flystol(at)bluebottle.com Guest
Posted: Mon Mar 12, 2007 3:12 pm Post subject: Strapping the Stab |
Hi All,
Relative newbie lurker here. I have started my 601XT with kits from Zenith. Rudder went together fine. I am now on the stab and have what may be a dumb question.
Here goes - the kit comes with alignment holes drilled for the skin. I have attached the lower side, turned everything over and am ready to close. If I follow the procedure of using the straps to pull everything into alignment, I quickly pull the forward flange pre-drilled holes in the skin past the center line of the flange.
Shouldn't I just line up the holes with the midline I have drawn on the flange, drill and cleco? Wouldn't that guarantee alignment of the rest of the skin?
What am I misssing here?
Do not archive.
Ron
601XL San Diego
Not making enough money? Click here to get free info on medical jobs
http://tags.bluebottle.com/fc/CAaCMPJk1mHgOrC1zqUDm2q69eiiqXS2/
p.mulwitz(at)worldnet.att Guest
Posted: Mon Mar 12, 2007 3:39 pm Post subject: Strapping the Stab |
Hi Ron,
I think that is a question for Zenith tech support. Most of us
(including me) didn't have the predrilled holes you have and we have
not experienced this sort of problem. Perhaps there is a problem
with the holes or maybe not.
Paul
XL fuselage
At 03:12 PM 3/12/2007, you wrote:
Hi All,
Do not archive.
Ron
601XL San Diego
naumuk(at)alltel.net Guest
Posted: Mon Mar 12, 2007 4:18 pm Post subject: Strapping the Stab |
Ron-
Did you have the correct spacers under the skeleton and everything
nailed down before attaching the bottom? You should have your spar clamped
to L blocks to keep everything from moving. Picture attached to give you an
idea of what I'm talking about.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
136.14 KB |
441 Time(s) |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Tue Mar 13, 2007 4:03 am Post subject: Re: Strapping the Stab |
Ron,
I had the pre-drilled skin like you and I remember this going fairly easily. From what I remember, when the line on the front spar flange was visible, the aft edge of the skin also lined up nicely with the rear spar trailing edge. After you get it strapped and everything is level, square and not twisted as referenced in the guides and drawings, go ahead and trial fit the end ribs to get the warm fuzzy that it looks right before drilling.
Good luck,
DaveG
309.08 KB |
444 Time(s) |
_________________ David Gallagher
Cincinnati, OH area |
bill_dom(at)yahoo.com Guest
Posted: Wed Mar 14, 2007 4:56 am Post subject: Strapping the Stab |
Ron,
According to my interpretation of the construction manual, rivets don't need to be perfectly in the center of the flange, as long as it is 3 times the diameter of the hole (2 times diameter as minimum) away from the edge it is ok (page 5 in my manual). This means 6 mm minimum distance from the edge. It is important that the nose of the sking is well aligned with the nose of the end ribs. Before doing any drilling, you can mark the front spar flange thru the sking hole with a sharpie and then remove the sking and check the mark distance to the edge in order to determine how close it is.
William Dominguez
Zodiac 601XL Plans
Miami, Florida
Ron Miller <flystol(at)bluebottle.com> wrote:[quote] --> Zenith-List message posted by: Ron Miller
Hi All,
Do not archive.
Ron
601XL San Diego
Not making enough money? Click here to get free info on medical [quote][b]
pbaker4(at)windstream.net Guest
Posted: Wed Mar 14, 2007 5:06 am Post subject: Strapping the Stab |
actua;;y. wrong subject. I purchased a 601-hd last fall,The
engine cover goes on the inside of the fuselage and is hard
to install. I noticed on some of the pictures that now the
cowling goes on the outside. Does anyone have pictures
and details of changing from inside to outside?
Paul baker---58 years flying spam cans
pbaker4(at)windstream.com
n85ae
Posted: Thu Mar 15, 2007 6:03 am Post subject: Re: Strapping the Stab |
You need to snug the skin against the nose ribs, or else you will get really deep dimples when you rivet the skin.
Jeff.
| Quote: | Shouldn't I just line up the holes with the midline I have drawn on the flange, drill and cleco? Wouldn't that guarantee alignment of the rest of the skin?
pacificpainting(at)comcas Guest
Posted: Thu Mar 15, 2007 7:12 am Post subject: Strapping the Stab |
GOOD LUCK ON GETTING THAT TO WORK.
Posted: Thu Mar 15, 2007 2:25 pm Post subject: Strapping the Stab |
Lister-
Sorry, it's been so long I lost your name. You probably have a twist on
the axis of the spar. In other words, one tip is higher than the other.
Think about it and check it out. You can probably get out with removing the
rivets in the bottom skin and re-aligning, then going from A4 to A5 as
necessary.
No big deal if you fix it now.
Bill Naumuk
HDS Fuse/Corvair
| Quote: | > What am I misssing here?
