		esmith6(at)satx.rr.com Guest
				 Posted: Sun Apr 15, 2007 5:18 pm    Post subject: Rudder trim inside the cockpit |
				OK, for you out there that have rear seat rudder  pedals, it is an easy task to install a rudder trim...Get a turn buckle and a  medium strength spring, and (you determine the size of each to fit your  situation) hook the turn buckle to the right rear pedal, and the  spring where the rear pedal PUSH ROD goes through the  bulkhead.
  To operate, push the right rudder pedal with your  size 12 until you get the "ball" in the center, or where ever you want it, then  start cranking the turn buckle to tighten the spring (this PULLS the rear  pedal forward, and the right rudder forward) until you can remove your size 12  from the front rudder pedal, and maybe tweak it if necessary.
  I know your thought now is, "suppose I forget it  all in the traffic pattern," no problem, the spring might cause a little more  pressure to be applied to the right rudder, but it works fine...If you think of  it in time, you can reach down and disconnect the spring without even  looking.
  So you don't have rear rudder pedals?..No problem,  get a aluminum rod, attach one end to the right rudder pedal right flange, drill  a hole in your right side bulk head and install the rod through it, allowing  enough length to work back and forth...For a long flight, get the "ball" where  you want it, and IN THE FRONT OF THE BULK HEAD, attach a small pair of locking  pliers to hold the rudder in place...LAUGH IF YOU WANT, but I used this for  years to go to OSH and LCL before installing the rear seat rudder pedals (and  never had right leg limp after arriving)...If you forget about it in the traffic  pattern, KICK THE "DOG POO" out of the rudders and the pliers will fall  off...(provided you didn't crank them too tight!)................Hope this helps  someone out there, good luck and  ....................CHEERS!!!!...............................Gene  Smith.
  |  | - The Matronics RV4-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV4-List |
				 Posted: Sun Apr 15, 2007 5:42 pm    Post subject: Rudder trim inside the cockpit |
 href="http://www.matronics.com/Navigator?RV4-List">http://www.matronics.com/Navigator?RV4-List
		Jerry Grimmonpre'
  Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
				 Posted: Mon Apr 16, 2007 4:57 am    Post subject: Rudder trim inside the cockpit |
				Gene ... your write-up sounds good, can you please send a  picture or sketch of the rear rudder pedals and trim direct and off  line?  My 4 is all opened up right now so putting in rudder pedals is my  next project ... I just need to know what works.
  Jerry
  jerry(at)mc.net (jerry(at)mc.net)
  [quote]   ---
		smokyray(at)yahoo.com Guest
				 Posted: Mon Apr 16, 2007 5:24 am    Post subject: Rudder trim inside the cockpit |
				Jerry,
   Gene's idea is great but is alot easier than that. All you need is a simple horseshoe shaped piece of .040 aluminum 3" wide. Drill a hole in one side and attach a small piece of mini bungee cord with a hook on one end and attach the cord to the horseshoe.  You simply place the "U" in the Horseshoe over the rudder cable (next to your right thigh) with pressure on the rudder inflight with the hook over the edge of the fwd fuselage bulkhead. Release the pressure and voila' the cable pressure over-center moves the U to one side thus holding the cable where you put it. Same principal as a strap for climbing palm trees...
 Very simple, cheap and works.   I'll take a picture for you and post it...
 Rob Ray
 Jerry Grimmonpre <jerry(at)mc.net> wrote:[quote]       Gene ... your write-up sounds good, can you please send a  picture or sketch of the rear rudder pedals and trim direct and off  line?  My 4 is all opened up right now so putting in rudder pedals is my  next project ... I just need to know what works.
  Jerry
  [quote]   ---
