Fred Klein
Posted: Thu Oct 10, 2013 12:12 pm Post subject: Question on pwr. dist. diag. Z-19 |
Bob,
On Z-19, I note that the dual batteries are connected in parallel via a brass strap and via grounds which both go to the PNL; one feeds a "Main Battery Bus"; the other feeds the "Engine Battery Bus"; the ECU and fuel pump are fed from both busses via "Engine Primary" and "Engine Secondary" switches and diode bridges.
What I don't understand is why, since the dual batteries are connected, are 2 busses necessary?...Why not just one bus being fed off either of the 2 batteries?...is there a battery failure mode with dual batteries which would preclude drawing current from the good battery thru the failed battery?
Fred
