dhkey(at)msn.com Guest
Posted: Thu May 03, 2007 6:09 pm Post subject: BiAnnual Flight Review - POH |
I need to get a bi-annual flight review, do I need to have a POH for my
plane?
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Thu May 03, 2007 6:22 pm Post subject: BiAnnual Flight Review - POH |
No...
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
John Williamson
Joined: 10 Jan 2006 Posts: 146 Location: Arlington, TX
Posted: Fri May 04, 2007 12:04 pm Post subject: Re: BiAnnual Flight Review - POH |
It's real easy to give a simple "No".
What is your reference for that answer?
_________________ John Williamson
Arlington, TX
Kolbra, 912ULS, 1640 hours
http://home.tx.rr.com/kolbrapilot |
Thom Riddle
Posted: Sat May 05, 2007 3:10 am Post subject: Re: BiAnnual Flight Review - POH |
dhkey,
Since a CFI must fly with the pilot taking the BFR he has the right (not obligation) to inspect the required aircraft paperwork. The old ARrOW acronym is an easy way to remember what paperwork is required to be legal.
A - Airworthiness certificate
R- Registration
r - Radio station license (no longer required)
O - Operator's manual (POH) for type certificated aircraft
-----or----- Operating limitations for experimental and LSAs
W - Weight and balance data
John W - You tend to be the best informed on regulations, please correct me if I am wrong on this.
Thom in Buffalo
David.Lehman
Posted: Sat May 05, 2007 8:39 am Post subject: BiAnnual Flight Review - POH |
Thom...
I'm not John W., but I know a little about this and you are correct...
The "O" may be a Pilot's Operating Handbook, or an aircraft flight manual, depending on what the Type Certificate requires... You are also correct that an experimental has Operating Limitations, attached to the Airworthiness Certificate, instead...
DVD
On 5/5/07, Thom Riddle <thomriddle(at)adelphia.net (thomriddle(at)adelphia.net)> wrote: [quote]--> Kolb-List message posted by: "Thom Riddle" < thomriddle(at)adelphia.net (thomriddle(at)adelphia.net)>
dhkey,
R- Registration
Thom in Buffalo
Posted: Sat May 05, 2007 10:40 am Post subject: BiAnnual Flight Review - POH |
Yea, it's the "O" I was having problems with. I think I'll just do it in a
172 or a 182 and keep it simple for everyone. I still need to address the
"O".
| Quote: | From: "Thom Riddle" <thomriddle(at)adelphia.net>
Reply-To: kolb-list(at)matronics.com
Subject: Re: BiAnnual Flight Review - POH
Date: Sat, 5 May 2007 04:10:39 -0700
dhkey,
R- Registration
Thom in Buffalo
http://forums.matronics.com/viewtopic.php?p=110954#110954
Thom Riddle
Posted: Sat May 05, 2007 11:58 am Post subject: Re: BiAnnual Flight Review - POH |
dhkey,
How did you get an special/experimental airworthiness certificate without Operating Limitations? I've never heard of one being issued without this. Did the inspector drop the ball? If you do have the Op Limits, then that satisfies the O part of ARrOW. You need a POH only if it is type certificated like Cessnas or an Operators Manual if it is a factory built S-LSA.
Thom in Buffalo
David.Lehman
Posted: Sat May 05, 2007 5:42 pm Post subject: BiAnnual Flight Review - POH |
Airworthiness certificates for Experimental, Restricted, Limited, etc. (not Standard) prior to sometime in the '80s didn't have operating limitations... The block on the airworthiness certificate that now references the operating limitations used to only reference a FAR... Apparently it made too much sense, so they changed it...
DVD
dhkey,
Thom in Buffalo
Posted: Sat May 05, 2007 6:11 pm Post subject: BiAnnual Flight Review - POH |
Is it enough to mark the operating limitations on the instruments or do I
need a piece of paper with them on it? Are there some operating limitations
that can't be marked on the instruments?
| Quote: | How did you get an special/experimental airworthiness certificate without
Thom Riddle
Posted: Sun May 06, 2007 3:16 am Post subject: Re: BiAnnual Flight Review - POH |
dhkey,
Operating limitations are typically a lot of words. The ones on our Allegro, for example, are two pages long. So you will see what I'm talking about, I'm attaching a copy of ours. Note that the first loaded last and vice versa.
Although these are specific for each airplane, the verbiage is much the same but not identical on many of them. So in answer to your question about putting them on the instrument panel, in a word, no. They won't typically fit and the FEDs are going to be looking for a "document" if you get ramp checked. Non-conformance to their expectations is an invitation for citation since they are not known, as a species, to be creative or individuralistic thinkers.
Thom in Buffalo
 Download |
| Filename: |
op_lim_2.PDF |
22.77 KB |
| Downloaded: |
620 Time(s) |
 Download |
| Filename: |
op_lim_1.PDF |
21.21 KB |
| Downloaded: |
595 Time(s) |
Posted: Sun May 06, 2007 4:54 am Post subject: BiAnnual Flight Review - POH |
Opps, I got one of those it says I can't fly more than a certian distance
until I fly off my time and I got night VFR put in it.
Well as long as I don't need something like a POH im fine.
