Use of props
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Seaplane-List
cathyboone(at)softcom.net
PostPosted: Wed Mar 28, 2007 9:48 pm    Post subject: Use of props Reply with quote
I would like some opinions,
I have an S5 Kitfox and will be putting a 912ULS on in the near future. I also purchased an IVO 72" ground adjustable 3 blade, medium weight. I was thinking of mounting the IVO in the 2 blade configuration to save weight and hoping to put the plane on floats in the future. Does anyone have any experience testing the difference in performance between the 2 and 3 blade configuration?
[quote] [b]
- The Matronics Seaplane-List Email Forum -
http://www.matronics.com/Navigator?Seaplane-List
Malcolmbru(at)aol.com
PostPosted: Thu Mar 29, 2007 3:17 am    Post subject: Use of props Reply with quote
I have always felt that the 2 blade prop will give the best power . but 3 blades offer the most versatility and vibration dampening options. However I think the nickel impregnated 3 blade warp drive prop is the most durable But you start getting into problems with inertia and can have clutch problems. until you put floats under it a 2 blade warp drive will work just fine. .Malcolm Michigan
See what's free at AOL.com.
av8rps(at)tznet.com
PostPosted: Thu Mar 29, 2007 12:21 pm    Post subject: Use of props Reply with quote
Larry,
I fly the IVO 3 blade lightweight blade on my amphibious Kitfox 4 with a 912ul. It works very well, but you do have to make sure you use the stainless leading edge tape or water erosion will destroy the fibreglass blades. My Kitfox is a bit underfloated, so my prop sees a lot of water. But the prop handles it just fine with the metal tape (although you should plan on replacing the tape every year or so as it tends to crack from the blade twisting a bit in flight)
After flying a Warp prop myself on an amphibious Rans S-7 with a 912s on it, I would agree the Warp drive prop is superior when it comes to erosion. But I am pretty convinced the IVO prop will outperform the Warp for thrust. Plus the IVO is lighter, therefore you don't have gear box issues with it like you might have with the Warp.
If I were you I would just fly the plane using all 3 blades of that medium IVO. I have three friends flying the medium 3 blade IVO on 912s powered Highlanders that are amphibs, and they all love the prop. Particularly the power and the smoothness. (fwiw -they previously used the significantly more expensive sensenich 2-blade ground adjustable prop designed specifically for the 912uls, but they like the IVO better)
To tell you how well the IVO's perform, get this; My Model 4 amphib (incidentally with only 80 hp) will go 118 mph flat out. Now remember, that is on floats! (see attached pic) My reduced cruise speed (5000 rpm) is between 100-105 mph TAS. And it will climb with me and a full tank of fuel on a warm day at 1400 fpm. I've not found another combination of engine and prop that will do that on a floatplane. So I am pretty well sold on the 912 and the IVO combination. And fwiw - I do have a 912s that I plan on bolting in place of my 80 hp one of these days. And when I do, I will be installing an IVO 3 blade medium on that new engine (can seaplane pilots ever have enough power?) When I have this combination installed you just might see me out flying alongside my Cessna 180 and 185/206 floatplane buddies <GRIN>
Paul Seehafer
 Filesize:  99.69 KB
 Viewed:  778 Time(s)
PostPosted: Thu Mar 29, 2007 8:46 pm    Post subject: Use of props Reply with quote
Thanks Paul for sharing your experience and information. Do you remember the length of their IVO props?
av8rps(at)tznet.com
PostPosted: Wed Apr 04, 2007 1:30 pm    Post subject: Use of props Reply with quote
Larry,
I believe they are 72 inch diameter 3 blade mediums.
Paul
PostPosted: Mon Apr 09, 2007 8:31 am    Post subject: Use of props Reply with quote
Thanks Paul,
I purchased the 72 inch medium weight. It sounds like I will be in good shape or at least a good starting place.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Seaplane-List All times are GMT - 8 Hours
