Dale Ensing
Posted: Fri Feb 10, 2006 7:00 am Post subject: VernathermRe: Varnatherm |
"There should be no reason to cover your oil cooler if you have a vernatherm."
Jeff,
It was explained to me that there is a small flow of oil thru the cooler even when the vernatherm is closed. This is to prevent the oil in the cooler from congealing which would not allow the oil to flow thru the cooler when the vernatherm does open. Partially closing off the cooler helps the non-congealing flow to do its job and subsequently helps keep the oil temp up when there is a flow thru the cooler.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
