Landing Gear Warning System
william(at)wbliss.co.uk
PostPosted: Mon Sep 09, 2013 1:30 pm    Post subject: Landing Gear Warning System Reply with quote
Dear All
I am considering adding a landing gear warning system to my monowheel
Europa. I would be grateful for any ideas or tips on how to go about it.
Thanks in anticipation
Will Bliss G-WUFF
davidjoyce(at)doctors.org
PostPosted: Mon Sep 09, 2013 2:01 pm    Post subject: Landing Gear Warning System Reply with quote
William, If you invest in a smartASS it may well save your
life and it also incidentally comes with a system warning
you if gear is not down when you reduce to approach speed,
so it may save your prop and engine too!
Regards, David Joyce, GXSDJ
On Mon, 09 Sep 2013 22:29:59 +0100
Dear All
my monowheel Europa. I would be grateful for any ideas or
Will Bliss G-WUFF
Un/Subscription,
Forums!
Admin.
rparigoris
PostPosted: Tue Sep 10, 2013 7:02 am    Post subject: Landing Gear Warning System Reply with quote
Hi Will
I am considering adding a landing gear warning system to my monowheel. I would be grateful for any ideas or tips on how to go about it.
I am not flying yet, but here is what we are doing:
http://www.europaowners.org/main.php?g2_itemId=27480
http://www.europaowners.org/main.php?g2_itemId=29497
See last 6 schematics:
http://www.europaowners.org/main.php?g2_itemId=81632
Ron Parigoris
PostPosted: Tue Sep 10, 2013 7:20 am    Post subject: Landing Gear Warning System Reply with quote
Ron, I would very seriously recommend putting in a
SmartASS (see article in upcoming Europa Club Mag.) I know
that it has saved at least one Europa pilot's life. It is
an amazing bit of kit that is your best bet for avoiding
stall spin accidents, but also has a nice lady telling you
to put the U/C down! If you are at all interested I will
send you a preview of the article. Regards, David Joyce,
G-XSDJ
On Tue, 10 Sep 2013 11:01:21 -0400
rparigor(at)suffolk.lib.ny.us wrote:
Hi Will
to my monowheel. I
about it.
Ron Parigoris
rparigoris
PostPosted: Tue Sep 10, 2013 7:50 am    Post subject: Landing Gear Warning System Reply with quote
Hi David
Ron, I would very seriously recommend putting in a SmartASS:
We purchased a Smart ASS Mk 1 that will be installed:
http://www.europaowners.org/main.php?g2_itemId=79836
I forget if it has a UC warning input, if it does will probably use it as well as our warning system.
Thx. for your INPUT!
Ron Parigoris [quote][b]
PostPosted: Tue Sep 10, 2013 8:01 am    Post subject: Landing Gear Warning System Reply with quote
Ron, If it is reasonably current it has a wire for a U/C
warning which you can attach to a microswitch in the
indent where the U/C lever goes when locked. You shouldn't
need another one as well. regards, David
On Tue, 10 Sep 2013 11:50:26 -0400
Hi David
SmartASS:
probably use it as
Ron Parigoris
roddyeuropa(at)aol.com
PostPosted: Wed Sep 11, 2013 2:24 am    Post subject: Landing Gear Warning System Reply with quote
Instead of a microswitch, I use a magnetic reed switch mounted on the centre console, with a small magnet embedded in the undercarriage latch. It has the advantage of not restricting the latching in any way.
Roddy Kesterton
G-IKRK
