Firestar bowling
Goto page 1, 2  Next
lcottrell
PostPosted: Mon Mar 19, 2007 10:33 am    Post subject: Firestar bowling Reply with quote
Two years ago while at the Alvord gathering after MV, Roger Hankins had brought a bowling ball with him on his trip. He first dropped it from 2000 feet, which caused a lot of consternation and possibly flash backs for John H and John W. I was going to film it, but decided that if I did I would never see it through the view finder. I must say it was a memorable event that probably should not be repeated. The sound of the wind through the finger holes was quite unnerving. After John H, Gary Haley and John W had departed, Roger began to wonder how far a ball would roll given the proper speed. I would suggest that if you do this for your self, you should strive to do it on a fully dry portion of the lake bed. If you look closely you can see the mud rooster tail in the last part of the roll.
http://video.google.com/videoplay?docid=6829470231367079848
Larry, Oregon
PostPosted: Mon Mar 19, 2007 11:01 am    Post subject: Firestar bowling Reply with quote
"He first dropped it from 2000 feet, which caused a lot of
Larry, Oregon"
Larry C:
The closer that ball got to the ground the more it looked like it was
going to hit me between the eyes. I stared at it for a few seconds,
chickened out, did a 180, and hauled ass. If it was going to hit me,
it was going to hit me in the butt. Wink
DO NOT ARCHIVE
planecrazzzy
PostPosted: Mon Mar 19, 2007 1:18 pm    Post subject: Re: Firestar bowling Reply with quote
Back when I was going for my Private Ticket...I used to belong to AOPA
mostly to use their weather site....
But in the back of one of their magazines , they asked questions....
One of their questions was: Is it legal to drop a bowling ball from a plane?
The answer is YES , but yer responsible for where it lands....
Gotta Fly...
Mike & "Jaz" in MN
PostPosted: Mon Mar 19, 2007 1:31 pm    Post subject: Firestar bowling Reply with quote
a plane?
| Mike
Mike:
How else ya gonna practice bombing?
DO NOT ARCHIVE
a58r(at)verizon.net
PostPosted: Mon Mar 19, 2007 1:55 pm    Post subject: Firestar bowling Reply with quote
Usta be somewhere in the FAA Rocks & Shoals (regs) bout dropping
stuff NLT grains of sand! S'pose inflation got to that, also.
regards,
Bob N. FireFly 070 Old Kolb
d-m-hague(at)comcast.net
PostPosted: Mon Mar 19, 2007 3:20 pm    Post subject: Firestar bowling Reply with quote
I don't know where that was (or is), but I recall it too. It was in
reference to gliders (or maybe it was balloons) jettisoning ballast, which
could only be "water or loose sand". I guess the idea was that unlike
larger objects, you didn't have to worry about where you dropped it.
-Dana
The citizens of the United States are getting the government they deserve.
The problem is that I'm also getting the government they deserve.
biglar
PostPosted: Mon Mar 19, 2007 3:46 pm    Post subject: Firestar bowling Reply with quote
It wouldn't open for me. Anyone else have this problem ?? Lar. Do not Archive.
On 3/19/07, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote: [quote] Two years ago while at the Alvord gathering after MV, Roger Hankins had brought a bowling ball with him on his trip. He first dropped it from 2000 feet, which caused a lot of consternation and possibly flash backs for John H and John W. I was going to film it, but decided that if I did I would never see it through the view finder. I must say it was a memorable event that probably should not be repeated. The sound of the wind through the finger holes was quite unnerving. After John H, Gary Haley and John W had departed, Roger began to wonder how far a ball would roll given the proper speed. I would suggest that if you do this for your self, you should strive to do it on a fully dry portion of the lake bed. If you look closely you can see the mud rooster tail in the last part of the roll.
Larry, Oregon
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
Eugene Zimmerman
PostPosted: Mon Mar 19, 2007 4:16 pm    Post subject: Firestar bowling Reply with quote
Hey Lar,
Worked fine for me.
Larry, Oregon
www.matronics.com/Navigator?Kolb-List _-
pj.ladd(at)btinternet.com
PostPosted: Tue Mar 20, 2007 2:10 am    Post subject: Firestar bowling Reply with quote
It was in
could only be "water or loose sand". >>
The difference is that water doesn`t fall in one lump. Neither does sand as
balloonists normally drop it in handfulls. If they cut loose a sack then
thats a different story. The authorities woudn`t like that,
Cheers
Pat
PostPosted: Tue Mar 20, 2007 2:14 am    Post subject: Firestar bowling Reply with quote
a plane?>>
In my gliding days we used to take `puffballs` ( a large type of mushroom)
in the two seater on wire launches and try to drop them on the winch
operator. We had an ex barrage balloon winch with a cage to protect the
operator in the case of a cable fail;ure. If you hit the cage with a
puffball it would break into a cloud of bits and nearly choke the poor guy.
Cheers
Pat.
PostPosted: Tue Mar 20, 2007 2:22 am    Post subject: Firestar bowling Reply with quote
Hi,
loved the bowling ball video. Bit dicey! A bit bigger bounce could have hit the tail. You should have put the music from the Dam Busters on the sound track.
Cheers
Pat
JetPilot
PostPosted: Wed Mar 21, 2007 3:30 pm    Post subject: Re: Firestar bowling Reply with quote
DO NOT ARCHIVE
Hahahaha,
I about fell out of my chair laughing when I read that Smile How far did the ball hit from where you had been standing ? What did the 2000 foot fall do to the bowling ball ?
Kolb MK-III Xtra, 912-S
R. Hankins
PostPosted: Wed Mar 21, 2007 8:06 pm    Post subject: Re: Firestar bowling Reply with quote
Here are a couple of pics of the ball and the splat-mark. It did far less than I had expected to the mud, but had a greater effect on the spectators than I anticipated. If I do it again it will be farther than 100yds from camp.
 Filesize:  244.96 KB
 Viewed:  745 Time(s)
 Filesize:  162.33 KB
 Viewed:  684 Time(s)
 Filesize:  249.85 KB
 Viewed:  618 Time(s)
Roger in Oregon
1992 KXP 503 - N1782C
R. Hankins
PostPosted: Wed Mar 21, 2007 8:08 pm    Post subject: Re: Firestar bowling Reply with quote
Now, if I could just get my hands on a watermellon.......
Roger in Oregon
PostPosted: Thu Mar 22, 2007 1:58 pm    Post subject: Firestar bowling Reply with quote
My home airport just closed (the usual, housing development Sad ). There
was a lady who lived across the river who hated airplanes of any kind. If
you were a bit low or close on downwind, she was on the phone to the
airport manager to complain before you turned final. One day I was flying
a Quicksilver and she took and emailed pictures of me to "prove" that I was
directly over her house (I wasn't, as the pictures clearly showed). A
local PPC pilot always said he was going to bring a watermelon up on the
last day of the airport with her chimney a target. Fortunately he wasn't
as crazy as he talked...
-Dana
JetPilot
PostPosted: Thu Mar 22, 2007 2:51 pm    Post subject: Re: Firestar bowling Reply with quote
Man that looks like fun Smile I need to find a supply of cheap bowling balls, I am dreaming up all sorts of stuff... What would it look like if it hit concrete, water, a old car, etc. etc. How high would I need to drop to get it to terminal velocity ? Even set up a video camera at the drop. The possiblities are endless !!!
ceengland(at)bellsouth.ne
PostPosted: Thu Mar 22, 2007 5:23 pm    Post subject: Firestar bowling Reply with quote
There's a story & video out in the wild somewhere about some
homebuilders disposing of a farmer's excess pumpkins. After various runs
they heard a call on the radio from a B-25. Imagine a 'stick' of
pumpkins leaving the bomb bay...
possums(at)bellsouth.net
PostPosted: Thu Mar 22, 2007 7:04 pm    Post subject: Firestar bowling Reply with quote
Fortunately he wasn't as crazy as he talked...
-Dana
Oh!...... come on, you guys can't tell me that at least some of you
haven't done watermelon drops before.
I don't mean on houses near the airport - but at your flyins at least??
rap(at)isp.com
PostPosted: Sat Mar 24, 2007 8:01 pm    Post subject: Firestar bowling Reply with quote
Bowling balls are tough we shot one with a old 308 military round and only
put a 1"chip in it.
planecrazzzy
PostPosted: Sun Mar 25, 2007 4:18 am    Post subject: Re: Firestar bowling Reply with quote
10 mph faster per sec.....12 sec ....Terminal velocity - 120 mph
If yer gonna jump off a building....you don't need to go higher than
the 12 floor....
Gotta Fly...
Mike & "Jaz" in MN
Goto page 1, 2  Next
Page 1 of 2
