LRI gage face
msherman95632(at)yahoo.co
PostPosted: Fri Apr 20, 2007 2:27 pm    Post subject: LRI gage face Reply with quote
List Members.
There has been some talk of an easy way to change the Dwyer pressure gage face to better suit the LRI that some of us a installing.
This is what I came up with. Below is a picture of the finished gage and the vinyl overlay I used to put over the top of the factory face.
It took a little practice to get it positioned right but it came out good.
I had to have a sheet of 16 printed out and have some extras, if anyone is interested. The first sheet was a little expensive, but now that the art work is done additional sheets won't be as much. They cost me about $4.00 ea.
Let me know off list.
Mark S.
701/912ULS
 Filesize:  25.01 KB
 Viewed:  479 Time(s)
grs-pms(at)comcast.net
PostPosted: Fri Apr 20, 2007 4:32 pm    Post subject: LRI gage face Reply with quote
Mark:
I'd like one! Let me know the price,including mailing.
George
dbortol
PostPosted: Sat Apr 21, 2007 4:36 am    Post subject: LRI gage face Reply with quote
I put the white dots in the artwork to help with alignment. Hold the assembly in front of a light and you'll be able to line things up easily. The dots are slightly undersized compared to the holes in the plate so that no white will be visible in the finished product if the alignment isn't perfect.
I printed my gauge face on a self-adhesive label. After cutting it out, I stuck it on a small piece of wax paper, leaving a narrow strip protruding on one side. I lined it up (on the back side) of the metal plate, stuck the exposed edge down, and then removed the wax paper to stick the rest down. I also did a test using the same method with regular paper and a glue stick. It worked well too.
Dino Bortolin
LRI gauge - done
XL - long way to go
On 4/20/07, Mark Sherman <msherman95632(at)yahoo.com (msherman95632(at)yahoo.com)> wrote:[quote]List Members.
Mark S.
701/912ULS
PostPosted: Sat Apr 21, 2007 8:37 am    Post subject: LRI gage face Reply with quote
George.
You can use PayPal, my account is under Mark Sherman msherman(at)softcom.net or send a check or whatever to 12875 Midway Rd. Galt, CA 95632.
For those of you who want two or more, the same $1.00 shipping for all of them will work. That would be $5.00 for one, $9.00 for two and so on.
I will include some instructions on applying the vinyl that worked good for me.
I have been using this same type of vinyl for instructions on the doors of commercial dryers. These are heat cycled about a dozen times a day from cold to 160 degrees, and have been installed for more than a year with no sign of deterioration. The data sheet on this material says it is good to 200 degrees and has UV protection. It is designed for use as outdoor signs.
Mark S.
PostPosted: Sat Apr 21, 2007 8:43 am    Post subject: LRI gage face Reply with quote
List.
Sorry for the last two postings, they were meant for private e-mails.
I will be more careful in the future.
Mark S.
kensmith(at)springnet1.co
PostPosted: Sat Apr 21, 2007 2:26 pm    Post subject: LRI gage face Reply with quote
Mark....
I will send out a $9.00 check to you tomorrow for two of the vinyl covers for my two (2) Dwyer gages.
Ken Smith
2903 Kipling Ct.
Springfield, Illinois 62711-7975
(217) 725-3406
"kensmith(at)springnet1.com" (kensmith(at)springnet1.com)
Mark Sherman wrote: [quote] [quote]--> Zenith-List message posted by: Mark Sherman <msherman95632(at)yahoo.com> (msherman95632(at)yahoo.com) George. You can use PayPal, my account is under Mark Sherman msherman(at)softcom.net (msherman(at)softcom.net) or send a check or whatever to 12875 Midway Rd. Galt, CA 95632. For those of you who want two or more, the same $1.00 shipping for all of them will work. That would be $5.00 for one, $9.00 for two and so on. I will include some instructions on applying the vinyl that worked good for me. I have been using this same type of vinyl for instructions on the doors of commercial dryers. These are heat cycled about a dozen times a day from cold to 160 degrees, and have been installed for more than a year with no sign of deterioration. The data sheet on this material says it is good to 200 degrees and has UV protection. It is designed for use as outdoor signs. Mark S. ---
