Avionics Wiring: SL30/40 to PMA8000
Albert Gardner
PostPosted: Fri May 04, 2007 5:46 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
I am wiring my audio panel (PS 8000) to my Garmin SL30 and 40 and need some help.
SL30, the comm. outputs to the audio panel are labeled as follows:
Pin 14 Headphone
Pin 13 Audio Ground
Pin 8 Mic 1
Pin 7 Mic Ground
Pin 4 TxKey
PS8000, the audio panel inputs from Comm Transceiver #1 are labeled as follows:
Pin 9 Com 1 Audio Hi
Pin 10 Com 1 Lo
Pin 11 Com 1 Mic Audio Hi
Pin 12 Com 1 Mic Key
Has anyone completed this specific installation and could help out?
Also, the audio panel says ground shields at audio panel only, float other ends while the SL30 diagram has some shields grounded there and says leave other end floating.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Ted French
PostPosted: Fri May 04, 2007 6:29 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
Albert
I have this exact installation. E-mail me your address and I'll send the cad dwg in PDF format to you.
ted_french(at)telus.net
Ted French C-FXCS
RV-10 Flying
[quote] --
Ted French
RV-10 fuselage
Tim Olson
PostPosted: Fri May 04, 2007 6:32 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
Regarding the grounds, do them as the PS8000 manual shows.
The SL-30's "Headphone" is the "Audio Hi". Lots of avionics
just call the signal and ground "Hi" and "Lo", so think of
the "Com 1 Lo" as the audio signal ground. Same with the Mic.
The Com1 Mic Key should just apply a ground to your Nav/COM
pin that will cause it to transmit, when you push the PTT button
wired into your audio panel.
The attached PMA8000 wiring diagram should be almost everything
you need.
The audio panel wiring is about the most complicated in the entire
panel, and certainly can have the most wires of just about
everything. Mine is wired with dual music inputs, both switchable
to be fed from either jack as front or rear for split music
in either jack direction, and it also includes the telephone input,
and I filled up the audio inputs. It also has Karoke mode, and
the muting override, so it's pretty much a complete install.
Can't go without karoke, so you can yell to the music....and with
headphones, your passengers can't even hear you. Wink
Tim Olson - RV-10 N104CD
some help.
Pin 14 Headphone
Pin 13 Audio Ground
Pin 8 Mic 1
Pin 7 Mic Ground
Pin 4 TxKey
follows:
Pin 10 Com 1 Lo
Albert Gardner
Yuma, AZ
PMA8000_Wire.pdf
 Filename:  PMA8000_Wire.pdf
 Filesize:  204.41 KB
 Downloaded:  459 Time(s)
Albert Gardner
PostPosted: Fri May 04, 2007 7:32 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
Hey thanks Ted.
ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Albert Gardner
PostPosted: Fri May 04, 2007 8:29 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
Thanks Tim. My confusion is over the fact that there are 5 pins in the SL30 and only 4 in the PMA8000 for the Com 1 radio.
I think the solution is to run both the SL30's pin 13 (audio ground) and pin 7 (mic ground) to the PMA8000 pin 10 (com 1 lo).
Albert Gardner
Yuma, AZ (
RV-9A N872RV
RV-10 N991RV
Tim Olson
PostPosted: Fri May 04, 2007 9:03 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
Page 19 of the SL-30 manual shows something similar when wiring to an
LS-10/15 audio panel so I see no problem there.
Albert Gardner
Yuma, AZ (
 Filesize:  67.25 KB
 Viewed:  403 Time(s)
Albert Gardner
PostPosted: Mon May 07, 2007 6:02 am    Post subject: Avionics Wiring: SL30/40 to PMA8000 Reply with quote
Many thanks to Ted and Tim for the wiring info. Ted's diagram answers a lot
of questions for wiring this particular setup.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
