Aileron stop 6W10-4
billsewell(at)gmail.com
PostPosted: Tue May 15, 2007 6:34 am    Post subject: Aileron stop 6W10-4 Reply with quote
My 2003 601xl wing kit came with a different type of aileron stop than that which is now being used. I have just installed the ailerons on the wings and would like to change the stops to the new design. I have pictures of the new design from the aircraft at the Zenith booth at Sun-n-Fun last month. I also have the pictures in the latest revision (06/24/05) photo assembly guide. Could someone provide me with the overall dimensions, bend locations and material thickness for this part. Also, is it riveted at both the top and bottom or just the top?
Bill Sewell
N601BZ
craig(at)craigandjean.com
PostPosted: Tue May 15, 2007 7:08 am    Post subject: Aileron stop 6W10-4 Reply with quote
A scan of section 6W10 from the March '06 plans is attached. The length (meaning width?) is given as 60, the developed length as 77. The material is .040. The 4 sections are 15, 29, 15 and 20mm long.
-- Craig
 Filesize:  101.22 KB
 Viewed:  310 Time(s)
dredmoody(at)cox.net
PostPosted: Tue May 15, 2007 8:34 am    Post subject: Aileron stop 6W10-4 Reply with quote
The drawing also answers the question about riveting the piece. It is riveted with the line of bottom rear skin to the flange rear spar channel and also to the web of the rear spar channel.
Dred
-- Craig
JohnDRead(at)aol.com
PostPosted: Tue May 15, 2007 9:14 pm    Post subject: Aileron stop 6W10-4 Reply with quote
Bill:
You should be able to download the drawings of the part from the Zenith web site.
John Read
See what's free at AOL.com.
PostPosted: Tue May 15, 2007 10:17 pm    Post subject: Aileron stop 6W10-4 Reply with quote
From where on the site? All I know of is the links off of this page which only describe the changes:
www.zenithair.com/zodiac/xl/xl-up-drawings.html
-- Craig
