Comm antenna placement
Vern(at)teclabsinc.com
PostPosted: Mon May 14, 2007 7:37 am    Post subject: Comm antenna placement Reply with quote
Hi All,
I’m to the point of wanting to install antenna doublers in my airframe. The two options are placing one comm antenna under the rear seat and one on top of the tail cone behind the fiberglass top. Or two comm antennas under the rear seat. My aesthetic preference is for the two belly mounts. However, have those running with just belly mounted comm antennas had any problems with radio communication when talking to ground control, ATC or anyone else for that matter? In searching the archives I’ve found some discussion but not an answer to this question.
Vern Smith (#324 tail cone on:)
Tim Olson
PostPosted: Mon May 14, 2007 9:06 am    Post subject: Comm antenna placement Reply with quote
Not even the slightest problems with communications with the dual-belly
antennas.
Vern W. Smith wrote:
Hi All,
billderou(at)yahoo.com
PostPosted: Mon May 14, 2007 11:18 am    Post subject: Comm antenna placement Reply with quote
I have supervised antenna locations on two RV-10s and have measured VSWR with a thru-line wattmeter on all the COM antennas. I'll try not to get too windy, but:
Start with the transponder antenna location as it transmits at very high power and has the
most restrictions.
Minimum 3 physical feet from transponder
Max of 8.8 feet of RG400
Minimum distance to COM antenna 30"
Try to keep it somewhat away from the gear legs.
Com antenna notes :
Use RG-58 or RG-400
Bent whip on belly hidden by gear legs and set 3" inside gear legs = VSWR 2.6 (poor-
reflection from transmitter is bouncing off gear legs and flows back into antenna and
up into cable cancelling some of the transmitted wave energy)
Bent whip on belly just aft of the baggage bulkhead = VSWR 1.8 (good)
Straight antenna located between gear legs approx 8" inside = VSWR 1.6 (exceptional)
(Doesn't look as pretty but increase in range very noticeable. Additional feature is
ability to measure the height of grass.)
It is much better to locate the primary radio antenna away from the gear legs even
considering the longer cable. Backup radio will work fine with the whip antenna
located near the gear legs.
GPS antenna notes:
Easiest to locate. The GA56 antenna can be located underneath the windscreen or
somewhere on the top of the fuselage. (Not aware of ground plane requirements here but
someone else may have more information). It is an active antenna meaning it has an
amplifier that is driven from voltage traveling down the coax center wire. Note that if
you intend to get your G430 or G530 upgraded to WAAS the GA56 must be replaced
and the minimum cable length is 8 feet - so the best initial location is probably on the
upper fuselage just behind the baggage bulkhead. Locate away from the COM antennas.
Have fun,
Bill DeRouchey
WTD Aviation Technology
N939SB, flying
Tim Olson <Tim(at)MyRV10.com> wrote:
[quote]--> RV10-List message posted by: Tim Olson
antennas.
[quote] Hi All,
PostPosted: Tue May 15, 2007 10:34 am    Post subject: Comm antenna placement Reply with quote
Tim and Bill,
Thank you both for your feedback to my question. I picked up two antennas for belly mounting.
Vern (#324)
Two belly or no two belly that was the question:)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Monday, May 14, 2007 12:18 PM
Subject: Re: Comm antenna placement
Have fun,
Bill DeRouchey
N939SB, flying
antennas.
danbenua(at)yahoo.com
PostPosted: Tue May 15, 2007 10:50 am    Post subject: Comm antenna placement Reply with quote
Hi All,
My RV-6A has one Com antenna on top and one on the bottom.
There have been several times when I was on the ground and could
not contact an off-field RCO or clearance delivery using the bottom
antenna. Switching to the top antenna solved the problem.
Of course the antenna position is not the only variable. The two
antennas are of different models and connect to radios from different
manufacturers. Your mileage may vary, but on my -10 I'm putting
one up and one down.
- Dan Benua
#40001 "Finishing"
I'm to the point of wanting to install antenna doublers in my airframe.
archives I've found some discussion but not an answer to this question.
Don't pick lemons.
See all the new 2007 cars at Yahoo! Autos.
http://autos.yahoo.com/new_cars.html
coop85(at)cableone.net
PostPosted: Tue May 15, 2007 6:52 pm    Post subject: Comm antenna placement Reply with quote
Vern,
I took a little different route. I put a bent whip antenna just aft of the baggage compartment, and a $7 copper foil antenna on the roof. I figured I wasn’t out a thing to try it and it works great. It also alleviated my concern of shadowing the antenna to tower while on the ground, although I haven’t had any issues with my belly mounted antenna which I use with the primary radio.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vern W. Smith
Sent: Monday, May 14, 2007 10:37 AM
Subject: Comm antenna placement
Hi All,
sam(at)fr8dog.net
PostPosted: Tue May 15, 2007 10:12 pm    Post subject: Comm antenna placement Reply with quote
Where can I find information on the foil antenna?
Sam Marlow
Marcus Cooper wrote:
Vern,
Marcus
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Vern W. Smith
*Sent:* Monday, May 14, 2007 10:37 AM
*To:* rv10-list(at)matronics.com
*Subject:* Comm antenna placement
Hi All,
question.
ScooterF15
PostPosted: Wed May 16, 2007 1:41 am    Post subject: Comm antenna placement Reply with quote
There's a post at _http://forum.matronics.com_ (http://forum.matronics.com)
in the RV-10 list titled Low Drag VHF Antenna regarding the foil antenna I
installed just aft of the passenger side door.
_http://forum.matronics.com/viewtopic.php?t=6664_
(http://forum.matronics.com/viewtopic.php?t=6664)
-Jim
40134
(http://forum.matronics.com/viewtopic.phpt=6664&highlight=jsmcgrew&sid=e98a17dca7e4dd298739c55713db731d)
In a message dated 5/16/2007 2:14:54 A.M. Eastern Daylight Time,
sam(at)fr8dog.net writes:
Sam Marlow
Vern,
Marcus
Hi All,
question.
Jim "Scooter" McGrew
_http://www.mit.edu/~jsmcgrew_ (http://www.mit.edu/~jsmcgrew)
************************************** See what's free at http://www.aol.com
PostPosted: Wed May 16, 2007 6:37 am    Post subject: Comm antenna placement Reply with quote
I got the foil antenna from Van's. The part number info is
Comm Antenna
Part Number = AV ANTENNA, W'SCREEN
Price = $7.00
Here's a direct link:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1179326096-54-723&brow
se=avionics&product=lowdrag-antennas
Hope this helps,
Marcus
winmail.dat
 Filename:  winmail.dat
 Filesize:  4.8 KB
 Downloaded:  255 Time(s)
PostPosted: Thu May 17, 2007 6:27 am    Post subject: Comm antenna placement Reply with quote
Marcus,
Have you had a chance to compare the performance of the foil roof mount to your bent whip?
Vern (#324)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Tuesday, May 15, 2007 7:52 PM
Subject: RE: Comm antenna placement
Vern,
Marcus
[quote]http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com [b]
PostPosted: Thu May 17, 2007 4:32 pm    Post subject: Comm antenna placement Reply with quote
Vern,
I use the whip primarily as it is tied to my Garmin 480 and the foil is connected to the SL-30. I have never not been able to contact anyone on the SL-30 and therefore switch to the 480 and have used it intentionally numerous times to see how it works. During initial testing I did a number of radio checks with the tower and it sounded like they couldn’t tell the difference (I wasn’t that far away though). My primary mode is to use the bent whip setup as primary and get ATIS/talk to Unicom on the foil with great success.
I figured worst case I’d have to add another whip antenna and I’d only be out $7 plus the coax to try it.
Marcus
Sent: Thursday, May 17, 2007 9:26 AM
Marcus,
Vern (#324)
Vern,
Marcus
http://www.matronics.com/Navigator?RV10-List[/b]
http://forums.matronics.com[/b][quote][b]
0[quote]
1[quote]
2[quote]
3[quote]
4[quote]
5[quote]
6[quote]
PostPosted: Fri May 18, 2007 7:04 am    Post subject: Comm antenna placement Reply with quote
Marcus,
Thanks for sharing your findings. I know results are subjective without measuring equipment, but it is great when people are willing to say ‘hay this is what I did and these are my impressions.’ The way you use your setup sounds like it perfectly matches your needs.
Vern Smith
Sent: Thursday, May 17, 2007 5:32 PM
Vern,
Marcus
Marcus,
Vern (#324)
Vern,
Marcus
[/b]http://www.matronics.com/Navigator?RV10-List
0[quote]
1[quote]
2[quote]
3[quote]
4[quote]
5[quote]
6[quote]
7[quote]
8[quote]
9[quote]
0[quote]
1[quote]
2[quote]
