... period. |
At 02:21 PM 5/19/2007, you wrote:
| Quote: | Or you may keep reading the same old b.s. information on the issue here.
All,
As it does not appear any NEW information has come to light,
I'm going to kill this thread right here. The only exception is
definitive evidence of explicit FAA approval for a Sport Pilot to fly
an aircraft previously certificated at a weight over the prima-facie
light sport aircraft weight of 1320/1430 pounds.
Guy Buchanan, Kitfox List Moderator
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Flyersteve Guest
Posted: Mon May 21, 2007 2:32 pm Post subject: Re: Maximum Takeoff Weight is not Gross weight..... period |
Of course there will be no "new" information. The FAA has published all that you need....and spent a lot of time getting it right too.
It to bad that it took but a few aviation publications to mis-inform the flying community with wrong assumptions due to the fact that they were not familiar with http://www.aopa.org/whatsnew/regulatory/sport_rule.pdf
Unless you read and apply this to the FAR 1.1 definition you will get nowhere.
Just telling it like it is folks.....
steve
