seiders(at)bellsouth.net Guest
Posted: Mon Mar 12, 2007 5:00 am Post subject: Tank fix |
At the risk of opening an old wound what, if anything ever happened
to the tank pickup tube fix fuss that was hotly discussed a year or two ago?
I have the wings off of my 6A for a repair to one of them (hit bush
with leading edge) and recall the discussion. To gain access to tank
interior I removed only the sending unit. After checking my pickup
tube nuts and finding them tight after almost 500 hrs I am thinking
about applying a small dab of pro seal to the joint and avoiding the
really unpleasant task of removing the tank cover plates as well. I
am reasonably satisfied with this as a fix. Would appreciate the
thoughts of y'all out there. Those that did, and those that didn't,
and reasoning.
Thanks.
Dick
panamared5(at)brier.net Guest
Posted: Mon Mar 12, 2007 9:14 am Post subject: Tank fix |
| Quote: | At the risk of opening an old wound what, if anything ever happened to the
Would appreciate the thoughts of y'all out there. Those that did, and
those that didn't, and reasoning.
I did it. Both tanks, one had the flop tube, which was the hardest to
do. It took on average of 12 hours each tank. I know some reported that
it is a 45 min job per tank. But it took that long for me to drain the
tanks? When I figured the time, that includes getting the tools, supplies
and parts necessary to actually start the operation. I took off the tanks
to do it and it was still frustrating, I would not do it with the tanks
still on the aircraft (but messing up the paint job was not a concern of mine).
Also this is a good opportunity to induce a leak if you don't already have
one, or maybe to have some loose proseal end up in the fuel filter (ask me
how I know). The solution could be worse than the problem.
Ten years ago when I built my tanks, both the list and Vans
cautioned: follow the plans exactly as far as the fuel system is
concerned. I did and then a few years later Vans state, if you followed
the plans you did it wrong??!?
As you can see Vans will change their advice based upon circumstances and
not necessarily based upon good engineering data. I considered this fix a
real waste of time, unless of course, it is your fuel pickup that falls
off. This is a 15 minute fix while building the tanks and should be done
at that time.
This is a case much like the Lycoming oil pump. Some will argue that the
AD replacement was as bad or worse than the original. But those who had a
pump failure probably wished they had replaced them!
I offer no advice, it is your butt in the aircraft. Do what is right for you.
Bob
Leland Collins
Posted: Mon Mar 12, 2007 9:38 am Post subject: Re: Tank fix |
Basically, I had the same experience as Bob. Days to remove the tanks and to the fix the problem on an RV9. My fuel tank access covers were gasketted and Prosealed on. I carefully dried the tanks and used heat and prying to remove the covers. Vacuumed Proseal residue from tanks. Even so, I have continued to get a small amount of particulate when sampling the fuel drains, but only a very small amount on the Gascolator screen. My pickup tubes were secure, but the flares on the tubes were horribly scratched. My wings and tanks were Quickbuilds. I bought Van's pre-drilled and "screened" pickup replacement tubes. The level of scratching on the flares of the replacements was better but still unacceptable.
Leland
_________________ Leland
RV9A
N137LC |
Posted: Tue Mar 13, 2007 5:34 am Post subject: Tank fix |
Leland and Bob, thanks for the input. I prosealed the flairnuts to
the clip angles yesterday. I am satisfied with the fix.
Dick
At 01:38 PM 3/12/2007, you wrote:
Leland
Leland
RV9A
N137LC
http://forums.matronics.com/viewtopic.php?p=100081#100081
Hopperdhh(at)aol.com Guest
Posted: Tue Mar 13, 2007 6:01 am Post subject: Tank fix |
VACUUMED? That thought crossed my mind, but then I thought of my shop vac
loading up with gasoline vapors. There are sparks in that motor, and some air
(fuel vapor!) is drawn up to cool it, at least that's how mine works.
Dan Hopper
RV-7A
In a message dated 3/12/2007 12:45:51 PM Eastern Standard Time,
federigo(at)pacbell.net writes:
unacceptable.
Leland
Leland
RV9A
N137LC
<BR><BR><BR>**************************************<BR> AOL now offers free
email to everyone. Find out more about what's free from AOL at
http://www.aol.com.
jpleasants(at)bellsouth.n Guest
Posted: Tue Mar 13, 2007 6:21 am Post subject: Tank fix |
Dan, that's what makes homebuilding so exciting!
Jim Pleasants
Do not archieve
Posted: Tue Mar 13, 2007 6:36 am Post subject: Tank fix |
Didn't I see that on Mythbusters.....?
