jerryhey(at)earthlink.net Guest
Posted: Mon Apr 16, 2007 6:53 am Post subject: Work table |
I just ordered the 701 plans this morning. Before they get here I
have time to build the table. Can anyone give me recommendations as
to length and width of the table top. Thanks, Jerry
roger(at)nwtradingpost.co Guest
Posted: Mon Apr 16, 2007 7:42 am Post subject: Work table |
Jerry
I am building a 701 and I find 12 foot by 4 foot works well
Roger
CH-701, finished building, installing systems
dgardea(at)gmail.com
Joined: 26 Mar 2007 Posts: 50 Location: Indianapolis, IN
Posted: Mon Apr 16, 2007 8:41 am Post subject: Re: Work table |
Jerry,
An excellent set of plans for a 4 by 12 table are at http://www.ch601.org/tools.htm
Scroll a bit down the page and look for "table plans". I built this table for my 601XL project.
62.47 KB |
519 Time(s) |
_________________ Dave Gardea
CH650 - Corvair - flying!
http://n631dg.t15.org/home.html |
brothapig(at)HOTMAIL.COM Guest
Posted: Mon Apr 16, 2007 10:28 am Post subject: Work table |
Jerry, I built mine ~13ft x 4ft, and that is plenty big. I used 2x6's for the top frame, but if I had to do it again, I would use engineered I-beams. The reason is they are straight. I thought the 2x6's I used were straight, but when you start measuring your table top, you see all of the variations in the board. I used 3/4" BC plywood for the top, but I would use MDF instead. MDF is extremely flat, and hard.
I went though a lot of extra shimming on my table to get it flat, and it still is not perfectly flat. If you want to see a picture of my table you can go to users.tznet.com/~brothapig
I'll send you more pictures off list if you would like them. Happy building.
Ryan
| Quote: | To: zenith-list(at)matronics.com
Subject: Work table
Date: Mon, 16 Apr 2007 10:52:39 -0400
ernieth(at)gmail.com Guest
Posted: Mon Apr 16, 2007 11:24 am Post subject: Work table |
Hi,
I used the engineered I-beams. The ones I used had 1x3 top and bottom. I would use the 2x4 version if I had to do it over again. They were not perfectly flat, but straight. My Neighbor told me that the ones he has used in the past were better quality. I think the version with 2x4 top and bottom would have been the better quality.
http://docs.google.com/View?docid=dhdvd8qv_8gzwkqk&revision=_latest
E.
Do not Archive
On 4/16/07, Ryan Vechinski <brothapig(at)hotmail.com (brothapig(at)hotmail.com)> wrote:[quote] --> Zenith-List message posted by: Ryan Vechinski <brothapig(at)hotmail.com (brothapig(at)hotmail.com)>
Ryan
[quote] To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
From: jerryhey(at)earthlink.net (jerryhey(at)earthlink.net)
Subject: Work table
--> Zenith-List message posted by: Jerry Hey
to length and width of the table top. Thanks, Jerry [quote][b]
JERICKSON03E(at)aol.com Guest
Posted: Mon Apr 16, 2007 4:12 pm Post subject: Work table |
In a message dated 4/16/2007 9:54:16 AM Central Daylight Time, jerryhey(at)earthlink.net writes:
| Quote: | --> Zenith-List message posted by: Jerry Hey <jerryhey(at)earthlink.net>
to length and width of the table top. Thanks, Jerry |
Jerry,
For a FLAT and moveable work table I used the two sections of a new, Home Depot, extension ladder.
Sixteen foot ladder, remove the fittings from the ends, space out plywood top surface down on the floor & lay out ladder sections with about 3 in clearance all around to clamp to during construction.
Drill clearance holes through the rails for # ten sheet metal screws, about 3/4 in long, pan head PHILIPS head. Screw through ladder rails at about ten in spacing or so. Use good quality plywood that is flat to start with, Home Depot again.
Layout is with both ladder sections laying next to ea. other. Screws through each of the four rails. Pilot holes only into the plywood.
Then screw two boards across the four ladder rails, cross wise to form kind of a box beam. Place them where you think the legs should be ~~~~~. Box beam makes it strong & keeps it flat too.
Use whatever legs you like, I used two small folding leg tables, sawhorses are used by others. That allows the height of the work table to be lowered later with shorter legs, or other supports. Just clamp it as needed.
The ladder I used was 16 foot extension, and resulted in a 10 1/2 foot long by 4 foot wide work table. It fits in my work shop, just right for my 701 construction. Use the length you need for your length table. Measure the ladder extensions before you buy it, to satisfy yourself they are the same width, yes they are made to slide into each other, not a factor here though.
The result is a FLAT & light weight work table, that goes together quickly. Cost is a wash, and the aluminum ladder rails are straight to start with and have stayed straight. I studied wood beam work tables & the tables at ZAC. Most were heavy and less than flat when I saw them.
Be aware that the FLAT plywood table top is the tooling here. It gets screws, holes, slots, and whatever is needed to serve to make the aircraft parts along the way. It is the way the designer helps us build correctly, no twist that is. Flat is Flat. Level is another condition, useful now and then, as in joining the fuselage sections.
Happy Building
Jerry Erickson, EAA TC & 701 builder.
See what's free at AOL.com.
Posted: Mon Apr 16, 2007 5:30 pm Post subject: Work table |
Here is another place where a couple of images would really be nice. Please post them if available. Thank you.
JERICKSON03E(at)aol.com wrote: | Quote: | ...Jerry,
Sixteen foot ladder, remove the fittings from the ends, space out plywood top surface down on the floor & lay out ladder sections with about 3 in clearance all around to clamp to during construction.....
Dave Downey
Harleysville (SE) PA
Zodiac 601XL/Corvair?
Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
raymondj(at)frontiernet.n Guest
Posted: Mon Apr 16, 2007 6:35 pm Post subject: Work table |
Greetings,
Some engineered lumber beams use LVL (looks like thick plywood) for the flanges. I think they might be straighter than the ones with regular lumber for the flanges.
Raymond Julian
Kettle River, MN
[quote] --
Posted: Mon Apr 16, 2007 7:10 pm Post subject: Work table |
I like this surprising table construction. Simple, inexpensive and accurate. I will be checking the ladders at Home Depot next time I am in town. Thanks, Jerry
On Apr 16, 2007, at 8:12 PM, JERICKSON03E(at)aol.com (JERICKSON03E(at)aol.com) wrote:
[quote] In a message dated 4/16/2007 9:54:16 AM Central Daylight Time, jerryhey(at)earthlink.net (jerryhey(at)earthlink.net) writes:
| Quote: | --> Zenith-List message posted by: Jerry Hey <jerryhey(at)earthlink.net (jerryhey(at)earthlink.net)>
Jerry,
Happy Building
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
| [b]
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
Kevin Bonds
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Tue Apr 17, 2007 1:06 pm Post subject: Re: Work table |
I made the box beams like you did Kevin only I was able to run them all over a planner at work. You see me jumping on it and doing engines tear downs and it is still flat, just has a lot of holes and grooves in it now.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
