		SSampson.SLN21(at)london. Guest
				 Posted: Fri Apr 13, 2007 12:29 am    Post subject: VS offset |
				I asked this question on Vansairforce but got  nothing from the -4 community. I thought I would try here, since it must have  been considered.
  With all the -4 flying in the USA is there any  'conventional wisdom' about offsetting the VS at the front spar to the left to  reduce the need for right rudder in order to fly in trim?
 I found a bit  about it in the matronics archives back in '98 but nothing since. They were  talking 1/4". The -9 is certainly designed this way and I expect the  -7.
 If yes, how much offset? Also does it mean you have to throw the VANS  fairing out?
 Thoughts?
  Thanks, Steve.
  |  | - The Matronics RV4-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV4-List |
		efortner(at)ctc.net Guest
				 Posted: Fri Apr 13, 2007 9:33 am    Post subject: VS offset |
				I am building a RV-4 but have not worked on it in a  while. I do remember building in offset to the vertical stablizer.  I
  don't remember if it was 1/4 inch or 3/8 inch but  was built
  in when I attached it.Don't recall if it was in the  instructions or not but I did read it somewhere to do that.
  Earl Fortner, Harrisburg, NC
  [quote]   ---
		Oldsfolks(at)aol.com Guest
				 Posted: Fri Apr 13, 2007 1:11 pm    Post subject: VS offset |
				I have built two  RV-4's and set the HS in line with the  fuselage.  There are enough variables in building with out adding more  possibilities of out -of-trim.
  Bob Olds
  RV-4     -  N126RV  &  N1191X
  Charleston,Arkansas
 See what's free at AOL.com.
		halbenjamin(at)optonline. Guest
				 Posted: Fri Apr 13, 2007 5:54 pm    Post subject: VS offset |
				Hi Steve C
   6nbsp;
  I considered 6nbsp;offsetting the VS C but after 6nbsp;talking to a couple of people with flying 4s (Including Van 7s) I decided to 6nbsp;mount it straight as per plans E
   6nbsp;
  Hal Benjamin
  RV4 C Long Island C NY
  Endlessly tweaking canopy frame 6nbsp;
		jlisler(at)alltel.net Guest
				 Posted: Sat Apr 14, 2007 1:49 am    Post subject: VS offset |
				I built mine with a 1/4" offset. I did not use the  Vans tail intersection fairing. It was not even close and it looked  awful. I layed up a new fairing that fits really good so far. As for the  offset, I still need the pressure of your foot resting on the right rudder  peddle to center the ball.  I guess I will eventually put on a  trim tab.
  Jerry Isler
  Donalsonville, GA
  RV-4 N455J
  16 hrs and counting
				 Posted: Sat Apr 14, 2007 9:08 am    Post subject: VS offset |
				Thanks everyone for the VS offset info. On balance  I think I have been talked out of the idea. I had thought that since the later  RV are built with the VS offset, it would make lots of sense, but though  there was some, there was not a lot of support. Cheers,  Steve.
				 Posted: Sat Apr 14, 2007 9:31 am    Post subject: VS offset |
				I would suggest you research it a little more. I  have yet to see and RV-4 that did not have a wedge or trim tab on the rudder.  How about asking Van. I am sure he
  would reply to your request and I doubt if there is  anyone that knows more about the RV-4 than Van.
  Earl
  [quote]   ---
		cubflyr(at)comcast.net Guest
				 Posted: Sun Apr 15, 2007 8:31 am    Post subject: VS offset |
				Steve:
 When I was first building (George Bush The First was president) I had been
 working with airplanes for years (since Nixon was president; yikes!). Since
 I was now building my own, I looked at every airplane I could, factory or
 custom built, which you should also do. I also have a 1946 J-3 Cub in the
 hangar and could look at it. Almost ALL of them, from the fastest to the
 slowest, had an offset vertical fin. I also noticed some rather humongous
 rudder trim tabs on the two RV models that were out: the -3 and the -4, then
 later on the -6. And some of them were not pretty. (Do NOT just stick a
 piece of flat stock on the rudder; THAT is ugly.) I decided to offset my
 vertical (I am the factory, after all) and, although I can't remember how
 much, I believe it was 1/4 inch. Then I went flying. I found I still had to
 hold a little rudder in level flight and ended up putting on a trim tab
 anyway, but smaller than most I had seen. I found myself wishing I had
 offset it more. But how do you know until you put air under the wings? Trim
 flight involves so many factors.
 The tail fairing was discarded almost as it came out of the box: from the
 box to the trash. I built my own that has a glove-like fit and I like it.
 Trim tab: an aluminum wedge plate that sits at the trailing edge. Placement
 is a controversial issue: it is my opinion that the lower (or higher, what
 ever you don't mind people seeing) may work better. I place mine where I saw
 most others placed: about in line with the middle hinge of the rudder. That
 may not be the best place as the rudder may not have as much authority there
 due to the disturbed air from the fuselage, but I am not sure because I
 didn't play with the up and down as much as I should have. The Bugs know:
 there are rarely any bugs on the tail fairing. Most bugs start about 8
 inches above the fairing, meaning that the air is disturbed from the
 canopy/fuselage and may not be reaching the trim tab as well as it could.
 Tufting would also help determine where to put it but to see back there
 necessitates formation flying with you and someone else that ALSO knows
 formation flight.
 SO: when you are duct taping your wooden trim tab test model on the rudder
 for flight trials, play with the size (height and width) as well as the
 angle that you need. But also, once you found the size that works best for
 feet on the floor flying AT CRUISE, move it up and down the rudder to see
 where it is most effective. You do NOT want to fly everywhere with your foot
 pressed against the rudder for the next 3000 hours. Also remember this has
 to be done AFTER the main gear leg fairings are in place because they can
 influence how straight the airplane flies. Suzie Q is one of the straightest
 airplanes I have flown. There is NO elevator sticking up or down from the
 horizontal when I am in cruise and solo, minimal baggage. Even with a
 passenger only about 1/8 inch sticks up. She cruises, once trimmed, feet on
 the floor.
 I LOVE my airplane. So will you.
 Michael
 N232 Suzie Q
 1038 hours, more to be put on this morning......
				 Posted: Sun Apr 15, 2007 11:05 am    Post subject: VS offset |
				Brian, calling the factory from here doesn't work  too well, so I will be very interested to hear if you manage to engage them in a  discussion, and more importantly what they have to say. WRT Smokey, I have seen  no input, but I sense he catches up in blocks. Perhaps he is away a lot since it  is the sort of thing he normally joins in on.
  No, my tent is not folded! I was just trying to get  some reaction...which appears to have worked. It is not a thing which I need to  act on for a while, since the next major operation is the dreaded canopy. Just  trying to get my ducks lined up though.
  Glad you are also interested. Its a big  help.
  Cheers, Steve.
  [quote]   ---
		DFCPAC(at)aol.com Guest
				 Posted: Sun Apr 15, 2007 11:32 am    Post subject: VS offset |
				steve,
  i did not build my rv-4, but i did check it and it has a very little  offset. and i still have one of those little angle blocks on my rudder. before i  painted the plane i taped it on and got what i wanted. no falling asleep right  foot.
  good meeting you last week.still fooling around with that canopy? i'll try  to fly over next Saturday and maybe we can do some flying.
  regards
  danny
  rv-4
  N2275S
		smokyray(at)yahoo.com Guest
				 Posted: Sun Apr 15, 2007 4:00 pm    Post subject: VS offset |
				Steve, Danny,
   I helped a friend assemble an RV4 with 1 degree right offset in the vertical stab. I thought at the time it was a great idea, and it was. The aircraft flew hands off and needed no rudder trim up to 170mph. Above 170mph up to VNE it would displace the ball to the middle of the "centered" reference line. His cruise speed was 155 knots (170 mph) so it really worked great.
 I highly recommend the mod, it works!
 Rob Ray
 DFCPAC(at)aol.com wrote:[quote]     steve,
  i did not build my rv-4, but i did check it and it has a very little  offset. and i still have one of those little angle blocks on          Ahhh...imagining that irresistible "new car" smell?
  Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url]  [quote][b]
				 Posted: Sun Apr 15, 2007 4:11 pm    Post subject: VS offset |
				Guys,
 OOPS, I meant the other right...1 degree LEFT offset producing right rudder! I get Lysdexic sometimes!
 Smokey
 Rob Ray <smokyray(at)yahoo.com> wrote: 	  | Quote: | 	 		   Steve, Danny,
 Rob Ray
 DFCPAC(at)aol.com wrote: 	  | Quote: | 	 		       steve,
  Check out new cars at  size="2"> |
 [/quote]
				 Posted: Sat Apr 21, 2007 4:13 am    Post subject: VS offset |
				Brian, did you talk to the factory yet? Thanks,  Steve.
  [quote]   ---
