effectus(at)rogers.com Guest
Posted: Sat Feb 04, 2006 4:54 pm Post subject: Trim Cable Anchor Bracket Installation |
Listers,
I received my two trim cable anchor brackets from Dave the other day via UPS. Dave provided a great service and I would recommend that you all get your orders in. This is a great fix to a poorly designed bracket. I just finished replicating the two cover plates that they attach to. This had to be done because the bolt pattern is different from the original brackets. It took me about 2 hours to draw and cut them out of the aluminum pieces that came with the emp kit.
I have decided that I want to be able to remove them from the access cover so I have dimpled the access cover and countersunk the bottom of the bracket. I am going to install them using stainless AN507C-632R6 screws with AN365-632 lock nuts. People have commented about the inability to rotate the older nut when mounted to the access plate. I felt that it would be much easier to adjust the cable relative to the anchor bracket by spinning the anchor bracket around the cable. I now have only to remove the cover screws and detach the anchor bracket from the cover to adjust/service the cable.
I hope this helps.
Dave Hertner
40164 - Emp finished ordering QB balance of kit.
william(at)gbta.net Guest
Posted: Sun Feb 05, 2006 6:51 pm Post subject: Trim Cable Anchor Bracket Installation |
Dave, could you post a pic of you trim tab brackets when installed??
DO NOT ARCHIVE
