Posted: Sun Apr 01, 2007 9:46 am Post subject: VW Redrive Update |
Valley Engineering has been working on and testing a update of the redrive that I have been using on my VW powered Kolb. The update is designed to solve the harmonic vibration issue that I have had. This is the same design of redrive that they are using on their V twin powered "backyard flyer". I'm still asking questions but everything I have heard so far sounds like a major improvement. The harmonic dampening comes from a spring loaded tensioner on the slack side of the ribbed drive belt. If everything checks out I may be the first customer. Hopefully not a test pilot. They as always are very good to me and will be offering a trade in/trade up on my old drive for some unspecified, at this time, amount. The attached is a photo of their new redrive.
Rick Neilsen
Redrive VW powered MKIIIC
23.09 KB |
682 Time(s) |
JetPilot
Posted: Sun Apr 01, 2007 10:03 am Post subject: Re: VW Redrive Update |
Belts are a problem, always breaking, or stripping thier teeth. The are good for driving alternators etc.., but for spinning a prop I would much rather have gears. Rotax did good when they put gears in all thier engines rather than going with some cheap, jury rigged solution.
Redrive units have a terrible record. I hope you dont hurt yourself or tear up your plane when that thing fails.
Kolb MK-III Xtra, 912-S |
Posted: Sun Apr 01, 2007 10:22 am Post subject: VW Redrive Update |
At 11:03 AM 4/1/07 -0700, you wrote:
Ron,
139+ hours on the first belt and it still looks very good.
Jack B. Hart FF004
Winchester, IN
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Sun Apr 01, 2007 10:46 am Post subject: Re: VW Redrive Update |
| Quote: | | Rotax did good when they put gears in all thier engines rather than going with some cheap, jury rigged solution. |
Rotax did do well with their gear box design. This, however, does not mean that a belt drive is a "cheap jury rigged solution." Besides, if it is jury rigged, is it really a solution?
Last year we replaced the gears in one of our chopping machines at work(45HP main drive) with a belt drive system of our own design. We have not had a failure yet. Before the upgrade we were losing $3000 worth of gears every 2-3 weeks. One must simply match the design to the application. A well designed belt drive will outperform a poorly designed gear drive and vice versa.
My two cents... Do Not Archive
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
Posted: Sun Apr 01, 2007 11:29 am Post subject: VW Redrive Update |
Mike/All
I agree that a gear reduction drive would seem to be a better solution if it
designed for its application. There are a few universal redrives available
that might work for a VW but without the proper engineering there is a much
better chance of it failing or causing something else to fail than with my
old belt redrive. As for a universal statement that belts are cheap, jury
rigged, and have a terrible record, this isn't the case. This drive
manufacture has hundreds of drives on the market with a good record. This
redrive has had only one failure that I know of (in my plane and no it
didn't hurt me or the plane). The part that failed wasn't the belt, it was
beefed up and is working well. All old drives and drives since now use the
stronger part. This new drive is a evolutionary improvement. As with all
their drives they install, they have more than one belt (my old drive has
three) and test run with one belt to make sure it will carry the load by
itself. Belts do wear and need to be replaced. My current drive belts have
all most a hundred hours on them with no wear. If the new drive belts wear
slightly more but give me a silky smooth operation its a good trade.
I'm not inclined to spend the big bucks for a Rotax motor. With all the work
and money I have spent over the years I could have purchased a 912. But I'm
getting close to a almost as reliable engine package with similar power that
people can put together for one third the price of a 912 and rebuild costs
will be less than a 912 gasket set.
Normally I don't respond to off the cuff comments like this but....
Rick Neilsen
cspoke
Posted: Sun Apr 01, 2007 1:21 pm Post subject: Re: VW Redrive Update |
Rick,
I am very interested in this new drive for the VW. I am building a MK111 xtra and I am just about to the point of deciding which engine I will use. Do you know if Valley Engineering will be at Sun n Fun?
_________________ Craig Spoke
Mark111 Xtra
VW Redrive
Lillian, AL
cspoke@mediacombb.net |
jrsmith2(at)triad.rr.com Guest
Posted: Sun Apr 01, 2007 5:14 pm Post subject: VW Redrive Update |
Dear Jack, I know Rick Neilsen has a redrive VW powered MKIIIC
Jack B. Hart FF004
Winchester, IN
captainron1(at)cox.net Guest
Posted: Sun Apr 01, 2007 6:09 pm Post subject: VW Redrive Update |
Hi Rick do they have a web site?
I need a price list.
Ron (Arizona)
Rick Neilsen
kugelair.com
possums(at)bellsouth.net Guest
Posted: Sun Apr 01, 2007 9:58 pm Post subject: VW Redrive Update |
At 03:22 PM 4/1/2007, you wrote:
| Quote: | --> Kolb-List message posted by: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Mike/All
Rick Neilsen |
Me either - since 1999 - when I joined this list with 1,200 UL hours and was a
lot "smarter", about pretty much everything to do with ultalights, including
Kolbs, reduction drives, props, rivets, oil, VG's, etc.
The older I get, the dumber I was.
So I was thinking about adding this as a "sign off" on all my emails -
but, again it is too long.
Dear Sirs:
I would like to offer an apology for my actions of last night. There was no
malice intended. I understand you may not appreciate the humor of my
message; I agree, it was in poor taste and went entirely too far. Again, it
was not meant for the "Kolb List" per se, but since the damage is already
done. I'd like to stress that none of the people listed in my remarks had
anything to do with the list, either by technical assistance or moral
support-except of course "Big Lar", "Beauford" John H. and their like. I
simply chose them because they are names you would recognize and I can
blame (that's what friends are for]. I can't offer any proof of this, but
ask that you accept it anyway. As this is the normal way we treat
"yearlings"-(JetPilot - Put-your-name-here,- I have a whopping 100 hours on my 503).
Possum First Class "yearling" would indicate 100 hrs or one year in service.
But, again, I would like to offer my deepest apologies and my hope that the
damage I have done (even though it was unintentional) can be fixed.
I ask that you use what influence you have to convince others that what
happened was the work of a thoughtless individual, not an entire squadron and
I am truly sorry.
I would like to be able to tell you that this sort of thing will never
happen again, but frankly, I can't make that commitment,
kiwimick
Posted: Mon Apr 02, 2007 9:33 am Post subject: VW Redrive Update |
Sorry but I think that is rubbish, I have hundreds of hrs on belt drive
engines with no probs.
Also Harley and Buel motorcycles are belt driven and you don't see them
snapping all the time and they are transmitting more power and more
aggressively than a VW conversion turning a prop.
Mike Moulai
Jabiru Xtra
_________________ Mike the kiwi Kolber in England....... |
Posted: Mon Apr 02, 2007 12:01 pm Post subject: VW Redrive Update |
That's a very good point!
Ron (Arizona)
---- mike moulai <kiwimick(at)sfmicro.fsnet.co.uk> wrote:
--> Kolb-List message posted by: "mike moulai" <kiwimick(at)sfmicro.fsnet.co.uk>
Mike Moulai
Jabiru Xtra
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Sat Apr 07, 2007 10:18 am Post subject: Re: VW Redrive Update |
| Quote: | | Belts are a problem, always breaking, or stripping thier teeth. The are good for driving alternators etc.., but for spinning a prop I would much rather have gears. |
Was comparing two ribbed drive belts the other day (about 3" wide x 24" circumference). Could hardly tell the difference between them.
One was brand new, the other had 1,000 hrs on it !
