raimo.toivio(at)rwm.fi Guest
Posted: Wed Mar 28, 2007 2:06 am Post subject: A Long Pin |
All
Do you have any idea where to get
a long pin to install to the root of the
flap? I mean about ½ inch longer than
the standard pin which is about 1" long.
Or is it any way to make the original one
longer by lenghtening it some how?
My purpose is to change it just to aid rigging.
I have some difficulties to rigg the port side wing.
The bearing in the flap cross tube turns away
when the pin try to go inside. Finally when rigged,
all is just perfect and the flaps moves 27 degrees.
I think when the pin is longer, it could go in more easily
(before those wing root fore and aft pins).
I found some talkings about this topic.
It was on the forum 13/3/2002. Somebody had exactly
same problem. Andy D wrote the bearing should move
only 5 degrees. Is that really so? My bearing is turning
VERY easily 360. I tied to contact him (PFA) but did
not get any comment (I am a PFA-member).
Any other ideas to solve my rigging problem?
My port side wing takes one hour to go in - stbd side one minute.
Regards, Raimo
Raimo M W Toivio
OH-XRT Europa XS Mono #417, completed
OH-CVK C172 Skyhawk, under reinterioring
OH-BLL Beechcraft C45, w radial engines (grounded)
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
www.rwm.fi
hansjd(at)online.no Guest
Posted: Wed Mar 28, 2007 6:10 am Post subject: A Long Pin |
Raimo,
I had the same problem. I made a "pig-dick" out of Redux/flox and put it on
the tip of the flap-pin (thick mixture).I made it into a cone and after cure
sanded it smooth. Bevare not to sand the pin itself, though. I roughened and
degreased the very tip of the pin before applying the mixture. After
lubrication the pin - with plenty of lubrication - hits the hole before the
wing pins enters. The bearing orientates nicely on the pin and rigging goes
effortless. The cone is ca. 2.5 cm long.
Hope this helps.
Hans
Posted: Wed Mar 28, 2007 11:32 am Post subject: A Long Pin |
Hans,
I thought it is impossible to glue anything
to the top of the pin but if your cone is
still there, it must be a way to the happy
rigging.
Thank you for a nice advice, Raimo
daseitz(at)cfl.rr.com Guest
Posted: Wed Mar 28, 2007 11:42 am Post subject: A Long Pin |
If you make the pin longer it may hit the side of the tube when it slide in
binding the flap movement, it goes in at an angle. The best way is the cone
extension like Hans said. I did mine like that too. The cone is angled and
does not interfere with the movement.
Dean Seitz
NevEyre(at)aol.com Guest
Posted: Wed Mar 28, 2007 12:32 pm Post subject: A Long Pin |
Ramio,
Ensure the spherical bearing is driven fully into the tube end fitting, if it is not all the way in, it will rotate as you have described, when fully inserted, the rotation should be limited so as not to '' go blind ''
Nev.
DanBish
Posted: Wed Mar 28, 2007 1:58 pm Post subject: A Long Pin |
You can find ball lock pins of just about any size or style at McMaster Carr (http://www.mcmaster.com/). Do a search on "ball lock pin" to pull up the results. Make sure you measure carefully following their instructions.
Dan
Visit - www.EuropaOwners.org
Posted: Wed Mar 28, 2007 4:19 pm Post subject: A Long Pin |
Nev
I have a vague memory that the bearing is not symetrical (back to front)
If put in wrong the spere will rotate, the oter way it is restrained by
the housing. Is this right, it's ten years since I last did this job??
Graham
NevEyre(at)aol.com wrote:
| Quote: | Ramio,
Nev.
Graham Singleton
Tel: +441629820187
Mob: +447739582005
hurstkr(at)redzone.com.au Guest
Posted: Wed Mar 28, 2007 5:03 pm Post subject: A Long Pin |
Gidday G,
| Quote: | I have a vague memory that the bearing is not symmetrical (back to
front)
If put in wrong the spere will rotate, the other way it is restrained by
the housing.
Can't look right now but I'm sure my bearings have a flange on the outer
casing and can only go in one way.
Cheers
Kingsley
Posted: Thu Mar 29, 2007 12:52 am Post subject: A Long Pin |
Hey K!
the outer casing has a flange, that's a Europa part, the bearing
assenmbly could go into it either way I think. The sphere protrudes more
on one side than the other so if the protrusion is put in first it will
be restrained from rotating too much by the hole in the outer casing.
Graham
Kingsley Hurst wrote:
Gidday G,
front)
the housing.
Cheers
Kingsley
Graham Singleton
Tel: +441629820187
Mob: +447739582005
Posted: Thu Mar 29, 2007 4:29 am Post subject: A Long Pin |
Nev, Graham, Kingsley and all the other Great Pin Men
I checked MY case and...
- bearings are fully inserted
- port side rotates 360 any direction very sensitively
- that is why it is difficult to rigg the port side wing
- stbd side rotates like port side but its quite tight
- that is why it is easy to rigg the stbd side wing
- MY bearings (sphere part of it) are symmetrical
- bearing outer casing has a flange, so it cannot go any deeper
- like Kingsley wrote they can go in only one way
Is it possible there are two kind of the flap bearings???
Fully rotating models and restricted models???
If somebody will find a truth /solution of this case,
please let me know. I will be this eve in the workshop
trying to find some comprehension and will check my mail
regularly.
I am very tempted to make my pin longer by adding
a cone shape part to it (build by redux-flox). One
builder found a way to sky by building a nice little ½" cone.
Thanks, Raimo
karelvranken(at)hotmail.c Guest
Posted: Thu Mar 29, 2007 1:36 pm Post subject: A Long Pin |
Raimo,
I rotate the bearing ball by the finger for about 20° and it never goes
inside. So if you can push the ball outside the bearing than there is
something wrong with the bearings.
Karel Vranken #447 F-PKRL
Posted: Fri Mar 30, 2007 3:18 am Post subject: A Long Pin |
Karel,
our common and prestigious friend - Dirk -
checked my plane and also those bearings
couple of months ago as you know. He did
not noticed anything wrong with the bearings.
He said only "they are very /too sensitive
- try to take all the grease away to aid rigging".
The ball is about 2 mm out of the bearing flange.
If I turn it 180 degrees, it is again 2 mm out of
the bearing = it is symmetrical.
So, my guess is: there are two kind of the flap
bearings in use on the Europa-market:
w restricted and unrestricted movements.
Could you please send me a close-up photo of
your bearing?
Regards, Raimo
Posted: Fri Mar 30, 2007 9:49 am Post subject: A Long Pin |
Raimo
it is not the ball that's assymetric, I think it's the journal it is
mounted in. Then, when it is placed in the receptacle wrong way it
doesn't protrude quite as far in the housing centre hole.
I habvn't looked in the Europa manual, mine is hidden in a box somewhere!
Graham
Raimo Toivio wrote:
Karel,
your bearing?
Regards, Raimo
ami(at)mcfadyean.freeserv Guest
Posted: Fri Mar 30, 2007 12:12 pm Post subject: A Long Pin |
The ball assembly (i.e. ball and its non-detachable outer race) need to be
placed right in to the bearing carrier (i.e. the part that fits in to the
end of the flap operating tube). Otherwise the ball will turn 180+deg.
The bearing carrier has a lip protruding on the inner diameter that prevents
the ball turning more than a few degrees, when properly registered.
Or, if the ball assembly if a loose fit in the carrier, then as the ball
turns it will push itself out against the inner lip to allow 180 deg ball
rotation.
Duncan McF.
Graham
yes - the ball is symmetric and the journal box is assymmetric,
because it has a flange. At least my journal box has a flange.
That´s why it is impossible to intall the journal box wrong way
in the receptacle. Just like Kingley stated.
Europa manual does not give a light.
I got a message from one builder&operator from the States:
he has really got two kind of bearings; a fully rotating one and
a restricted one. He has problems w restricted one (of course!).
"I have this problem. Interestingly enough one ball rotates completely
and the other doesn't and there is no obvious difference."
So, my guess was right. There are two kinds of the flap bearings.
Think it is basically the guestion of quality (or lack of it).
Have to live (and rigg) with it.
Cheers, Raimo
Raimo M W Toivio
OH-XRT Europa XS Mono #417, completed but not easy to rigg (port side wing so far)
OH-CVK C172 Skyhawk, under reinterioring, almost completed
OH-BLL Beechcraft C45, w radial engines (grounded), the firing day will come
37500 Lempaala
Finland
www.rwm.fi
Posted: Fri Mar 30, 2007 12:46 pm Post subject: A Long Pin |
Raimo,
Meanwhile I saw your answer to Graham. Now you are to the point. Look at the
pictures I made. Number one and two are with extreme left and extreme right
position. You barely can see the difference. So this means that the movement
is restricted. Number three shows the pin in the flap. You will notice that
I made a cone to guide the rod with the bearing to the pin and no rigging
problems.
Karel Vranken, # 447 F-PKRL
163.01 KB |
315 Time(s) |
171.01 KB |
327 Time(s) |
183.01 KB |
359 Time(s) |
Posted: Fri Mar 30, 2007 1:01 pm Post subject: A Long Pin |
Raaimo
Duncan explained it better than I did but there are three parts to the
assembly
1 sphere
2 bearing journal
3 bearing carrier/bearing box
It seems one of your bearings is not fully entered into the bearing
carrier. That's why the spre can rotate 360
Graham
Raimo Toivio wrote:
Graham
josok-e(at)ukolo.fi Guest
Posted: Fri Mar 30, 2007 2:54 pm Post subject: A Long Pin |
Raimo,
The bearing that is rotating, is not deep enough in the socket. Take a
tube on the outer ring and hit it, while someone supports the other end of
the flap tube. That should move it the millimeter that is missing.
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
mono xs, at the painter, continuing on the panel.
Posted: Fri Mar 30, 2007 4:22 pm Post subject: A Long Pin |
Jos
I think you hit the nail on the head!
G
Jos Okhuijsen wrote:
Raimo,
of the flap tube. That should move it the millimeter that is missing.
Graham Singleton
Tel: +441629820187
Mob: +447739582005
Posted: Fri Mar 30, 2007 10:20 pm Post subject: A Long Pin |
In a message dated 31/03/2007 01:23:43 GMT Standard Time, grahamsingleton(at)btinternet.com writes:
Jos
G
| Quote: | --> Europa-List message posted by: "Jos Okhuijsen" <josok-e(at)ukolo.fi>
Raimo,
Hey Guy's, that is what I said three days ago............................................................
Cheers, Nev.
