Performance Comparison
jim(at)CombsFive.Com
PostPosted: Tue Mar 13, 2007 2:05 pm    Post subject: Performance Comparison Reply with quote
Regarding the comparison to other aircraft:
Here is a performance comparison someone put together a long time ago. I have the original power point and would add to it if someone has the specific data points for other aircraft of interest. (Bonanza, etc).
I don't know who did this originally, but I did keep a copy.
The points used:
Price, wingspan, length, wing area, empty weight, gross weight, useful load, useful load - full fuel, wing loading, power loading, engine horsepower, fuel capacity, cruise speed, takeoff performance, landing performance, range, climb rate.
Jim Combs
N312F (40192)
perf_cmp.pdf
 Filename:  perf_cmp.pdf
 Filesize:  64.22 KB
 Downloaded:  165 Time(s)
jhstarn(at)verizon.net
PostPosted: Tue Mar 13, 2007 7:18 pm    Post subject: Performance Comparison Reply with quote
AWW..ya forgot the TBM. Carries 6 people, 1000 mile range at better then
300MPH (more than that if they have removed the armor plating & the "Fish")
Short field & climbs out are smartly. Can carry a ton and is fully aerobatic
too. (for a bomber).
KABONG Do Not Archive BUT I agree the RV-10 is the pick of the litter in
it's class. 8*)
PostPosted: Wed Mar 14, 2007 4:15 am    Post subject: Performance Comparison Reply with quote
But it takes 60 gallons of fuel just to start it up and taxi to the runway! (Grin!)
Do Not Archive!
Date: 2007/03/13 Tue PM 10:17:57 EST
Subject: Re: Performance Comparison
it's class. 8*)
jesse(at)saintaviation.co
PostPosted: Wed Mar 14, 2007 5:19 am    Post subject: Performance Comparison Reply with quote
I have also compiled a comparison chart on my website comparing
performance of the RV-10 and several others, both certified and
experimental. It can be seen at www.saintaviation.com/perf.htm. This is
all data that I got from the respective websites.
Speaking of which, has anybody seen the article in Kitplanes about the
Raven 500? They are claiming a max gross 900 lbs over the RV-10, yet
still a 650ft takeoff roll and 1500fpm climb, with the same engine. If
they can do it and still get 197Kts, then more power to them, but I highly
doubt it. Any other thoughts on that? Oh yeah, and how about a
500-600hour build. That would be, no doubt, without finishing (paint,
interior, etc.).
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
The points used:
Jim Combs
N312F (40192)
pilotdds(at)aol.com
PostPosted: Wed Mar 14, 2007 6:12 am    Post subject: Performance Comparison Reply with quote
Having owned an original comanche and now flying a 10.I think performance is quite similar.The raven #"s seem realistic exept top/cruise speed seems somewhat optimistic.The published build time is of course outlandish.
PostPosted: Wed Mar 14, 2007 1:13 pm    Post subject: Performance Comparison Reply with quote
Did you see the cost of the kit? 90K
and the estimate of a finished airplane? 250K
Jim C
Date: 2007/03/14 Wed AM 08:19:07 EST
interior, etc.).
Jesse Saint
C: 352-427-0285
The points used:
Jim Combs
N312F (40192)
PostPosted: Thu Mar 15, 2007 4:16 am    Post subject: Performance Comparison Reply with quote
Yeah, and if they follow the pattern of Van's, it will actually cost
$300,000-350,000.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
