Floats on CH701
mcolbeck
PostPosted: Tue Apr 24, 2007 4:18 am    Post subject: Floats on CH701 Reply with quote
Can anybody tell me what floats do to your gross weight? As it stands with extended range tanks (full), a passenger and myself we would be at gross weight. Is it a straight across the board change your landing gear to floats then redo your weight and balance?
I have not completed my aircraft but know that when I have completed my test phase I will probably switch from wheels to amphibs.
Very Happy
CH701 Builder and new flyer
Rudder, HS, and Elevator completed
Left wing Complete
50% complete on Right Wing
99% Complete on Fuselage
Engine installed almost ready to fire
Instrument panel and electrical Complete
Gig Giacona
PostPosted: Tue Apr 24, 2007 5:29 am    Post subject: Re: Floats on CH701 Reply with quote
Depending on the float you use they generaly carry their own weight, so to speak. Meaning that if they way 100# they add additional lift of 100 #.
The only place this is a problem is if you are shooting for the LSA MGW and you are already at the MGW.
W.R. "Gig" Giacona
601XL Under Construction
john.marzulli(at)gmail.co
PostPosted: Tue Apr 24, 2007 6:27 am    Post subject: Floats on CH701 Reply with quote
The LSA gross weight increases by 100lbs for floats to 1420.
-John in Seattle
On 4/24/07, Gig Giacona < wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)> wrote:[quote]--> Zenith-List message posted by: "Gig Giacona" < wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)>
W.R. &quot;Gig&quot; Giacona
http://forums.matronics.com/viewtopic.php?p=108870#108870
http://701Builder.blogspot.com/
"Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes.
-Airplane The Movie [quote][b]
billmileski
PostPosted: Wed Apr 25, 2007 5:49 am    Post subject: Re: Floats on CH701 Reply with quote
I have often wondered about the "floats develop lift that counters their extra weight" thing. Often when I see a 701 float installation, it looks like they are at a negative incidence with respect to the wing, so that when planing in proper trim, the wing is at some modest positive angle of attack for liftoff. In the oldest 701 installations it looks like the setup put the floats in a significant down angle (negative angle of attack) in flight, which looked to be developing negative lift if anything. Anyone else have thoughts?
Bill Mileski
701 912S 89hrs
Avidmagnum
PostPosted: Wed Apr 25, 2007 6:38 am    Post subject: Re: Floats on CH701 Reply with quote
I have a 701 on Czech 1200A floats. The floats are set at a 3 degree down angle so that you can more easly rotate off the water. I increased the gross weight by the difference in the weight of the removed gear and the new weight with the floats. (About 150 lbs on the 701) My gross is 1250 now. But please note at full gross it will not peform like a 701 on wheels! There is more lift but also a lot more drag! That's not to say it's a poor float plane ...it's a very good float plane but the lighter the better. (Time for me to go on a diet!) I had to do a lot of modifications to get it to cruse at 95mph (5500RPM) with a 912s. I often fly it at 80 to save gas.
Tom Schulke
100 + hours on floats (701)
650 + total floats
701 on floats (Czech 1200a)
Rans S-7 on wheels.... have Czech 1200A's on order
nyterminat(at)aol.com
PostPosted: Wed Apr 25, 2007 9:15 am    Post subject: Floats on CH701 Reply with quote
Tom,
Ok let´s hear about the mods to get your cruise up.
Bob Spudis
Tom Schulke
650 + total floats
http://forums.matronics.com/viewtopic.php?p=109168#109168
rget=_blank>http://www.matronics.com/Navigator?Zenith-List
AOL at AOL.com.
Avidmagnum
PostPosted: Thu Apr 26, 2007 5:57 am    Post subject: Re: Floats on CH701 Reply with quote
Ok Bob....The mods!
1)Skyshops retrofit kit w/ new cowling and Rotax air box....little help...but look nice
2)Skyshops kit for fairing out the lift struts....this was a big help!
3)Rans plastic cover for jury struts. did this the same time as the lift struts so who knows...but they look nice!
4)Made cover for the tunnel that the landing gear went. This helped more in rate of climb.
5)The big one! Removed the slats and put on Vgs. Went from 85mph to 92mph at same prop pitch and with the less drag I was able to repitch the prop to pick up 3 more mph. Flys better and stall went up only about 1 mph.
This is what I did and it worked for me.... Very Happy
Do not Archive
Tom Schulke
Stol 701sp on Czech 1200A Floats
912S warp drive prop
PostPosted: Thu Apr 26, 2007 10:08 am    Post subject: Floats on CH701 Reply with quote
Thanks Tom, I will start with the stut fairings, already have the Skyshops cowl, You are right it does look good. Where did you end up putting the VG´s? Any pictures of the gear cover?
Thanks again
Avidmagnum
PostPosted: Thu Apr 26, 2007 12:11 pm    Post subject: Re: Floats on CH701 Reply with quote
The instructions are on www.stolspeed.com . I like the VG's they sell and will buy a set for my Rans S 7 next fall when I go back to Florida.
For the 701 it's extra easy. Just measure 130mm in front of the top edge of the nose skin where it rivets onto the spar - this will be the front tip of the VG. For under the horizontal stab measure 100mm in front of the gap between stab and elevator. I've posted the photo of the gap cover.
Have Fun.
Tom Schulke
 Filesize:  251.5 KB
 Viewed:  841 Time(s)
cgbrt(at)mondenet.com
PostPosted: Sun Apr 29, 2007 4:08 am    Post subject: Floats on CH701 Reply with quote
Hi ,
I'm Canadian and built my 701 in 1994. Flew the test hrs on wheels then
switched to amphibs in 1995. The basic weight on wheels was 619 lbs, amphibs
increased to 760. The designed gross at that time was 960 lbs.
When I applied for the registration I asked for an increase in gross to
1200, I included a lettre from Chris Hentz that approved the change but with
the warning of a proportional decrease in G loading and increase in stall
speed.
The 1200 gross was accepted by the Department of Transport.
Personally I do not believe that the floats develop lift. I base that on
their shape (more like an inverted airfoil) and their negative angle of
attack in relation to the wing. I have two front frames; one gives me a -8'
the other -4' relative to the wing. With -8' frame the cruise is 4 mph less
than the -4' frame. With the -8' frame lift-off occurs at 38 mph; with
the -4' it occurs at 42 mph.
Cruise speed is decreased approx 10 mph by the addition of amphibs. I
believe the difference is caused by negative lift and form drag . I would be
concerned about increasing gross without adjusting G limits.
Carl
701/912 amphibs.
ricklach
PostPosted: Mon Apr 30, 2007 7:30 am    Post subject: Re: Floats on CH701 Reply with quote
Hi Carl,
I would like to talk to you about getting a copy of the letter you provided with your request of a 1200LB weight limit. I will be applying for my registration to the FAA here in the U.S. soon and would like to do the same thing you did and the letter would help in my request.
I can be reached at:
rick(at)ravengear.us or 661-345-7755
Rick
PostPosted: Sat May 12, 2007 3:55 am    Post subject: Floats on CH701 Reply with quote
Rick,
Here is Chris' letter. Sorry for the delay
Carl
 Filesize:  37.13 KB
 Viewed:  891 Time(s)
