manliker(at)uiuc.edu Guest
Posted: Mon Apr 02, 2007 1:37 pm Post subject: Vertical Fin Height...Model 2 or 3? |
Trying to determine if my friend has a Model 2 or Model 3 Kitfox. Vertical fin height was measured as 44”. Rudder height was measured as 43.25”. Would appreciate replies from those with ready access to their Kitfox and a tape measure. Thanks.
rexinator(at)gmail.com Guest
Posted: Wed Apr 04, 2007 5:49 am Post subject: Vertical Fin Height...Model 2 or 3? |
Anliker, Mark wrote:
| Quote: | Trying to determine if my friend has a Model 2 or Model 3 Kitfox.
Vertical fin height was measured as 44. Rudder height was measured as
43.25. Would appreciate replies from those with ready access to their
My Model 2 measures 44" for both the vertical fin and rudder at the hinge.
Actually slightly under 44" by about 1/16". Can you be more specific as
to where you want the measurement taken?
(You should also be able to tell by serial number, mine is S/N 496 )
Rex
Colorado
Aerobatics(at)aol.com Guest
Posted: Wed Apr 04, 2007 2:44 pm Post subject: Vertical Fin Height...Model 2 or 3? |
In a message dated 4/2/2007 4:38:26 P.M. Central Daylight Time,
manliker(at)uiuc.edu writes:
measure. Thanks.
Hi Mark I have a 2 and its 44 inches... hmmmmmm maybe he has a 2?
good luck,
Fly today?
Dave
************************************** See what's free at http://www.aol.com
