Daniel.Snow(at)wancdf.com Guest
Posted: Wed Apr 11, 2007 4:15 am Post subject: Hard Starting Without Primer |
Based on the experience of others, I didn't install a primer on my new
Superior XP O-320 engine. I use the mixture control to kill the engine,
so I understand fuel has to get back to the jets before it will run.
However, I'm having to crank for roughly 20 seconds, let the starter
cool, then crank again for nearly 20 seconds before it will start. My
start sequence is;
Master on
Fuel pump on for at least 10 seconds
Throttle 1/4 open
Crank for 5 seconds
Pump throttle one time and hold at 1/4 open
Continue cranking for 5 more seconds
Stop cranking and let starter cool for 2 minutes
Crank for 5 seconds
Start playing with throttle to find the "sweet spot"
Starts rough until I find the "sweet spot"
Idles smoothly and runs up fine after warm
For those of you who don't use a primer, do you have any suggestions? I
don't know if I'm giving it too much fuel or not enough. I don't smell
gas at the air inlet, so I don't think I'm flooding it, but I'm afraid
to pump too much at the beginning. Do I need to just let the boost pump
run for a while with the throttle at 1/4 open to get fuel to the jets,
or is that only going to work when the engine is cranking over?
I just remembered, it restarts within a couple of revolutions when I
shut it down using the mixture control, so fuel should be reaching the
jets fairly quickly on a cold start.
Daniel Snow
RV-9A, 1 week to SnF, 2 weeks to inspection
dale1rv6(at)comcast.net Guest
Posted: Wed Apr 11, 2007 4:53 am Post subject: Hard Starting Without Primer |
Try:
Master on
Mixture rich
Fuel pump on
Pump throttle one full stroke
Without delay; close throttle, then open 1/8 inch, crank 5 seconds, if no
start repeat throttle pump, open throttle only 1/8 inch again and crank 10
seconds.
If it does not start after 20 seconds something is wrong
After start lean mixture as much as possible while keeping engine running
smooth
After 20 years and 3,000 hrs on carb Lycoming engines I have never had to
pump while cranking.
Best of luck,
Dale
sheldonb(at)frontiernet.n Guest
Daniel,
I had the same kind of start problem (no primer system) early on when first
learning my plane... 0-360
COLD STARTS: ( cold start = 1st start for the day).. Mixture rich, pump
throttle 3 times and leave at 1/4 open, engage starter... fires right up...
HOT STARTS: Do not push or touch throttle, leave closed (pulled back)..
leave mixture in cut off.. start cranking... slowly push mixture in.. when
engine likes it, it will start... give some throttle to keep it running...
Works every time..
Sheldon RV6A 450 hours 0-360 FP
n616tb(at)btsapps.com Guest
Posted: Wed Apr 11, 2007 6:01 am Post subject: Hard Starting Without Primer |
Daniel,
I have an 0-360A1A and I couldn't start mine easily without the primer. I
know I have heard others doing it, but I can't get mine started reasonably
without using it. Thankfully I installed it. Also I think you don't want
to pump the throttle unless you are cranking simultaneously. If it is an
updraft carb, then fuel can just run out into the airbox, down the drain
hole into the cowl and well, you get the point. Why not just install a
primer?
[quote] --
sbuc(at)hiwaay.net Guest
Posted: Wed Apr 11, 2007 6:38 am Post subject: Hard Starting Without Primer |
Daniel,
I've been flying my primerless O-320 for over seven years. I think if
you will pull the throttle nearly closed instead of 1/4 open you will
enjoy good starts. With my engine, it is turn on fuel pump until
pressure is established then pump off, one or two full strokes of the
throttle depending on how cold the ambient air, pull the throttle
lightly closed, hit the starter button, and the engine will start within
2-5 blades (lightweight starter, two Slick mags). Hot starts are the
same except no fuel pump or stroking of the throttle.
The nearly closed throttle creates more vacuum in the carb and pulls the
rich mixture into the engine better than having the throttle 1/4 open.
If your carb idle mixture screw is set correctly, the engine should
start fine on nearly closed throttle.
Sam Buchanan
Snow, Daniel A. wrote:
start sequence is;
Master on
Throttle 1/4 open
Crank for 5 seconds
Crank for 5 seconds
Daniel Snow
n801bh(at)netzero.com Guest
Posted: Wed Apr 11, 2007 6:50 am Post subject: Hard Starting Without Primer |
The carb is an updraft one and it is located on the bottom of the motor. You need intake velocity to carry the mixture up and into the cylinders. Just as you get the motor turning over with the starter pump the throttle several times, that will spray the fuel from the accelerator pump jet into the incoming airstream and then it will be carried to the cylinders.Just pumping the throttle while the motor is not spinning will cause the fuel to puddle into the airbox,,, Just my two cents worth.. do not archive
Ben Haas
N801BH
www.haaspowerair.com
-- "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> wrote:
--> RV-List message posted by: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com>
start sequence is;
Master on
Throttle 1/4 open
Crank for 5 seconds
Crank for 5 seconds
Daniel Snow
RV-9A, 1 week to SnF, 2 weeks to inspectio======================== - The RV-List&the many List utilities such as the S================================================ - NEW MATRONIC now also available via the Web Forum==================================== [quote][b]
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Wed Apr 11, 2007 8:34 am Post subject: Hard Starting Without Primer |
Ben,
I think your two cents worth are well worth the investment. If I may I would like to add my own two cents worth;
The fuel "puddle in the airbox" and surrounding area then becomes subject to potential fire hazard conditions due to subsequent engine backfire.
It has happened to others in the past.
Reduction of fire hazard and easier starting are two of the main reasons for the addition of primmer systems.
During starting raw fuel is best introduced into the intake ports immediately ahead of the intake valve (carbureted systems) or in the cylinders (fuel injected systems).
Raw fuel in the airbox is ill advised, hard on the environment, at least partially wasted, and has been known to waste aircraft in the past.
OK, maybe three cents worth, {[
Jim in Kelowna RV6A !.5 hr.
_________________ "I never make mistreaks" |
Posted: Wed Apr 11, 2007 10:05 am Post subject: Hard Starting Without Primer |
Two things to consider:
If the result of one pump of throttle is liquid and not spray, your cranking
engine will not pull the liquid against gravity.
2nd; my method is to pump once and crank immediately before it condenses.
This allows me to set the throttle to correct position (nearly closed eg 1/8
inch from closed) for cold start.
I agree that multiple pumps will cause excess liquid fuel and is a fire
hazard, even while cranking. Multiple pumps is similar to working with
hammers and pliers when you need wrenches.
Dale
randy(at)romeolima.com Guest
Posted: Wed Apr 11, 2007 1:59 pm Post subject: Hard Starting Without Primer |
If you pump the throttle without the engine turning over to suck the fuel
from the accelerator pump in you are risking an intake fire. I've actually
seen it happen right before my eyes. Therefore I would strongly recommend
you pump the throttle AFTER you engage the starter.
Also, IIRC, while the MA4-5 carburetor used on virtually all carbureted
O-360s has an accelerator I seem to remember that many of the models for the
O-320 do not. Get the exact model number of your carburetor and do some
reasearch on it to determine whether it has an accelerator pump or not. If
it doesn't then pumping won't do any good. Once you get the model number you
can always call Precision Airmotive for confirmation...
http://www.precisionairmotive.com/
Randy Lervold
Posted: Wed Apr 11, 2007 2:07 pm Post subject: Hard Starting Without Primer |
My experience is similar to what Sam Buchanan posted.
My technique is to turn the fuel pump on, mixture rich, one pump of the
throttle, then wait for 10-20 seconds (in my case, that's about how long it
takes to fasten all of the belts). Then, throttle barely cracked and hit
the starter. The engine starts right up.
KB
bobbyhester(at)charter.ne Guest
Posted: Wed Apr 11, 2007 2:40 pm Post subject: Hard Starting Without Primer |
I only have 22 hrs on my XP-O360 and I start it just Like Ben says below and it starts just fine!
n801bh(at)netzero.com (n801bh(at)netzero.com) wrote: [quote]The carb is an updraft one and it is located on the bottom of the motor. You need intake velocity to carry the mixture up and into the cylinders. Just as you get the motor turning over with the starter pump the throttle several times, that will spray the fuel from the accelerator pump jet into the incoming airstream and then it will be carried to the cylinders.Just pumping the throttle while the motor is not spinning will cause the fuel to puddle into the airbox,,, Just my two cents worth.. do not archive
Ben Haas
N801BH
-- "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> (Daniel.Snow(at)wancdf.com) wrote:
--> RV-List message posted by: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> (Daniel.Snow(at)wancdf.com)
start sequence is;
Master on
Throttle 1/4 open
Crank for 5 seconds
Crank for 5 seconds
Daniel Snow
RV-9A, 1 week to SnF, 2 weeks to inspectio======================== - The RV-List&the many List utilities such as the S================================================ - NEW MATRONIC now also available via the Web Forum==================================== [b]
PittsS1(at)aol.com Guest
Posted: Wed Apr 11, 2007 2:47 pm Post subject: Hard Starting Without Primer |
starting ... you guys sure make it difficult
See what's free at AOL.com.
dbris200(at)sbcglobal.net Guest
Posted: Wed Apr 11, 2007 4:58 pm Post subject: Hard Starting Without Primer |
If you crank the engine with the throttle partially open, you'll draw
very little fuel into the cylinders. If the throttle is completely
closed it will pull fuel through the idle circuit and make starting a
lot easier. I learned this early on when I started flying a hand propped
Continental. You had to pull the prop through with the throttle closed
until it sounded "squishy" then crack the throttle and it started on the
first blade. If you have to pump the throttle, you're doing something wrong.
Dave
Also, a minor point, the primer and injectors both add the fuel before
the valve, not directly into the cylinder.
| Quote: | During starting raw fuel is best introduced into the intake ports
jim jewell
Posted: Wed Apr 11, 2007 6:46 pm Post subject: Hard Starting Without Primer |
Hi Dave,
You are right , I stand corrected.
Jim in Kelowna
tn3639(at)hotmail.com Guest
Posted: Thu Apr 12, 2007 3:50 am Post subject: Hard Starting Without Primer |
I have basically the same setup and all I do is pump the throttle once or
twice depending on the temperature and it fires off within one or two
blades. You may need to check your ignition system. The local spam can
rental was having the same problem and it was traced to a bad mag.
Generally if it is getting fuel, air and spark something is going to happen
pretty quick. Not to mention that you are damaging your starter with all
that cranking...
Hope this helps and let us know what happens.
Scott
start sequence is;
Master on
Throttle 1/4 open
Crank for 5 seconds
Crank for 5 seconds
Daniel Snow
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Mortgage rates near historic lows. Refinance $200,000 loan for as low as
$771/month*
https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117
Posted: Thu Apr 12, 2007 4:24 am Post subject: Hard Starting Without Primer |
As I've posted before, my Superior XP O-320 has the same MA4-5 used on
the O-360's. Someone pointed out that they could feel when the
accelerator pump was pumping fuel, however the MA4-5 has a spring
connection to the pump lever that causes the pump to move at a
semi-constant speed regardless of how quickly you pump the throttle.
Thanks for all the suggestions guys. Last night I pumped one time and
closed the throttle, followed immediately by cranking. It started in
2-3 blades. The next test is to not pump before cranking and see if the
idle circuit is enough to start the engine in a couple of blades.
Daniel Snow
| Quote: | Also, IIRC, while the MA4-5 carburetor used on virtually all carbureted
| Quote: | O-360s has an accelerator I seem to remember that many of the models
for the
| Quote: | O-320 do not. Get the exact model number of your carburetor and do some
| Quote: | reasearch on it to determine whether it has an accelerator pump or not.
If
| Quote: | it doesn't then pumping won't do any good. Once you get the model
number you
| Quote: | can always call Precision Airmotive for confirmation...
Posted: Thu Apr 12, 2007 4:41 am Post subject: Hard Starting Without Primer |
Glad to hear the good news, great progress!
Posted: Thu Apr 12, 2007 7:01 am Post subject: Hard Starting Without Primer |
This is a good point. My AFP injected O360A1D started perfectly for
several years even though I had installed the wrong Shower of Sparks
unit and it wasn't working at all, meaning that it was starting with NO
spark retard because the SkyTec starter cranked it so fast that it
didn't matter. Then when the battery started to get weak it got very
hard to start. Modifying the SOS solved the problem.
So, check the ignition system, be sure it's starting on the correct mag
and that the impulse is working.
Dave
| Quote: | You may need to check your ignition system. The local spam can rental
johnd(at)wlcwyo.com Guest
Posted: Thu Apr 12, 2007 7:55 am Post subject: Hard Starting Without Primer |
I agree with not being to aggressive about pumping the throttle when
starting.
The exception to this is when you are trying to start a very cold engine
( 0 deg or colder). I had problems starting my engine while in Rochester
MN about 4 years ago. The outside temp was -10 Deg., the plane had been
in a hanger at about 15 deg. The engine just would not start with normal
priming and a pump or two of the throttle.
One old boy told me to pump the throttle vigoursly as I cranked the
engine. I probably pumped the throttle 10 times, but the engine did
catch and began to run normally.
Just a thought.
John L. Danielson
Posted: Thu Apr 12, 2007 4:43 pm Post subject: Hard Starting Without Primer |
Your point is well taken. Here where I live in Jackson Hole Wy a 0 degree day is about half the year. . My theory was to pump the throttle while cranking the motor. As soon as it starts just use enough throttle to keep it running. On a cold day it will take several shots of fuel through the accelerator pump, of course if it is warmer then the motor will light off on the first pump, or maybe even before. !!!! YMMV..............
Ben Haas
N801BH
-- "John Danielson" <johnd(at)wlcwyo.com> wrote:
--> RV-List message posted by: "John Danielson" <johnd(at)wlcwyo.com>
starting.
Just a thought.
John L. Danielson
