Comant installation question
jaybrinkmeyer(at)yahoo.co
PostPosted: Thu Mar 29, 2007 11:17 am    Post subject: Comant installation question Reply with quote
For those of you who attached Comant antennas on the fuse underside...
Where exactly did you rivet your Comant doublers beneath the rear seats? The
2nd bay in or really in the outboard-most bay? Did you install the doublers and
wire up the antennas and then rivet in the floor or did you save the floor
final attach for later? I'm thinking I'll bugger up the antennas if I put 'em
on now and close up the floors.
Anyone have any photos of the actual installation?
Thanks in advance,
Jay
TV dinner still cooling?
Check out "Tonight's Picks" on Yahoo! TV.
http://tv.yahoo.com/
recapen(at)earthlink.net
PostPosted: Thu Mar 29, 2007 11:35 am    Post subject: Comant installation question Reply with quote
I've got photos of what I did for my 6A...It's underneath the right seat. Since I nutplated in the seatbottom, I decided to make the antenna removable, dimpled the attach screw holes and made a second plate to cover the center hole.
Zap me direct......
indigoonlatigo(at)msn.com
PostPosted: Thu Mar 29, 2007 11:47 am    Post subject: Comant installation question Reply with quote
My antenna is beneath the baggage floor. I did the doubler, rivetted it in
place but did not instal the antenna in. I have three access panels in the
bagggage floor. one for the antenna, one for each of the side step bolts. In
my case, anything down there is going to get wacked as I move it out of my
building area.
To: RV10 <rv10-list(at)matronics.com>
Subject: Comant installation question
Date: Thu, 29 Mar 2007 12:16:45 -0700 (PDT)
The
and
'em
Thanks in advance,
Jay
millstees(at)ameritech.ne
PostPosted: Thu Mar 29, 2007 11:48 am    Post subject: Comant installation question Reply with quote
Jay:
I just installed my Comant bent whip antenna (CI-122) under the left back seat (just 1 antenna), 1 bay outboard of the center channel, and about 4" aft of the aft spar. I installed a doubler with nut plates attached to the doubler, so the antenna can be removed. I have not downloaded the pictures yet; if you would like to see them, I can get the to you tomorrow.
Steve Mills N750SM (reserved)
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
LarryRosen
PostPosted: Thu Mar 29, 2007 11:51 am    Post subject: Comant installation question Reply with quote
Photos of how my antenna location and doublers are here
<http://lrosen.nerv10.com/Construct/Log/Fuselage/ComAntennaDoubler/index.html>
I fabricated an access panel above.
On my next RV-10 build Wink I would install it just forward of the rear
seat, under the flap torque tube.
Larry Rosen
#356
Thanks in advance,
Jay
Larry Rosen
#40356
N205EN (reserved)
<http>
jwt(at)roadmapscoaching.c
PostPosted: Thu Mar 29, 2007 3:58 pm    Post subject: Comant installation question Reply with quote
Here is my Comant mount under the rear seat. I put the wire in and dropped
it out the bottom and then sealed up the floors. The antenna mounts from the
outside with platenuts.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Paint prep and LOTS of misc stuff
 Filesize:  645.47 KB
 Viewed:  181 Time(s)
