n103md(at)yahoo.com Guest
Posted: Fri Apr 27, 2007 1:10 pm Post subject: 12v supply to stabilize avionics |
I am purchasing a 12V power supply that takes
6-24V input and gives 12V out at up to 14 A continuous.
It's a 95% efficient switcher with a quiescent current
around 10mA. We need to buy ten of them to get a
better price (about $55).
Why do I want one? Why might you want one?
I have a 1-battery airplane and don't want to rewire the
whole thing. The GPS and radios reboot if they are on when
I start the engine. During cranking, the bus voltage drops
to around 10 V, and the avionics brown out. I want that
problem to go away, and also want to keep the radio working
for a while if the alternator shuts down and the battery drains
below 10V.
So, the solution I am trying is a switching power supply that
converts anything between 6 and 24 V in to a stabilized 12V out.
with 95% efficiency, the lost power is minimal. We would like to
buy 10 units for about $55 each (+ s/h). We've accounted for
four units, so there will be six more available. Who wants one?
-bob mackey
n103md -at- yahoo.com
rjquillin(at)gmail.com Guest
Posted: Fri Apr 27, 2007 2:01 pm Post subject: 12v supply to stabilize avionics |
At 14:09 4/27/2007, you wrote:
| Quote: | So, the solution I am trying is a switching power supply that
Could you forward some additional technical specs on the unit?
tnx
mprather(at)spro.net Guest
Posted: Fri Apr 27, 2007 3:43 pm Post subject: 12v supply to stabilize avionics |
Based on previous discussions, seems like return on investment won't be
good...
When battery only (dead alternator), once the battery is down to ~11v
there's very little usable energy left. Adding the regulated supply
wouldn't likely added but possibly a moment of additional system operation
- the input voltage will sag very quickly. You might actually lose
operating time because of the (small) inefficiency in the supply.
To buffer the brownout condition, you might consider a couple of ideas..
A diode (or relay) and a "largish" cap would protect against brownouts of
relatively short duration (while the starter is cranking). You might also
look at your wiring and take a few measurements of system voltages (at the
battery, and at the buss) while cranking (scope plots would be ideal).
Depending on how your buss gets power, and your ground routing, you might
not be getting the highest possible voltage to the radios while cranking.
A little rewiring might take care of most of the problem..
Let me know if you are interested in how to wire up a diode/relay and cap
to reduce the impact of brownouts..
Matt-
below 10V.
-bob mackey
gmcjetpilot
Posted: Sat Apr 28, 2007 1:34 am Post subject: 12v supply to stabilize avionics |
That is a hard to believe price for that power supply.
What about weight?
What if it fails?
Why not as suggested use a capacitor and diode?
How about turn the avionics off during start with a avionics master switch?
How about a more efficient starter (NL skytec), bigger starter wire and stronger battery?
Good luck but sounds like more complication than necessary. Of course the aeroelectric way is more complication and weight, always good.
George
>Subject: 12v supply to stabilize avionics
| Quote: | From: "bob mackey" <n103md(at)yahoo.com>
| Quote: | 6-24V input and gives 12V out at up to 14 A continuous.
Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
nuckollsr(at)cox.net Guest
Posted: Sat Apr 28, 2007 8:36 am Post subject: 12v supply to stabilize avionics |
At 02:32 AM 4/28/2007 -0700, you wrote:
| Quote: | That is a hard to believe price for that power supply.
Agreed
What about weight?
Devices like this don't need to be "heavy". With
some of the new high frequency, boost-buck topology
supplies available, this device could weigh under
a pound.
Single points of failure for lots of things
running downstream is a consideration.
The ability of a capacitor to support a load is
bounded by the relationship . . .
A V
F S
This says Amps per Farad equals Volts per Second.
Assuming "brownout" is defined a duration that a
battery is under 9 volts, the time is rather short
. . . on the order of 200 milliseconds or so. See:
Here's a battery trace on an engine with a PM
starter who's inrush drags the battery down to
7.5 volts. In 200 milliseconds, the engine speed
is up high enough to allow battery to rise to
9 volts or more. Note that "cranking" is happening
at about 10 volts. We can see that the engine starts
on the third cylinder compression after a total
cranking duration of 500 milliseconds.
So assume you have a capacitor charged to battery
voltage (12.5 according to our trace) minus a diode
drop so we're going to start out at about 11.7 volts.
Assume a brownout protected load of 1A. We want to
limit the voltage sag to 1.7 volts for 500 mS plus
headroom - lets say 1 second. One of those auto
super audio system monster caps is readily
available in 1 Farad sizes. 1 Farad will drop 1
volt per second with our 1 A load. A 1 Farad
capacitor would support about 1.7 amps for
1 second to keep the sag under 1.7 volts.
If you have lighter loads, then the capacitor
can get smaller. Assume a couple of solid state
electro-whizzies at perhaps .2A each for total
of 0.4A. A 1.7 volt sag over one second at
0.4A calls for about 250,000 microfarads.
We're talking pretty BIG hunks of hardware here.
There are other considerations about connecting
large capacitors across a battery fed bus . . . big
inrush currents. When you purchase one of those
1F capacitors (about 3" diameter, 10" long)
the installation instructions suggest charging
the capacitor through a resistor before connecting
it directly to the battery.
Now, if one chooses to diode isolate an e-bus,
then the diode is already in place. But the
pre-start interval where lots of things are
already powered up puts a load on the battery
that may have you starting out at less than
12.5 volts hypothesized above. Further,
the trace shows BATTERY voltage. There
are small but perhaps significant drops elsewhere
to consider.
Obviously, one can stir the design goals.
Perhaps you can live with a half second brown
out buffer. The size of the capacitor goes down
by half.
Hmmmm . . . perhaps the diode isolated
capacitor is not very practical for loads of
more than 100 mA or so.
Okay, you could put the stabilizing supply
in series with the e-bus isolation diode. This
leaves you with the e-bus alternate feed path
to back up a possible failure of the stabilization
supply. But I'd want to do more study about the
potential for other problems should the e-bus
alternate feed switch get closed during normal
operations . . . you don't want to close a loop
that causes the stabilization supply to attempt
to charge the battery with the battery's own
output.
A stabilization supply is going to be lighter
and smaller than a monster capacitor that will
never have the sag-mitigation capabilities of
the stabilization supply. How about a small,
SVLA battery that would support the e-bus during
cranking. A 2 a.h. battery connected to one of
the e-bus fuses and controlled from a switch
on the panel would be a stone-simple means for
providing e-bus support during start-up brownout
offers a low risk means by which one avoids
disappointing results from more complex approaches.
How about a battery pak of 8 d-size alkaline
cells that are relay connected to an e-bus fuse
when you hit the starter button. Alkalines have
VERY long self lives, they're only needed a few
seconds per flight cycle. The eliminate any
need to worry about charging or extraordinary
maintenance. You would throw a new d-pak in on
condition . . . i.e. the first time it failed
to cover the brown out. Sound's pretty
attractive to me. It puts nothing in series
with your e-bus loads and loss of performance
does not impact any flight condition.
The point of this dissertation is not so much
to champion or trash any given approach. It's
intended to be an illumination of the duties that
engineers have to fully understand the statics and
dynamics of their ideas as they impact design
goals. It's not intended to discourage experimentation.
It would be a good thing if 10 folks got together
and tried the brown-out protection scheme being
proposed. My role here is only to shine the
light around and help identify things lurking
out there in the dark that one needs to be
watchful for during the experiment. But finally,
how ever the experiment comes out, publish your
findings here on the List. Letting folks know
what does not work is more valuable some times
that limiting your postings to things that
do work.
The 'complexity' arises not so much from amount
or kinds of hardware used but from a need to
identify, study and understand the system dynamics
as it affects design goals. I'm working a problem
now that arose from a hip-shot decision of a tiny
detail of a major system change that has cost us
about $100K a year for the last six years dealing
with the fallout. It took six years for the
pressure gauge to reach a point that someone of
authority says we need to do something about it . . .
which leaves others wailing about the $200K and
6-10 months it's going to take to certify a fix
that should never have been needed in the first
place.
If the issue is simply that some electro-whizzies
reboot due to the brownout event, why turn them off?
There is no study I'm aware of that shows any
starter to be more "efficient" than another starter.
Such claims are made but unsupported in the 4-color
brochures for all the popular products offered.
In fact, efficiency of a starter (h.p. out for watts
consumed) is the last of our concerns for optimizing
system functionality. It's how fast the engine gets
started. If I could trade a 50% loss of absolute
efficiency for a 50% drop in cranking time, I'd do
it in a heartbeat.
The starter feature under discussion here is locked-
rotor current or inrush. It's a given that for starters
of about the same size, the series wound starter will
have lower inrush currents than a PM starter. This
is a hard fact that drove B&C's decision to say with
their original philosophy. While others (most notably
the automotive industry) were rapidly embracing PM
starters for lower cost, we knew that aviation was not
so much driven by absolute cost as it was by performance
delivered for cost.
Until someone is ready to fund an apples for apples
comparison of the various starters and quantify their
relative performance numbers, the gold-plated,
bright shining claims to market superiority of any
electrical feature are to be taken with a grain
of sand. Pontiac has touted a "new wider look" since
I was a kid. If they were really meeting their marketing
claims claims, you'd need a wide load permit by now
just to drive one.
| Quote: | bigger starter wire and stronger battery?
Certainly worth considering . . . but that
inrush can be 1000 amps! Remember folks, we're
talking about techniques to mitigate an event
that lasts for less than one second per flight cycle.
The obvious, low cost, maximum efficiency, minimum
risk, minimum weight approach is to develop
a operating procedure work-around and leave the
hardware alone.
Every other approach offers a requirement to
deduce, understand, consider and then fit every
new system integration problem into the design
goals for the airplane. There can be a lot more
to the task than plug-play-and-pretend that
we've done a good thing. Man! when I think of all
those whippy new products I could have brought
to market with the $600K that went down the
tubes . . .
Agreed.
| Quote: | Of course the aeroelectric way is more complication and weight, always good.
Please describe any modification you would make to any
suggestion in the 'Connection that would reduce
weight and/or complexity. Describe also what features
of the design goals for that suggestion one
should be willing to give up in exchange for
the perceived reduction in weight or complexity.
If your claim is accurate, then a substantiation
dissertation of underlying simple-ideas would be
much appreciated.
Posted: Sat Apr 28, 2007 8:39 am Post subject: 12v supply to stabilize avionics |
At 02:09 PM 4/27/2007 -0700, you wrote:
Put me down on the list to buy one should this
deal move forward. I'd like to have one to play
with on the drive stand this summer.
| Quote: | I have a 1-battery airplane and don't want to rewire the
below 10V.
Actually, your battery probably spends a few milliseconds
at voltages below 8 volts . . . Actual cranking, i.e. energy
delivered to the engine for starting does happen at about
10 volts but there's that gawd-awful inrush before cranking
actually beings that is the real dragon to slay.
ME!
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
pilot4pay
Joined: 01 Jan 2007 Posts: 171 Location: Louisville, KY
Posted: Sat Apr 28, 2007 10:31 am Post subject: 12v supply to stabilize avionics |
Interesting thread, my 182 with a g1000 doesn't even blink during a
start-up. It's a 24volt system though. I wonder if there are fat caps in the
avionics modules that prevent any reaction to the starting load. Startups
are performed with one pfd, one com, and the rest of the avionics energized
(bus 1).
CS
_________________ Craig Smith
CH640 builder
SN: 0078
"Just think how stupid the average person is,
and then realize that half of them are even stupider!"
--George Carlin |
Posted: Sat Apr 28, 2007 12:04 pm Post subject: 12v supply to stabilize avionics |
At 02:30 PM 4/28/2007 -0400, you wrote:
<pilot4profit(at)sbcglobal.net>
(bus 1).
CS
Probably not. It takes more than the simple diode-capacitor
ploy to fool an appliance into ignoring a startup-brownout.
Your appliances were no doubt qualified under
DO-160 recommendations by folks who took those recommendations
to heart and crafted products designed to live in the real
world of airplanes.
The absence problems manifested by other products being discussed
in this thread is a testament to their professional responsibility
an skills as engineers.
pilot4pay
Posted: Sat Apr 28, 2007 2:08 pm Post subject: 12v supply to stabilize avionics |
--> <nuckollsr(at)cox.net>
world of airplanes.
Certainly I didn't mean to suggest something that simple, but do you mean to
say that there is no other source of current other than the battery bus? I
guess what I'm getting at is would a fat cap be employed as a component of a
more sophisticated sub-system between the bus and the avionics circuitry, at
a module level or avionics bus level?
Or would something like Lion batteries be the chosen component, again, not
as a standalone thing, but as the choice component to be the current
reservoir in an engineered sub-system to keep the avionics alive.
CS
CH640 builder
SN: 0078
--George Carlin |
Posted: Sat Apr 28, 2007 3:03 pm Post subject: 12v supply to stabilize avionics |
At 06:07 PM 4/28/2007 -0400, you wrote:
world of airplanes.
. . . or the power supply within the product has the
same wide input range cited in the topic that
started this thread. Nowadays, it's not a big
deal to tailor input power conditioning to
cover ALL expected inputs. On a 14v device a
design goal might be for normal operation over
the DO-160 11 to 16 volt suggested range,
useable if somewhat degraded down to 9 volts
and orderly behavior for start-up brownouts.
I seriously doubt that anyone finds it useful
to go for a diode-cap or internal battery unless
a swift footed power supply is just impossible
or impractical.
Bob. . .
Posted: Sun Apr 29, 2007 6:56 am Post subject: 12v supply to stabilize avionics |
As Bob Nuchols surmised, this is lighter weight than
a second battery -- 0.1 lbs plus wiring.
It uses an Linear LTC3780.
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1116,P10090
The spec sheet for the 12V supply is attached.
-bob mackey
 Download |
| Filename: |
DSX12V_power_supply.pdf |
71.41 KB |
| Downloaded: |
401 Time(s) |
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Sun Apr 29, 2007 11:37 am Post subject: 12v supply to stabilize avionics |
That's what I did for my GRT EFIS brownout/reboot problem. I installed a hi-qual switch. If that switch ever fails, I have one radio, GPS and Dynon still good. But what are the odds? Now I just do an engine start, then flip R mag, Alternator, and Avionix switches on. Slick, and no pesky and long rebooting of GRT.
BTW, my Skytec spins the XP-IO360 like crazy from a 4 yr old PC680 Batt. I know, Bob, I should replace it every year, but I'm VFR and cheap...
Jerry Cochran
| Quote: | From: <gmcjetpilot(at)yahoo.com>
Subject: Re: 12v supply to stabilize avionics
<snip>
battery?
George
See what's free at AOL.com.
Posted: Mon Apr 30, 2007 5:05 am Post subject: 12v supply to stabilize avionics |
At 03:32 PM 4/29/2007 -0400, you wrote:
| Quote: | That's what I did for my GRT EFIS brownout/reboot problem. I installed a
If you have "a plan" for dealing with electrical
system failure, there's nothing inherently wrong
with running a battery until it croaks an won't
start the engine any more.
My admonition for a PM program that tracks battery
condition by either measurement or periodic replacement
presumes that you fly in conditions where loss of the
system is likely to star you in a dark-n-stormy-night
story.
It has nothing to do with being "cheap" and everything
to do with failure mode effects analysis: "What's
the sweat-factor for having this part fail and what's
the most efficient investment of $time$ to mitigate
that condition? If you're in a no-sweat mode of
ownership and operation, then running the battery into
the ground IS the most efficient cost of ownership
philosophy.
Posted: Mon Apr 30, 2007 5:12 am Post subject: 12v supply to stabilize avionics |
At 07:55 AM 4/29/2007 -0700, you wrote:
Take a peek at the detail specs for the i.c. at:
http://tinyurl.com/399l2x
Note that the part is rated at up to 5A continuous
with the parts described in the application example.
The larger currents cited are short term or momentary
capability.
( EVERY day . . . )
Jerry Cochran
Posted: Tue May 01, 2007 8:33 am Post subject: 12v supply to stabilize avionics |
I am in phase one testing with only 15 hrs on the system, so of course, VFR/day only and within 50 NM radius. Before relying on this 4 yr old PC680 for phase one though, I load tested it and was good. Begs the question though, isn't it being "load tested" on each engine startup? Do you advise other periodic testing? My copy of AEC at hangar...
Of course, if/when I do nitetime ops and/or IFR, then I'll go to a yearly mode for battery replacement.
Thanx,
Jerry Cochran
story.
philosophy.
BobsV35B(at)aol.com Guest
Posted: Tue May 01, 2007 8:40 am Post subject: 12v supply to stabilize avionics |
In a message dated 5/1/2007 11:36:03 A.M. Central Daylight Time, Jerry2DT(at)aol.com writes:
| Quote: | I am in phase one testing with only 15 hrs on the system, so of course, VFR/day only and within 50 NM radius. Before relying on this 4 yr old PC680 for phase one though, I load tested it and was good. Begs the question though, isn't it being "load tested" on each engine startup? Do you advise other periodic testing? My copy of AEC at hangar...
Good Morning Jerry,
Different Bob here, but I think you will find that a battery that tests as low as, or even lower than, ten percent of it's normal category will still crank an engine. Proper load testing needs to be done on a regular basis as suggested by 'Lectric Bob and others.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
khorton01(at)rogers.com Guest
Posted: Tue May 01, 2007 3:41 pm Post subject: 12v supply to stabilize avionics |
On 1 May 2007, at 12:39, BobsV35B(at)aol.com wrote:
| Quote: | In a message dated 5/1/2007 11:36:03 A.M. Central Daylight Time,
of AEC at hangar...
Good Morning Jerry,
Load testing should be done, if safety depends on having a battery of
some particular capacity. If the consequences of alternator failure
+ battery failure are acceptable, then there is no need to do
periodic battery load testing.
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Tue May 01, 2007 4:08 pm Post subject: 12v supply to stabilize avionics |
At 12:31 PM 5/1/2007 -0400, you wrote:
| Quote: | Bob,
There are two kinds of tests that one conducts on a
battery to know "all of the story". Yes, cranking the
engine is a non-quantified but certainly valid anecdotal
"load test". The tests accomplished by your local
service mechanic with something like this . . .
http://www.aeroelectric.com/Pictures/Tools/Battery_Testers/HF91129_4.jpg
is a quantified equivalent of the "see if she cranks"
test.
The other piece of data still more useful to the
owner/operator is the CAPACITY test. "How long will
it run the useful goodies on my panel?"
A load test won't tell you but a cap test with this
thing will . . .
http://www.aeroelectric.com/Pictures/Tools/CBA2_1.jpg
If you don't want to invest $time$ in doing the periodic
hat dance necessary for the quantified test, then you
simple replace it long before you think it's capacity
is compromised with age. Sometimes the periodic, blind
replacement is more effective for reducing cost of ownership
than detailed testing.
( EVERY day . . . )
Posted: Tue May 01, 2007 4:45 pm Post subject: 12v supply to stabilize avionics |
In a message dated 5/1/2007 6:43:05 P.M. Central Daylight Time, khorton01(at)rogers.com writes:
| Quote: | Load testing should be done, if safety depends on having a battery of
Good Evening Kevin,
No argument with your analysis at all. I was merely trying to point out that just because a battery starts the engine does NOT mean it has been "load tested".
If the engine will run with no electricity at all, who needs a battery? You can prop it and go fly.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
