W&B
by0ung(at)brigham.net
PostPosted: Tue May 01, 2007 6:22 am    Post subject: W&B Reply with quote
Been working off line with Robert Laird on his W&B and come up with a
small spread sheet that will calculate the exact arm for the pilot, fuel, or
any other item added to a plane.... no more guessing at the location of
the belly button or calculating the center of mass of the fuel tanks
etc...
The spread sheet is not been made to look real purdy,,,,, but it works.
I put in some example numbers to test functionally .... you can erase the
test numbers and save it or duplicate it in a format that is better thought
out.
Boyd
W&B_kolb-pilot-arm.xls
 Filename:  W&B_kolb-pilot-arm.xls
 Filesize:  8.5 KB
 Downloaded:  275 Time(s)
rlaird
PostPosted: Tue May 01, 2007 6:56 am    Post subject: W&B Reply with quote
Ok, now that I've got the w&b done, who's got a MkIIIC POH that I can borrow (in Word format, if possible).
Thanks!
-- Robert
On 5/1/07, boyd <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote:[quote]Been working off line with Robert Laird on his W&B and come up with a
etc...
out.
Boyd
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
Michael Sharp
PostPosted: Tue May 01, 2007 7:38 am    Post subject: W&B Reply with quote
Robert,
I asked for a POH several years ago and the consensus at that time was that no one had one. Hopefully that has changed, If one showes up please post it to the group...
Robert Laird <rlaird(at)cavediver.com> wrote:
[quote]Ok, now that I've got the w&b done, who's got a MkIIIC POH that I can borrow (in Word format, if possible).
Thanks!
-- Robert
On 5/1/07, boyd <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote: [quote]Been working off line with Robert Laird on his W&B and come up with a
small spread sheet [quote][b]
The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
rlaird
PostPosted: Tue May 01, 2007 8:11 am    Post subject: W&B Reply with quote
Ok, I will.
And if one doesn't show up, I'll take the POH I wrote a few years ago for an Aventura II and re-write it for the Kolb, and post it. I'm at a bit of a disadvantage, though, since I don't have -any- Kolb documentation, plans, schematics, etc.
-- Robert
On 5/1/07, Michael Sharp <kolbdriver(at)mlsharp.com (kolbdriver(at)mlsharp.com)> wrote:[quote] Robert,
Thanks!
-- Robert
On 5/1/07, boyd < by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote: [quote]Been working off line with Robert Laird on his W&B and come up with a
small spread sheet [quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com [quote][b]
Robert Laird
Houston, TX area
