914 Home grown 10MM Banjo 2 of 2
rparigor(at)suffolk.lib.n
PostPosted: Tue Mar 13, 2007 7:31 pm    Post subject: 914 Home grown 10MM Banjo 2 of 2 Reply with quote
On Tue, Mar 13, 2007, rparigor(at)suffolk.lib.ny.us said:
Completed Home grown 10mm to -6 Banjo for Aeroquip 666 Teflon hose with
conductive lining.
The 666 is smaller OD than other -6 hoses and allows me to plumb 914 from
201B Flowscan senders under Airbrake horn, through firewall between
footwell and UCMF.
Made it out of 416 Stainless, replicating Aeroquips reusable fitting
design.
I used Aeroquip Olive and Nut.
Ron Parigoris
 Filesize:  66.38 KB
 Viewed:  311 Time(s)
n100rh(at)sbcglobal.net
PostPosted: Tue Mar 13, 2007 8:20 pm    Post subject: 914 Home grown 10MM Banjo 2 of 2 Reply with quote
Looks like really nice work,
Ralph
> conductive lining.
> footwell and UCMF.
> design.
> Ron Parigoris
europa(at)pstewart.f2s.co
PostPosted: Wed Mar 14, 2007 9:42 am    Post subject: 914 Home grown 10MM Banjo 2 of 2 Reply with quote
Ron
Very neat solution. The only other way I can find to get round it is
Speed flow (www.speedflow.co.uk) do 10mm banjo /AN fittings but the
largest is a AN-04 see attached pics. You would need to put a -o6
to 04 reducer in as well - not ideal. At present I'm planning to
stick with the standard banjo and a hose clamp.
Paul
G-GIDY
 Filesize:  7.09 KB
 Viewed:  2477 Time(s)
 Filesize:  6.42 KB
 Viewed:  2478 Time(s)
PostPosted: Wed Mar 14, 2007 10:11 am    Post subject: 914 Home grown 10MM Banjo 2 of 2 Reply with quote
Hello Paul
I searched extensive, could not find anything suitable.
My first thought was to make a 10MM Banjo to -6 adapter. You can see the
middle mock up I hacked out of aluminium. A bit long but would have
worked.
Shorter and lighter is better IMHO.
Ron Parigoris
 Filesize:  100.24 KB
 Viewed:  348 Time(s)
Hello Paul
worked.
Ron Parigoris
 Filesize:  100.24 KB
 Viewed:  314 Time(s)
PostPosted: Wed Mar 14, 2007 10:12 am    Post subject: 914 Home grown 10MM Banjo 2 of 2 Reply with quote
Hello Paul
worked.
Ron Parigoris
 Filesize:  100.24 KB
 Viewed:  327 Time(s)
fklein(at)orcasonline.com
PostPosted: Wed Mar 14, 2007 7:04 pm    Post subject: 914 Home grown 10MM Banjo 2 of 2 Reply with quote
Ron...you're quite a "hacker"!
Fred
On Wednesday, March 14, 2007, at 10:10 AM,
<rparigor(at)suffolk.lib.ny.us> wrote:
You can see the
worked.
Ron Parigoris
<(at)2 Middle was mock up for -6 adapter.JPG>
