Fox5flyer Guest
Posted: Tue Apr 03, 2007 4:31 am Post subject: Starter grinding noise |
Sounds like one of those wait 'n see things Don. Actually, pulling a 582 to
get to the starter isn't much of a deal and getting the starter off to have
a good look at it is less of a deal so if I were you, I'd pull it and check
the cause of the grinding noise. There should be some visible evidence of
it somewhere. Here's why.
Way back when, at a flyin, I prepared to leave and when I tried to start up,
the engine locked up. I could hear the starter engage, but the engine
wouldn't turn. I got out, moved the prop back and forth a few times, then
when I tried to start it, it locked again. This time I successfully hand
propped it. I then (stupidly) flew the 40 minutes home uneventfully,
wondering what sort of problem would cause that. During the flight the more
I thought about it, the more I worried about what could have been the cause,
so I pulled it into the workshop, pulled the engine and found a big surprise
that made my hair stand up. The first thing was the 4g ground strap from
the starter to the engine mount was only hanging by a couple wires, but it
was only visible with the engine out of the airplane. The next thing I
found, the one that gave me the chills, (drum roll please) was the flywheel
was cracked almost completely across. The crack emanated from one of the
gear teeth radiating inward toward the bolt hole. One side was all the way
with a gap of about 1/8 inch at the teeth. The other side didn't go all the
way and there was about an inch of metal holding the flywheel together near
the bolt hole. It was very close to coming apart! What happened when the
engine locked up (the best I could deduce) was that a starter tooth had
lodged in the crack gap causing it to bind, but moving the prop back and
forth released it. What made me cringe about it all was the thought of what
it would have been like if at 6000 rpm on a climb over hostile territory
(much of it around here) that thing decided to come apart with nothing but
that flimsy firewall between me and it.
Anyway, I called Jerry at Greensky Adventures, a Rotax guru at the time, and
he told me that there was an SB on that and he had a new and improved
flywheel for me, which I received in the mail in a few days, including new
bolts. The new flywheel was about 50 percent thicker. My engine was one of
the older 582s with a B box so I'm sure that at some point the engines were
all upgraded with the new flywheels. Something to check out if you have an
old one. You may even be able to check it with the engine in the airplane
using a mirror and good light. Pretty simple to check by serial number and
I'm sure that Lockwood or any of the Rotax reps would have information on
it. I think the SB # was SB-505-04, but I'm not sure about that. It was a
simple change out with no special tools required.
The reason I took the time to write all this Don is because of the
importance of checking out anything that doesn't sound right, especially
mechanical noises. I hope this doesn't sound like a lecture, but things
have a habit of happening in the worst possible places and at the worst
possible times. Good luck and keep us posted if you find anything else.
Deke
Ps: Here's a listing of the SBs for the Rotax 2-strokes
http://www.rotax-owner.com/sdocs.htm
Malcolmbru(at)aol.com Guest
Posted: Tue Apr 03, 2007 4:50 am Post subject: Starter grinding noise |
Don you also need to think about the starter grinding the starter gear and the metal shavings winding up on the magnets of the fly wheel and starter this happens naturally and is a maintenance cleaning issue mal
See what's free at AOL.com.
dosmythe(at)cox.net Guest
Posted: Tue Apr 03, 2007 1:09 pm Post subject: Starter grinding noise |
Deke,
I remember it well. Remember, I built it. I remember the old flywheel
thread long ago and If I remember correctly, I have the new/beefier
flywheel.
My hard decision is this, I have a real good potential buyer coming mid
next week. I need to take him for a check ride. If he decides to buy, I
can then remove the engine and make any and all repairs. I already have an
understanding with him that "we" will spend several days together doing a
full conditions inspection before I will deliver the plane to him. The big
decision??? Risk one more flight or not??
Don Smythe
Posted: Tue Apr 03, 2007 2:52 pm Post subject: Starter grinding noise |
Don,
I think you know risk = no. Even best case, if he
sees you take such a risk he will wonder what other
risks you took in construction and probably back out.
Better to git-er-done and reschedule the
flight/inspection for later.
Just my opinion,
Kurt S.
--- Don Smythe <dosmythe(at)cox.net> wrote:
| Quote: | Deke,
the new/beefier
flywheel.
Don Smythe
Don't get soaked. Take a quick peek at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
Posted: Tue Apr 03, 2007 3:42 pm Post subject: Starter grinding noise |
Kurt,
I just hate good opinions don't you? I'm going to head out early tomorrow
pull that little sucker and put it on the work bench. I had already just
about come to that conclusion but your email tipped the scale. How knows, I
just might be able to pull this off and get her back in the air by mid next
week.
Don Smythe
Posted: Tue Apr 03, 2007 6:11 pm Post subject: Starter grinding noise |
You're welcome Don,
I hear the relief. I knew you already knew the
answer. You wrote the question like you were asking
for the car keys to go out and do a little drag racing
because you were invited, but you really didn't want
to go. You knew better. You just needed an out so
you could do the right thing, which you already had a
plan for. I just confirmed it is all.
For that I'll charge you one visit next time you are
in Florida. No pre-exposure to epoxy though...
Dr Kurt S. ha ha
Noes poeseeblay archivus
[quote] Kurt,
in the air by mid next week.
Don Smythe
alnanarthur(at)sbcglobal. Guest
Posted: Wed Apr 04, 2007 7:34 am Post subject: Starter grinding noise |
Don,
How does your starter disconnect from the crank after the engine
has started? The 912 has a sprag clutch,
which is a centrifugal clutch which grabs the crank to start the
engine then as the engine goes faster then the
starter it disconnects. This is what failed in my engine. I've
looked at the drawings in the Lockwood catalog for the 582
and I don't see how this connect/disconnect is accomplished.
My starting action became jerky and sometimes the starter would spin-
up without turning the engine. Once I heard a
scraping noise.
Have you talked to Kerry at Lockwood?
Allan Arthur
Kitfox 5, N40AA
Rotax 912ULS, Warpdrive 3 blade
Byron Airport, CA (C83) Hanger C8
On Apr 3, 2007, at 4:41 PM, Don Smythe wrote:
Kurt,
tomorrow pull that little sucker and put it on the work bench. I
had already just about come to that conclusion but your email
tipped the scale. How knows, I just might be able to pull this off
and get her back in the air by mid next week.
Don Smythe
Fox5flyer Guest
Posted: Wed Apr 04, 2007 9:51 am Post subject: Starter grinding noise |
I think the 582 starter uses a Bendix type of connection, similar to an
automobile starter.
Deke
Posted: Wed Apr 04, 2007 12:57 pm Post subject: Starter grinding noise |
Allan,
My starter is similar to an auto starter. When it spins up it throws
the gear fwd to engage the flywheel. Once the engine starts, it throws is
aft again. At least, I think.
I just came home from pulling the engine. Everything lookes good and
clean with no abnormal wear on the flywheel or starter gears. There was no
evidence of metal dust anywhere.
The only thing I have left to do is pull the rear cover off the starter
and inspect the brushes. This is where I stopped until someone can tell me
what to expect when I pull that cover off. I once had a nightmare pulling
the back cover off a tractor starter. As I said before, parts flew
everywhere. Didn't you say that you have had the brushes out of your
starter. Can you tell me if there is a nightmare ahead or are there any
tricks to removing that aft cover?????
I haven't talked to anyone yet. Was waiting to get the engine out and
get a look see. I'd appreciate a quick response since I'm up against the
clock. BTW, the clutch action on my starter gear is nice a free.
Don Smythe
How does your starter disconnect from the crank after the engine has
which is a centrifugal clutch which grabs the crank to start the engine
starter it disconnects. This is what failed in my engine. I've looked
My starting action became jerky and sometimes the starter would spin- up
scraping noise.
Allan Arthur
Kitfox 5, N40AA
> Kurt,
> tomorrow pull that little sucker and put it on the work bench. I had
> already just about come to that conclusion but your email tipped the
> scale. How knows, I just might be able to pull this off and get her
> Thanks
> Don Smythe
> Do Not Archive
davef(at)cfisher.com Guest
Posted: Wed Apr 04, 2007 3:41 pm Post subject: Starter grinding noise |
Dave,
I'm trying to be a little on the rush side. However, I fully understand
that you can only rush so much. My starter is working just fine after
replacing and cleaning all the grounds and hot wires. All I want to do
right now is pull the rear end of the starter and check for any wear and
tear plus the condition of the brushes. I really feel I need to go this
extra mile since pulling the engine ain't fun. My "BIG" concern is, how
many parts fly out of the starter when the rear cover is removed? Are there
any tricks to performing this little task. I've been into a few starters
and realize they can be a bear putting back together. Just looking for some
first hand tips. If I hadn't heard that little grinding noise, I wouldn't
have pulled the engine. However by pulling the engine I've uncovered a
couple little things that did need attention. So, pulling the engine wasn't
a complete waste and might be something that others might consider if it's
been several years since first installation. If I find a problem with the
brushes, that will be the next step. I need to get this thing back 100% by
the first of next week (If possible).
Don Smythe
Float Flyr
Posted: Wed Apr 04, 2007 3:49 pm Post subject: Starter grinding noise |
It is a Bendix style engagement.
Sprague clutches are famous for chattering. It amazes me that it is Sprague
clutches that transfer the power to the rotors of most helicopters....
Without the Sprague clutch autorotation would be impossible. This is what
frightens me about the Airscooter design.... With an engine out you change
form a flying machine to an anchor with the chain let go.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Wed Apr 04, 2007 5:08 pm Post subject: Starter grinding noise |
Don,
I would call a Rotax shop to confirm your findings and get parts sent out if
needed over night ...... This is a short week though. Starter drives can
do funny things as well. Just make sure of slides ok on the splines and
thast the clutch inside that drive is working properly. Ask your Rotax guy
but it sounds electrical possibly other than the noise.
Also ask your Rotax shop for proper tightening of starter amd you check with
a feeler gauge and set for 1 mm ( about .040 ) Too tight and that starter
housing will break (300 to 350 $ for those) The Studs go throught a stack
of 2 diferent sizes of o rings.
Dave
