czechsix(at)juno.com Guest
Posted: Thu Feb 09, 2006 6:09 am Post subject: O-360/CS full power fuel flow |
Guys,
For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can anybody tell me what fuel flow they see at full takeoff power / 2700 rpm / mixture rich? The Lycoming manual shows about 15 gph at full power, but the engine break-in documentation that came from Aerosport Power shows something like 22 gph at max power. That's a pretty big discrepancy. Curious if anybody can verify one number or the other...
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D, FAA inspection tomorrow with first flight as soon as the wx cooperates....
Guys,
--Mark Navratil
Cedar Rapids, Iowa
DOUGPFLYRV(at)aol.com Guest
Posted: Thu Feb 09, 2006 6:31 am Post subject: O-360/CS full power fuel flow |
The last time I noticed I was burning about 20 GPH on take off.
Doug Preston
RV-7
DO NOT ARCHIVE
lors01(at)msn.com Guest
Posted: Thu Feb 09, 2006 7:15 am Post subject: O-360/CS full power fuel flow |
I like to keep records on these numbers myself. EAA published an extensive test (including fuel flow numbers) on different exhaust systems and the test horse was the IO - 360. The max power fuel flow was always in the neighborhood of 20 - 21 GPH. The 180 HP O - 360 would burn proportionally less (about 18 - 19 GPH at max power) but 15 GPH at 180 HP is somewhat optimistic I think. Running the engine rich during break-in would easily put it in the 22 GPH area.
My Mazda rotary makes about 200 HP at 7000 rpm and burns about 20 GPH. What a coincidence!
The BSFC of most any piston (or rotary) engine improves when tested at less than max power. It takes less than half the fuel to make half the HP, especially when leaning the mixture aggressively.
Tracy Crook
rv8a2001(at)yahoo.com Guest
Posted: Thu Feb 09, 2006 7:23 am Post subject: O-360/CS full power fuel flow |
On a 180 HP engine that is too much according to Mahlon on the Lycoming list. Matter of fact I would ask this question on the Lycoming list. If I remember correctly a 180 hp engine is approx 15~17, a 200 hp enigne is about approx 18~20. I have a modifed engine which puts out 190~195 hp and I see 18.7~19.3. OAT can make a good .5 GPH differnece.
Doug Preston
RV-7
DO NOT ARCHIVE
Scott Bilinski
RV-8a
cell 858-395-5094
Vanremog(at)aol.com Guest
Posted: Thu Feb 09, 2006 7:48 am Post subject: O-360/CS full power fuel flow |
In a message dated 2/9/2006 6:11:28 A.M. Pacific Standard Time,
czechsix(at)juno.com writes:
15-16 gph is what I see routinely at take off at my field on my 0-360 c/s
WFO at 400 ft MSL. 8.2-8.4 gph is what I see leaned out at 65%.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA)
khorton01(at)rogers.com Guest
Posted: Thu Feb 09, 2006 7:55 am Post subject: O-360/CS full power fuel flow |
On 9 Feb 2006, at 14:06, czechsix(at)juno.com wrote:
Guys,
Mark,
If you are looking at Figure 3-34 in the Lycoming Operator's Manual,
it is labelled "Minimum Allowable Fuel Flow". There is nothing wrong
with having a higher fuel flow than that, as long as the engine runs
smoothly.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Thu Feb 09, 2006 8:04 am Post subject: O-360/CS full power fuel flow |
The numbers I gave are from memory from about a year ago, they were posted by Mahlon from Mattituc. Maybe I am off a gallon on the low side but I think close. Again you want real answers from someone who has run hundreds of engines on the dyno, then post this question on the Lycoming list and Mahlon will answer it with real numbers.
Tracy Crook
randy(at)romeolima.com Guest
Posted: Thu Feb 09, 2006 8:52 am Post subject: O-360/CS full power fuel flow |
| Quote: | For those of you with a 180 HP O-360, CS prop, and fuel flowmeter.....can
16-17 gph for mine. Almost always read 16.5 when taking off from near sea
level. I would imagine jetting could change this figure when running at full
rich mixture. If someone is burning 19-20 gph their main jets may be too
large.
Randy Lervold
dan.beadle(at)inclinesoft Guest
Posted: Thu Feb 09, 2006 8:58 am Post subject: O-360/CS full power fuel flow |
These numbers seem about right. Rule of thumb is about 10HP / Gallon when
at best power (100 degrees rich). Varies by engine type, but generally
within 10%
Kellym
Posted: Thu Feb 09, 2006 9:43 am Post subject: O-360/CS full power fuel flow |
A related question. Does anyone know if the standard certified
carburetor for the Lyc. O-360 has a power enrichment circuit(for full
throttle enrichement)?
If so, I would think that as soon as you reduced throttle 1/2 inch for
cruise the EGTs would rise noticeably. Can anyone confirm that?
Quoting scott bilinski <rv8a2001(at)yahoo.com>:
KCHD |
mstewart(at)iss.net Guest
Posted: Thu Feb 09, 2006 11:48 am Post subject: O-360/CS full power fuel flow |
18 for me at sea level.
~17 at 1000'
Mike
alexpeterson(at)earthlink Guest
Posted: Thu Feb 09, 2006 6:28 pm Post subject: O-360/CS full power fuel flow |
Guys,
--Mark Navratil
Mark, the 22 sounds quite high. Mine runs at about 16 or so at 1000msl, and
many others have reported similar results in past threads on this subject.
Don Rivera (designer of the Airflow Performance system) has indicated to me
that 17 or so is correct for a 180hp at sea level (I'll have to note the
flow next time I'm at sea level, which will be Sun-n-Fun in April).
There are some extremely good articles about engine management written by
John Deakin on www.avweb.com. They are not necessarily easy reading, so
plan on spending some serious time studying them.
The one number I've not been able to directly find yet is the specific fuel
consumption desired for a full throttle sea level condition. Clearly, at
this full rich setting, excess fuel is desired to modify the combustion to
eliminate detonation and to run cooler. My 16 gph at 1000msl would work out
to be about .57 lb/hp/hr (sfc, specific fuel consumption). Best power is
around .51, while best economy is around .4. 22gph would be .73 lb/hp/hr.
Does anyone know the desired sfc for full throttle, sea level power?
Alex Peterson
RV6-A N66AP 712 hours
Maple Grove, MN
