503 Hard start
Scott Mac.
PostPosted: Sun Apr 08, 2007 9:16 am    Post subject: 503 Hard start Reply with quote
I'm new to Ultralights and Rotax motors and I just purchased a '91 Kolb Mk II with a 503 DDIC. The engine is equipped with a pull start. and the only time I'm successful starting this motor is if I use starting fluid. Any suggestions as to what adjustments is necessary?
Scott Mac.
MK II
occom
PostPosted: Sun Apr 08, 2007 10:46 am    Post subject: 503 Hard start Reply with quote
Sounds like it's past due for new seals.
ElleryWeld(at)aol.com
PostPosted: Sun Apr 08, 2007 11:01 am    Post subject: 503 Hard start Reply with quote
First of all DO NOT use starting fluid especially on a two stroke that gets it lube throught the fuel, install a primer pump to squirt gas in the intake manifold and you shouldnt have any problems starting but if you already have tyhat system and use it then you have other problems what type of ignition systerm and Dual or single might need more info to really help you
Ellery
See what's free at http://www.aol.com. [quote][b]
NYTerminat(at)aol.com
PostPosted: Sun Apr 08, 2007 7:27 pm    Post subject: 503 Hard start Reply with quote
Scott,
Not sure if the Bing carb is like a Rotax 912 but with the 912 the throttle must be closed to start the engine. If you open the throttle it will not start. If that is not the case then a primer will do the trick.
In a message dated 4/8/2007 2:47:26 P.M. Eastern Daylight Time, occom(at)ns.sympatico.ca writes:
--> RotaxEngines-List message posted by: "Scott Mac." <sdmacp(at)yahoo.com>
Scott Mac.
MK II
See what's free at AOL.com.
stlmusic
PostPosted: Mon Apr 09, 2007 7:14 am    Post subject: Re: 503 Hard start Reply with quote
Buy a primer pump. If I don't use the primer, it will take forever to start when cold. If I give it 3 pumps, the engine starts on the first pull. Make sure to have the enricher circuit open as well. When it's really warm outside or the engine has run in the last hour, I can modify the startup procedure.
Scott Mac.
PostPosted: Mon Apr 09, 2007 2:38 pm    Post subject: Re: 503 Hard start Reply with quote
thanks guys. I'll try the closed throttle. And if that doesn't work well then I'll look into the primer pump.
It never occured to me to consider the the lack of oil in starting fluid.
Scott Mac.
MK II
