naumuk(at)alltel.net Guest
Posted: Sat Apr 14, 2007 8:24 am Post subject: Corvair firewall- bolt length |
Jeff and all-
Wow, this has been like a newspaper treasure hunt!
Are HD/HDS and XL plans mount locations the same? Yes. According to the archives, the XL O-235 layout will also work for Rotax and Jabiru mounts on all 601s. But what about Corvair mounts?
According to Phil Maxson, he drilled per plans for the O-235 and everything worked for his Corvair installation but for longer bolts.
Now, all I need is to know is the bolt specs so I can give ACS some more money and I'm in business.
I'm sure you can imagine how hard it is to hold back progress until you make sure you won't have to rework the whole front end of your project down the line. Education via the school of hard knocks.
Anyone out there have the Corvair mount bolt specs?
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Jaybannist(at)cs.com Guest
Posted: Sat Apr 14, 2007 8:52 am Post subject: Corvair firewall- bolt length |
Bill,
According to WW, you will need 4 AN6-23A bolts, 4 AN363-624 nuts and 4 AN960-616 washers. This information is in the WW 601 installation manual.
Jay in Dallas
"Bill Naumuk" <naumuk(at)alltel.net> wrote:
[quote]Jeff and all-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sat Apr 14, 2007 9:15 am Post subject: Corvair firewall- bolt length |
The spool thickness on the Wynne motor mounts are the same as the spools on the motor mounts shown on the Zenith plans for the Lycoming O-235 mount on 6-YE-2. I know because I measure the spools on my WW mount. From base to top the length is 38 mm. Repeating the quote from an e-mail from Nick he recommended:
"In the latest edition, we no longer weld the bolt to the engine mount fitting. For the lower engine mount fittings, installing the bolt after the fitting is installed to the fuselage allows for better alignment.
For a 38mm long bushing, allow approximately 3mm to go through the fitting, the doubler and firewall = 41mm A better bolt to use is an AN6-22A (grip length = 1-11/16")"
-- Craig
[quote] [b]
Posted: Sat Apr 14, 2007 10:42 am Post subject: Corvair firewall- bolt length |
Jay-
The manual is out? I had an e-mail with WW 4/10 and it wasn't ready for
publication yet.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sat Apr 14, 2007 11:16 am Post subject: Corvair firewall- bolt length |
Bill,
The manual is not ready for publication, but it is "out." I have gotten two iterations from WW. The first one was about 10% complete and the latest one is about 50% complete. No telling when he will finish it. He would never admit it, but he simply has more on his plate than he can possibly handle in a reasonable amount of time.
Jay in Dallas
Jay-
publication yet.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sat Apr 14, 2007 1:07 pm Post subject: Corvair firewall- bolt length |
Jay-
Since I'm through the firewall questions, I've got enough other stuff to
keep me busy until he finishes the manual.
Thanks.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
