Dash Cover
scottmschmidt(at)yahoo.co
PostPosted: Fri May 04, 2007 8:23 am    Post subject: Dash Cover Reply with quote
I need to finish the dash cover. How did most of you do yours? I have been told to use Vinyl and not leather. I guess the leather will shrink. Did you glue directly to the aluminum or to some type of high density foam?
Scott Schmidt
scottmschmidt(at)yahoo.com
pitts_pilot(at)bellsouth.
PostPosted: Fri May 04, 2007 11:03 am    Post subject: Dash Cover Reply with quote
If you're talking about the glareshield, I've used speaker grill cloth. It's stretchy and stays pretty tight if you just glue down the edges.
Linn
Scott Schmidt wrote:
[quote] I need to finish the dash cover. How did most of you do yours? I have been told to use Vinyl and not leather. I guess the leather will shrink. Did you glue directly to the aluminum or to some type of high density foam?
Scott Schmidt
scottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
Jim Berry
PostPosted: Fri May 04, 2007 1:37 pm    Post subject: Re: Dash Cover Reply with quote
I just talked to Abby at Flightline Interiors about this 2 days ago, as she was getting ready to ship out my interior. She thinks a good quality leather (like hers naturally) will hold up fine. She also recommended using Weld Wood gel contact cement for glueing down all interior material, including headliner. She has a new double welt assembly covered in the material of your choice to trim out the door and rear windows which she is sending. I have not seen it yet, but she really likes it.
Jim Berry
40482 Finishing
robin1(at)mrmoisture.com
PostPosted: Fri May 04, 2007 2:44 pm    Post subject: Dash Cover Reply with quote
Jim,
When the interior is installed would you PLEASE post photos of
the inside of your -10? I can't wait to see.
Thanks in advance,
Robin
mritter509(at)msn.com
PostPosted: Fri May 04, 2007 4:07 pm    Post subject: Dash Cover Reply with quote
I used black vinyl and used double sided carpet tape to hold it down it
down.
Mark
N410MR
To: RV-10 List <rv10-list(at)matronics.com>
Subject: Dash Cover
Date: Fri, 4 May 2007 09:22:20 -0700 (PDT)
Scott Schmidt
Get a FREE Web site, company branded e-mail and more from Microsoft Office
LarryRosen
PostPosted: Fri May 04, 2007 5:10 pm    Post subject: Dash Cover Reply with quote
How did you finish the aft edge? Did you use trim or wrap the vinyl over?
Larry
it down.
Mark
N410MR
> From: Scott Schmidt <scottmschmidt(at)yahoo.com>
> Subject: Dash Cover
> high density foam?
> Scott Schmidt
Office
Larry Rosen
#40356
N205EN (reserved)
<http>
ScooterF15
PostPosted: Sat May 05, 2007 4:56 am    Post subject: Dash Cover Reply with quote
I bought Glare Shield vinyl and Glare Shield edge trim from Cleveland Aircraft Tool. http://www.cleavelandtoolstore.com/ The black vinyl has a dull finish which does not reflect the sun glare. I glued it down with 3M Super 77 and finished the exposed edges (around hand holds and defrost fan) with black Sikaflex. Pictures attached.
-Jim
40134
In a message dated 5/4/2007 12:25:21 P.M. Eastern Daylight Time, scottmschmidt(at)yahoo.com writes:
Scott Schmidt
See what's free at AOL.com.
 Filesize:  12.04 KB
 Viewed:  589 Time(s)
 Filesize:  88.43 KB
 Viewed:  626 Time(s)
dav1111(at)suddenlink.net
PostPosted: Wed May 09, 2007 2:30 am    Post subject: Dash Cover Reply with quote
Abby did my interior (minus seats) and I used her new edge trim and like everything a lot.
A picture of the headliner and edge trim can be viewed at:
http://img213.imageshack.us/my.php?image=headlinerab0.jpg
I ordered 90 feet of the edge trim from Abby at $96.00 including shipping.
I installed hinge covers using nutplates pop riveted to the cabin top, before install of the headliner, to screw on the hinge covers that I also made out of the extra headliner material. Not shown in the picture are hinge covers I also made to cover the door hinges as well. The give a pretty nice finished look and you don't have to hassle with working the headliner material completely down into the hinge recess in the cabin top. After gluing down, just cut a small X in each recess and glue down the edges.
My helper, who does upholstery used a steamer to stretch the headliner material to get a better fit around the edges and curves.
It only looks good because of his expertise, not because of my work.
Hope to see some of you at the Texas RV flyin May 26, 2007. More info is at:
http://www.vansairforce.net/tex/tex.htm
Russ Daves
N710RV - First Flight 7/28/06
KiloPapa
PostPosted: Fri May 11, 2007 8:05 am    Post subject: Dash Cover Reply with quote
How does the edge trim work? Is it attached first then the headliner tucked into it?
Kevin
40494
tail/empennage
[quote] Sent: Wednesday, May 09, 2007 3:25 AM
Subject: Re: Dash Cover
<snipped>
Russ Daves
Kevin
40494
Albert Gardner
PostPosted: Fri May 11, 2007 6:39 pm    Post subject: Dash Cover Reply with quote
It’s a flattened tube with a little bit of foam material in the center. It’s about ¾” wide as I recall or thereabouts. She’ll make it out of whatever material you want I think. It works like the baseboard on your house floor and hides the cut edge of the material it’s covering up. I made some thing similar but about 2” wide and about twice as thick to cove the rivet line at the bottom of the glass roof. Abby does excellent work.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
PostPosted: Sat May 12, 2007 2:30 am    Post subject: Dash Cover Reply with quote
Abby's edge trim is glued on after the headliner is finished. It goes on over the cut edge of the headliner to give the edge a finished look.
You can see the edge trim around the top door edge in this picture:
The covers between the left and right top door edges cover the door hinges and are screwed on via nutplates which were installed with pop rivets before the headliner was glued on. That way you don't have to worry about working the headliner down into the pockets of the door hinges, you can just X cut the fabric at the door hinge pockets and glue down the edges.
I will try and post a picture tomorrow of Abby's edge trim around the windows.
Russ Daves
N710RV - First flight 7/28/06
original message:
tucked into it?
Kevin
40494
tail/empennage
<snipped>
Russ Daves
KiloPapa
PostPosted: Sat May 12, 2007 8:00 am    Post subject: Dash Cover Reply with quote
Thanks.
Kevin
40494
tail/empennage
Kevin
40494
