Jack photos
speckter(at)comcast.net
PostPosted: Wed Mar 28, 2007 4:47 am    Post subject: Jack photos Reply with quote
From: Gary Specketer [mailto:gspecketer(at)hotmail.com]
Sent: Wednesday, March 28, 2007 8:38 AM
To: speckter(at)comcast.net
Subject: FW: Jack photos
Here are some pictures of a simple jack. It can be carried on the plane and weighs only a few ounces. It consists of a 24” cable that is dropped between the break disc and the wheel pant mounting plate. For your home base you can get fancier for the blocks and lever, but this loop allows you to have it with the plane at all times.
[i]Gary[/i][i] [/i]
 Filesize:  63.29 KB
 Viewed:  223 Time(s)
 Filesize:  75.09 KB
 Viewed:  226 Time(s)
 Filesize:  67.89 KB
 Viewed:  205 Time(s)
 Filesize:  96.06 KB
 Viewed:  216 Time(s)
 Filesize:  96.01 KB
 Viewed:  191 Time(s)
 Filesize:  89.44 KB
 Viewed:  212 Time(s)
 Filesize:  80.99 KB
 Viewed:  207 Time(s)
 Filesize:  72.38 KB
 Viewed:  219 Time(s)
Deems Davis
PostPosted: Wed Mar 28, 2007 7:16 am    Post subject: Jack photos Reply with quote
Gary, what a great and simple idea!
THANKS
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
gary wrote:
pitts_pilot(at)bellsouth.
PostPosted: Wed Mar 28, 2007 7:19 am    Post subject: Jack photos Reply with quote
Now that's the slickest thing I've seen in a long while!!!
Amazing how the simplest things escape us!
Linn
gary wrote: [quote]
From: Gary Specketer [mailto:gspecketer(at)hotmail.com (gspecketer(at)hotmail.com)]
To: speckter(at)comcast.net (speckter(at)comcast.net)
jjessen
PostPosted: Wed Mar 28, 2007 7:51 am    Post subject: Jack photos Reply with quote
What a great idea! Looks like it might be a little unsteady side to side. Is that an issue at all?
John Jessen
40328
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of linn Walters
Sent: Wednesday, March 28, 2007 9:18 AM
Subject: Re: FW: Jack photos
Linn
gary wrote: [quote]
PostPosted: Wed Mar 28, 2007 8:03 am    Post subject: Jack photos Reply with quote
Stability is not an issue. Actually without the wing on I can lift the plane with just a 3 foot board. By the way I used a 3/32 cable and had to flatten the nicropress slightly to get it to slide through after I put on the clear shrink tube.
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen
Sent: Wednesday, March 28, 2007 11:50 AM
Subject: RE: FW: Jack photos
John Jessen
40328
Linn
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com
jjessen
PostPosted: Wed Mar 28, 2007 8:24 am    Post subject: Jack photos Reply with quote
That's right. The other wheel is on the ground, so side-to-side movement, if any, is a none factor.
40328
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary
Sent: Wednesday, March 28, 2007 9:04 AM
Gary
40274
John Jessen
40328
Linn
5 [quote][b]
