dgardea(at)gmail.com
Joined: 26 Mar 2007 Posts: 50 Location: Indianapolis, IN
Posted: Mon May 14, 2007 11:14 am Post subject: 601XL outboard spar and long range tanks |
I recently picked up the wing kit at ZAC along with the long range tanks. Having completed the ailerons and flaps, I'm now moving onto the wings. Glad to be back building again as my job had put a major delay in the project for the past year. I see that the standard pre-built 601XL wing spar comes with a nose rib angle at 1490 from the root for nose rib #4. This will interfere with the back of the long range tank. I have seen a couple posts that say ZAC says this angle should be cut off .. as opposed to removed. Any advice on the best way to cut it off? I was thinking of using my dremel with a rotary wheel with scrap underneath to protect the spar. I have been unable to contact ZAC yet as their line has been busy most of the day. Any advice or previous experience on this is appreciated.
Dave Gardea
601XL - Corvair - tail done, working on wings
_________________ Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html |
Michael Valentine
Posted: Mon May 14, 2007 11:29 am Post subject: 601XL outboard spar and long range tanks |
I cut mine as close as possible with snips and then filed. I also added 2 ribs where the hat stiffener is - around 1700mm - at the end of the tank. I think this is required if you go this route.
Michael in NH
On 5/14/07, dgardea(at)gmail.com <dgardea(at)gmail.com (dgardea(at)gmail.com)> wrote:[quote] --> Zenith-List message posted by: "dgardea(at)gmail.com" <dgardea(at)gmail.com (dgardea(at)gmail.com)>
Dave Gardea
Dave Gardea
601XL - Corvair
working on wings
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon May 14, 2007 11:31 am Post subject: Re: 601XL outboard spar and long range tanks |
Cut it with anything that does not damage the underlying spar. You can even use snips although the material is a little thick and at an awkward angle. I scored mine with a cutting wheel and then grabbed it at both ends with a couple of pairs of pliers and snapped it off. I took a file to the edge to dress it.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
dredmoody(at)cox.net Guest
Posted: Mon May 14, 2007 12:24 pm Post subject: 601XL outboard spar and long range tanks |
The angle can be scored deeply with an OLFA knife then simply broken off at the score line. A little bit of filing/sanding smooth and you're ready to move on.
Dred
---- "dgardea(at)gmail.com" <dgardea(at)gmail.com> wrote:
Dave Gardea
Dave Gardea
601XL - Corvair
working on wings
http://forums.matronics.com/viewtopic.php?p=112783#112783
Posted: Mon May 14, 2007 1:06 pm Post subject: Re: 601XL outboard spar and long range tanks |
Thanks for the quick replies, guys. I appreciate the help and advice.
Dave
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Mon May 14, 2007 7:11 pm Post subject: Re: 601XL outboard spar and long range tanks |
| Michael Valentine wrote: | | I also added 2 ribs where the hat stiffener is - around 1700mm - at the end of the tank. I think this is required if you go this route. |
Where did you find that information...?
I'm just now finishing one wing, and don't recall seeing any requirement for 2 more ribs. I *think* I have the most recent drawings.
I'd sure hate to button this thing up missing a couple of wing ribs...
Patrick
601XL/Corvair
Michael Valentine
Posted: Tue May 15, 2007 7:42 am Post subject: 601XL outboard spar and long range tanks |
Patrick - I did not have the most recent designs on this one. My spar was built for 12 gallon tanks with 4 nose ribs inboard of the tank, two just outboard, another space for a 12 gallon tank, then three more ribs outboard of the second space. When I spoke with the factory about changing the spar to accomodate the longer 15 gallon tank, they said I should put 2 nose ribs outboard of the tank. There was already a hat stiffener in that location - easy to install two ribs right there.
Michael in NH
On 5/14/07, PatrickW <pwhoyt(at)yahoo.com (pwhoyt(at)yahoo.com)> wrote:[quote] --> Zenith-List message posted by: "PatrickW" <pwhoyt(at)yahoo.com (pwhoyt(at)yahoo.com)>
| Quote: | I also added 2 ribs where the hat stiffener is - around 1700mm - at the end of the tank. I think this is required if you go this route.
Patrick
601XL/Corvair
http://forums.matronics.com/viewtopic.php?p=112869#112869 [quote][b]
Tim Juhl
Posted: Tue May 15, 2007 8:30 am Post subject: Re: 601XL outboard spar and long range tanks |
When you install the 15 gallon tanks you move the rib from the position of the L that you cut off to another flange outboard of the tank. You still have 7 Nose Ribs - 3 inbd of the tank and 4 outboard.
See pix.
| Nose ribs - XL Seen from wing root |
32.61 KB |
559 Time(s) |
CFII
Champ L16A flying
Posted: Tue May 15, 2007 8:48 am Post subject: Re: 601XL outboard spar and long range tanks |
Tim,
So I will need to add a new nose rib "L" for the relocated nose rib #4? Thanks for the pic. What is the new position for the relocated nose rib #4? I could not find any reference to this in plans or assy docs, i.e., modifications of the spar/nose rib attachment points to support the long range tanks. (Maybe I did not look hard enough)
Dave
PatrickW
Posted: Tue May 15, 2007 8:52 am Post subject: Re: 601XL outboard spar and long range tanks |
| Tim Juhl wrote: | | See pix.Tim |
Gotcha. Thanks. I'm ok.
It sure is nice to have this forum to correspond with others who are doing the same thing.
Patrick
601XL/Corvair
Posted: Tue May 15, 2007 8:56 am Post subject: Re: 601XL outboard spar and long range tanks |
Pls disregard the last post .. I found the location, just the other side of the hat stiffener, on the drawing at 1750 from the spar root for the relocated nose rib #4 to support the long range tank.
Thanks for the help again, guys.
Dave Gardea
Tim Juhl
Posted: Tue May 15, 2007 9:19 am Post subject: Re: 601XL outboard spar and long range tanks |
For what it is worth - I had to add additional cork to the ends of the fuel tank to get a snug fit using the ZAC rib locations. IMPORTANT - Fitting the tank is difficult with both the #3 & 4 ribs riveted in place. In my case I didn't rivet NR4 until the tank was installed because my capacitance type fuel sender was installed on that end. If you used the standard float type you might want to hold off on riveting NR 3 until everything is fitted and the tank installed. I also had to build up some cork around the filler hole (about 5/16") to make a snug fit without pushing the skin down around the neck. See pix.
If your filler neck turns in with any difficulty at all you might want to get on the list for the "big tap" loaned out by ZAC. On one of my tanks when I hand screwed the neck in and left it for a couple of days I couldn't get it back out. The threads crossed and locked and I had to destroy the neck to remove it. If you want more info do a search of Fuel Filler Neck Woes.
| Cork sheet used to support skin around fuel filler hole - glued together with contact adhesive. |
48.53 KB |
586 Time(s) |
CFII
Champ L16A flying
